car wobbles side-to-side on highway on/off ramp turns - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-09-2009, 06:06 AM   #11
awalp
Fan#: 52288
What I Drive: 2003 Ford Focus ZX5 SVT
FF Reputation: 1 awalp Good Standing Member
I took it to a tire place and they checked the alignment and the suspension, only one number was off and it was wihtin spec. The rest of the alighment numbers were perfect.
They did notice one of my tires only had 12lbs of air so they made sure all the tires are inflated.
They could find nothing wrong with the suspension, they recommended I replace the struts and shocks due to the age 80,000 miles, but they aren't blown.
Now with all the tires evenly inflated, and the suspension having bh checked, I still feel like the car jerks side to side. Maybe it is normal, or maybe there is something wrong still. My next step is going to be getting those tire pressure indicator valve cover caps so I also can rule out tire pressure first, then replace the struts and shocks, though I really don't want to replace the struts and shocks early if at all avoidable.
awalp is offline
Old 12-09-2009, 07:09 AM   #12
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,291, Level 46
Points: 5,291, Level: 46 Points: 5,291, Level: 46 Points: 5,291, Level: 46
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Did they check it and deem it within specs for a regular ZX3 or was it an SVT? There is a difference in the alignment settings. Swing by your local Ford dealer to get the specs for an SVT and compare those with the specs at your tire place.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 12-09-2009, 07:06 PM   #13
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
this could still be the problem. Fords spec is too broad . your alignment can be "on spec" and still cause handling issues and tire wear issues, etc. do you have the actual alignemnt numbers that we can analyze? can you show us the printout? if that one number that is off is the toe in the rear, then this most likely is the problem.
Also if just 1 number is off, especially if it is just one side, it might indicate a bent componant.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 12-10-2009, 07:28 AM   #14
Missourileo
Captain Retard
Fan#: 55980
Still wondering if they aligned it to SVT specs or a regular ZX3.................
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 12-10-2009, 11:28 AM   #15
focuzed1
focuzed1's Avatar
Fan#: 10722
What I Drive: 2002 liquid grey zx3
Points 10,847, Level 68
Points: 10,847, Level: 68 Points: 10,847, Level: 68 Points: 10,847, Level: 68
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 16 focuzed1 Great Standing Member
Buy-Sell-Trade Rating: (15)
also check the bolts on your rack and pinion steering.. i had this same problem with mine and got underneath with a wrench and noticed that my bolts for my rack and pinion were loose.. tightened them up.. and volaa problem fixed..
Too Fast For Me... TONS OF WHP... GOBBS OF WTQ......
Go ahead put your car where your mouth is....
focuzed1 is offline
Old 12-11-2009, 03:13 AM   #16
Glowboi87
Glowboi87's Avatar
Fan#: 54766
What I Drive: 01 pitch black zx3
FF Reputation: 2 Glowboi87 Good Standing Member
i wonder if your rear suspension bushings are worn.... i know mine are and it does a bit of the same behavior
FOCUS NATION
Glowboi87 is offline
Old 07-15-2013, 12:09 PM   #17
Carma
Fan#: 116748
What I Drive: 2004, Black, ZX5,
FF Reputation: 1 Carma Good Standing Member
Issue Resolved?
awalp- was your issue ever resolved? I am having the same problem myself.
Carma is offline
Old 07-15-2013, 02:12 PM   #18
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
check your rear wheel bearings....mine was doing this a few months back...back end on the highway was wondering back and forth like your's. both of my bearings were bad and not making any noise. my d/s rear bearing had so much play the tire was moving enough to touch the control arm. scary when i discovered it. new bearings and all is good!
#3286 OF 4788
jasonbi is offline
Old 07-15-2013, 03:05 PM   #19
Carma
Fan#: 116748
Thanks, Jasonbi.
I haven't experience any wobbling driving straight on the road. Just when I go around clover leaf turns off of highways. If you still think the bearings are the issue I will get those checked out ASAP.
Carma is offline
Old 11-30-2013, 12:30 AM   #20
ZX2003
ZX2003's Avatar
Fan#: 98743
What I Drive: 2003 Pitch Black ZX3
Points 372, Level 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level Up 44% Completed
FF Reputation: 1 ZX2003 Good Standing Member
I'm wondering if the problem has been resolved, I'm having the same exact problem but only on right turns, more specifically on and off ramps, or tight highways turns, my cars wobbles VERY bad. Very unsafe. It also bounces left to right if I'm in a right highway lane where trucks have indented the road. I've had it checked out and an alignment done. They weren't able to see a problem and told me my suspension was fine. After reading this ill def check out the wheel bearings.
ZX2003 is offline
