Serpentine Replacement Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-10-2009, 11:09 AM   #1
Ian97
Fan#: 63873
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 1 Ian97 Good Standing Member
Just starting this year as it has begun to get cold, my car is making a strange noise when I start it up. It makes a whine like it has a super charger. From what I have read, it seems like it could be the idler pulley bearing going bad. I want to pull the belt and see if that pulley binds up turning it by hand or if the car makes the noise sans belt.
The question I have is, what's the best way to get to the belt? It's packed pretty tight against the passenger side wheel well. It is best to go from underneath the car or go from the top?
Ian97 is offline
Old 12-10-2009, 01:38 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Moved to Technical Chat.
Underneath...sort of.
I put mine up on jackstands and removed the wheel and went at it from the wheel well.
And, here's the "How To":
http://www.focushacks.com/?modid=75&ht=Replacing%20Accessory%20Belt%20(Zetec)
^^^Also includes the belt routing diagram.
WD40 is offline
Old 12-11-2009, 09:25 AM   #3
Ian97
Fan#: 63873
Thanks for the info!
Ian97 is offline
Old 12-11-2009, 09:45 PM   #4
deadend9009
Fan#: 69681
What I Drive: 2003 Grey Focus ZX5
FF Reputation: 3 deadend9009 Good Standing Member
I did mine from underneath, routing the top part from the top, obviously. Its an easy job but make sure you remember the routing of the belt!
deadend9009 is offline
Old 12-11-2009, 10:25 PM   #5
copper67440
copper67440's Avatar
Fan#: 43748
What I Drive: 2006 Charcol ZX5
Points 557, Level 11
Points: 557, Level: 11 Points: 557, Level: 11 Points: 557, Level: 11
Level Up 14% Completed
FF Reputation: 1 copper67440 Good Standing Member
just did mine today, from the top and bottom. follow the how to. no problem
Drive it like you stole it!!!!!!!!!!
Zetec crew member# 284
copper67440 is offline
Old 12-12-2009, 01:35 AM   #6
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
Be Careful and make sure you have some good stands.
From the bottom you just have to push the belt tensioner and the belt should just about slip off ... Putting it back on is usually the hard part ... I've done it many times when I've had to change my Serpentine Belt and my Alt .... many times ...
Patience and try not to strip the bolt of the tensioner.
Good Luck.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 12-12-2009, 08:42 AM   #7
deadend9009
Fan#: 69681
i did mine from the car just on its wheels, if you are not lowered you should fit.
Old 12-15-2009, 04:05 PM   #8
Ian97
Fan#: 63873
I enjoy soft pretzels a little too much to fit I think!
Also, I was going to do this in the garage at work. Turns out the automatic door broke so I have to wait!
Ian97 is offline
Old 12-28-2009, 05:57 PM   #9
OrangeSVTguy
Get Squashed
OrangeSVTguy's Avatar
Fan#: 33384
What I Drive: '04 Comp. Orange SVT 3dr.
Points 78,690, Level 100
Points: 78,690, Level: 100 Points: 78,690, Level: 100 Points: 78,690, Level: 100
FF Reputation: 44 OrangeSVTguy Great Standing Member
Buy-Sell-Trade Rating: (17)
Just the thread I've been looking for. Doing my Serpentine belt tonight Now I need to be sure that my tensioner pully is fine...
Then in a few weeks I'm going to do my timing belt since I'm creeping up on 97k miles.
Lee
SVT Squad #227 || Build # 1329 of 1978 || FF ROTM Oct. 2006
OrangeSVTguy is offline
Old 12-28-2009, 07:39 PM   #10
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
This method works well for 'V' belts. Anyone want to try this on Serps?
http://www.youtube.com/watch?v=AcB5-jSqdH0
Don't try this at home......
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
