Researching: Spray Bomb Painting : Proper Techniques. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-10-2009, 01:04 PM   #11
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
Thankyou Norcal, That sounds very true about being overused . I am planning a OD Green Flat/Gloss (undecided) with Satin roof ,hood and Trunk. In every forum i read they say with good prep a rattle can will still last a long time .
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 12-10-2009, 02:02 PM   #12
hamburglar
Fan#: 70864
What I Drive: 2002 Infra Red SVT (for sale)
FF Reputation: 1 hamburglar Good Standing Member
I have a bumper and hood I need to paint. Would it be terribly unwise to try painting it myself until I can afford to get it professionally done?
hamburglar is offline
Old 12-10-2009, 02:44 PM   #13
02Zetechse
02Zetechse's Avatar
Fan#: 65832
IMO, Do your research before you Try to paint anything by yourself. There are a few companies that offer automotive spray paints. Try Alsa Corps "Killer Cans" they are a can with hardener in it . If you chose to Go the Cheap Route Brands I recommend are Rustoleum and Valspar . use dish Soap and water to wipe down the hood to get the dirt and wax off . you want to Scuff your clear coat using approx 200 Grit Wet/Dry sand paper. Wipe it down again with mineral spirits or paint thinner and allow to dry. Spray a Light Coat of high build primer ( IIRC: Rustoleum brand) It will fill in the Scuff Marks. Let the paint dry several hours. Use 400-600 grit to sand the primer coat smooth .
Wash the hood down thoroughly to get the dirt and sanding dust off. Spray a several more light coats and let dry . You should not cover the old paint completely in one coat ,If so you are spraying the paint too thick . try moving the can further away or move more quickly across the hood. After those coats dry wet sand using 1000+ grit to make the surface glassy smooth as rattle cans tend to show every scratch /scuff below it. If you are OCD I recommend going all the way to 2000 grit paper in your sanding. Now to the color coat, A color coat will likely have unevenness to it if you do not have enough coats on it. Depending on the color and brand of paint you may need more or less coats. there will be over spray from the can of paint. Something I do when using aerosol paints is use a box fan to suck the air from my workspace to keep the paint cloud from settling on my painted piece.
For the bumper I would use a adhesion promoter to make the paint stick to the plastic .
I have read that you can claybar the piece to get the overspray off to make the hood smooth.
Anytime you get something professionally painted they will charge you a little more for stripping a spray painted piece.
just my 02C
Old 12-10-2009, 03:36 PM   #14
hamburglar
Fan#: 70864
What if I get black hood and black bumper and want to paint it Infra Red? Do I have to take off the black paint first?
Old 12-10-2009, 07:04 PM   #15
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
The paint in a rattle can is no differant than paint in brush form. IDK why so many people think that paint in a spray can is cheaper paint.
Depend on what you want for an out come. Ive used rattle cans on my trunk lid and door. I took my time and finished it with rubbing compound, you cant tell that I used a spray can.
just my 02C
Prefect advise
I wouldnt, just use gray primer first.
norcalfocus01 is offline
Old 12-11-2009, 09:51 AM   #16
02Zetechse
02Zetechse's Avatar
Fan#: 65832
I have to disagree with Norcal on using grey primer to go from black to red .Although your results will prolly be unnoticeably different I would use the Red Oxide Primer. Its a red/brown primer . Either way its done will work perfectly fine. The red paint may cover better on the Red Oxide Primer.
Old 12-11-2009, 12:00 PM   #17
norcalfocus01
Fan#: 55603
The reason you want to use a differant color primer, is so when paint the finish coat on, if you cant see the primer, you know youve put enough paint on.
Hi end auto painters used to use red oxide primer, under yellow, blue, black. Just so they knew they had put an even full coat on the car.
Old 12-11-2009, 12:39 PM   #18
02Zetechse
02Zetechse's Avatar
Fan#: 65832
I didnt know that .hope you don't mind if I add that to my OP cause that is good to know.
Old 12-11-2009, 07:50 PM   #19
norcalfocus01
Fan#: 55603
No problem. Please go ahead and do so.
Kinda of a side bar, but I seen paint specs for bridges that say red for the 1st coat, yellow for 2nd coat, and blue for the 3rd. Just so the job inspector knows that enough paint had been put on the bridge.
Old 12-12-2009, 06:34 PM   #20
02Zetechse
02Zetechse's Avatar
Fan#: 65832
Great selection of paints for good prices
http://www.tcpglobal.com/spraypaintdepot/
Tags
diy paint , rattle can , spray bomb , spray paint
