2002 Wagon door Ajar light - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-01-2009, 11:18 PM   #1
Hexar
Fan#: 67254
What I Drive: 2002 Ford Focus Wagon
FF Reputation: 1 Hexar Good Standing Member
Hi Guys,
I have a 2002 manual Wagon with the Zetec engine. Recently the Ajar light on the instructment panel lights up, and the blue remote button that opens the trunk liftgate does not work, the liftgate switch inside the car, near the instructment panel does not work either. The only way to open the liftgate is to use the key to open it.
I think the switches on the doors seem right, I think the problem is the liftgate switch. I tried to fix it, but was not successful. I opened the plastic panel, tried to lube the lock mechanism by WD40 shots, not working.
The fuse 63 behind the fuse panel is good.
Oh, the switch on the liftgate, where there are 4 wires: white/green, black/red, black and one other wire. Is this the switch that might be gone wrong?
On the Haynes manual, it listed a "Tailgate decklid anti-theft inhibit switch", where is this switch located?
So what else should I check?
Thanks a lot!
Hexar
Hexar is offline
Old 12-01-2009, 11:21 PM   #2
Hexar
Fan#: 67254
oh, forgot to say: currently, if I Lock the system by pressing the lock button on the remote, twice, the horn will sound twice, maybe indicating that one of the locks is not locked...
Hexar is offline
Old 12-01-2009, 11:30 PM   #3
Lancer211
Lancer211's Avatar
Fan#: 65747
What I Drive: 2004 infrared sedan SE
FF Reputation: 4 Lancer211 Good Standing Member
Buy-Sell-Trade Rating: (9)
Perhaps your door is ajar?
2004 Zetec infrared ATX sedan SE "Ruby"
CarDomain page: http://www.cardomain.com/ride/3345563
Lancer211 is offline
Old 12-01-2009, 11:31 PM   #4
Lancer211
Lancer211's Avatar
Fan#: 65747
Sorry, couldn't resist. But seriously, does the liftgate latch properly and everything?
How about your hood? Have you checked that?
Old 12-01-2009, 11:42 PM   #5
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
You have a broken wire in your hatch OR a defective Hatch Latch mechanism
pull the boot between the hatch and the body and inspect the wires.. don;t be surprised if they look like these
The Second Horn beep means one of the doors is being detected as open
Mine stopped working and one day auto opened when we hit the brakes the door suddenly popped open and I lost one of the 4 Pinnacle Rims and tires I was hauling
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Old 12-03-2009, 09:59 PM   #6
Hexar
Fan#: 67254
np.
all the doors were shut, because when I open any one of them, the interior light will come on. so I think the switches for the 4 doors are good.
I "checked" with the hood - open and close it a couple of times...
The reason I am think it is the liftgate is: I cannot open it with remote nor with the liftgate switch inside.
Thanks for the reply and suggestions though.
Hexar is offline
Old 12-03-2009, 10:01 PM   #7
Hexar
Fan#: 67254
WOW, that maybe it... Because my rear wiper and defroster do not work either (they don't work when I bought the car this summer, and I always assumed it was bad motor.)
Is it hard to remove the boot and stuff? Is there a howto on this subject?
Thanks Feral!
Hexar is offline
Old 12-03-2009, 10:25 PM   #8
Feral
Feral's Avatar
Fan#: 58350
ill get a video how to pull the boot off its pretty simple but the hatch has to be open in order to inspect them
with the hatch open grab and gently pull the boot down it will peel off its hard plastic insert retainer... once off you can see the wire... to properly replace the boot grab a small knife and slide it between the hatch and the hard plastic insert (you will see the clips on the inner part where you have to press once there released it will pop out just slide/manouver the lip back on the retainer and insert back into the hatch (you will hear it click) as for the repairs I havn't gotten that far yet on making a how to for it... i want to see if there is any way possible to do it without having to remove the interior panels of the car to give enough wire to be able to fix the affected spot
Feral is offline
Old 12-04-2009, 04:07 AM   #9
daidie
daidie's Avatar
Fan#: 70867
What I Drive: 2003 maroon red 3 dr hatchback(zx3)
FF Reputation: 7 daidie Good Standing Member
take your parcel shelf out close the boot lid then see if the boot light is still on if it is then you may have a dead boot lid sensor, it needs to be repaired as the boot light staying on may cause your battery to drain if left standing for long periods.
red focus zx3, stainless from cat back, the big 3, k&n, anti carjack mod, in dash dvd with jbl sub and custom 5x7's, ghia interior light mod.
have you repped someone helpful today
daidie is offline
Old 12-04-2009, 03:35 PM   #10
yards
Fan#: 71027
What I Drive: 2005 light tundra ZXW
FF Reputation: 1 yards Good Standing Member
door ajar indicator (wagon)
hello ff's
i had been troubleshooting the door ajar symptom on my wagon with no luck,
(down to the component level-took the latch mechanism apart, tried jumping some wires in the connector etc.)
Really glad to find this recent post, I pulled the wiring boot open as illustrated by Feral and was amazed at how much bare and broken wiring there was under the boot.
I soldered a few connections and sealed things up for now and everything works as it should.
Many thanks for the great tip. (unique also, i read ahundred posts on those sensors , this was THE one should be the first place someone looks w a hatch)
regarding the first post- the 5 wires to tailgate latch are :
WH/GN -liftgate unlatch motor
BK -Ground
BK/BU -liftgate ajar switch, output
BK/RD -liftgate ajar switch, signal
BK/OG -liftgate antitheft switch signal( not on my '05)
yards is offline
