UEGO bung location for aem afr gauge - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2009, 08:36 PM   #21
seige123
Guest
Fan#: 17996
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 3 seige123 Good Standing Member
This was the first time for me so I guess I have about 1.8 yrs left ebfore the next one if I am correct.
seige123 is offline
Old 12-04-2009, 08:38 PM   #22
seige123
Guest
Fan#: 17996
I need it to be good enough for Tom so if that loaction is good enough for him for tunng it should be okay for now. This location will not be its permanent home either way.
seige123 is offline
Old 12-04-2009, 09:03 PM   #23
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
did you say "bung"???
HaveBlue83 is offline
Old 12-07-2009, 09:14 PM   #24
seige123
Guest
Fan#: 17996
maybe....
seige123 is offline
Old 12-08-2009, 07:06 PM   #25
..:: sleestak ::..
on thin air
..:: sleestak ::..'s Avatar
Fan#: 22528
What I Drive: 04 Forester XTi
Points 14,456, Level 78
Points: 14,456, Level: 78 Points: 14,456, Level: 78 Points: 14,456, Level: 78
Level Up 2% Completed
FF Reputation: 80 ..:: sleestak ::.. Excellent Standing Member
Buy-Sell-Trade Rating: (15)
Originally Posted by toeycrack View Post
i would recommend putting the sensor BEFORE the CAt. I was told this buy a fellow SCT tech. and a AEM tech. reason is, installing after the cat will cause the reading to flux. you won't get a accurate reading. the flow of flume builds up in the cat and release a reading only a wack job can read.
when i had mine in my second o2, i had reading from 11 to 14..... and it should of really been around 11 to 12, 13 is getting close and 14 is past....
just my cent... but what do i know?
Sounds like a reasonable argument, but then how come a lot of dyno's have a probe that gets stuck in the tailpipe? That's post-cat as well.
..:: sleestak ::..
"Our mother of blessed accelleration, dont fail us now!" -- Elwood Blues
..:: sleestak ::.. is offline
Old 12-08-2009, 08:51 PM   #26
pitchedblack04
Bewst Anyone!!!
pitchedblack04's Avatar
Fan#: 62993
What I Drive: 2004 turbo'd svt
Points 3,266, Level 35
Points: 3,266, Level: 35 Points: 3,266, Level: 35 Points: 3,266, Level: 35
Level Up 44% Completed
FF Reputation: 7 pitchedblack04 Good Standing Member
hmmmm
Car is for sale. Pm me for details.
pitchedblack04 is offline
Old 12-09-2009, 09:37 PM   #27
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
EGT just throwing it out there; i really have no idea.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 12-09-2009, 11:21 PM   #28
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,240, Level 72
Points: 12,240, Level: 72 Points: 12,240, Level: 72 Points: 12,240, Level: 72
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 77 S0C0nFused Excellent Standing Member
How is it that other manufacturers/cars can hang there cats below the car but our Focus have the thing in the friggin manifold. I.E. how can they get away with that? Is it tuning where they run a really lean mix at startup or something?
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 03-06-2011, 11:45 PM   #29
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
I read those are more for older muscle cars that didnt have cats.
My wideband is made by innovate and their forum group said i would be fine running the front sensor that is on the header as long as i use a home made heatsink. With the shielding over the mani-cat along with the home made sink it should stay cool enough. They said the wideband will throw a code if its running to hot and doing it once wont burn it up.
WHat im worried about is what soconfused said about it messing up the engine. Somthing about dumping in to much fuel or somthing because that sensor is not in there?
Ide prefer the #1 bung if the engine will run ok. If i have to use the second or third i just want to see what its doing for now.
It's not important to win, it's important to make the other guy lose.
BowerR64 is online now
Old 03-07-2011, 12:53 AM   #30
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Lol! Ok, your not 'getting it'. let me try again. Your gauge measures the air/fuel ratio, it does not control it. Your air/fuel ratio is controlled by the sensor in (refer to your pic please) the number 1 bung hole. IF you remove that sensor, then your ECU (which controls your fuel injectors via input from the sensor in #1 hole) would have no reference to know how much fuel to add or subtract. I suspect that with no input, it would just keep adding fuel in an attempt to get some kind of reading (would it simply assume no fuel? That is what I am unsure about). Regardless, you car won't be able to run without sensor #1. Sensors #2,3 are for measuring the health of your catalytic converter. Note that sensor #2 resides right in the middle of it in the 'canister' portion (well, actually, that is an assumption as noone has ever taken one apart to know if it is in the cat or right before it. but based on it's location and the size of the canister make up your own mind). Regardless, it is a very poor location for a wideband as you want the exhaust gases flowing in close proxity to the wideband sensor. the canister is to big thus 'diluting' the mix. Hence, your only location left would be after the cat near #3. But as you already have a sensor stuck in the pipe at that location (assuming you keep it thus avoiding having to rig up a cheater), that leaves you with only the flex pipe or somewhere more 'downstream'. Typically, you would locate a wideband sensor in the collector of the manifold anyway (where the gases come together from the exhaust ports). So that is really your only option as regards the stock mani-cat.
Better?
add > I read what your wrote about heatsinking the wideband. Discounting that you cannot drill and tap a bung into the cast material, I think there wrong. See, aftermarket headers are made from tubular steel. Hence, they dissipate heat much faster than a cast unit. That being known, If you were to add a heatsink (such as a piece of copper on the wideband sensor), it would heatsink the entire cast portion of the upper manifold (as it is coolest, heat would flow to it). Tween you and me, that's a lot of heat. And if your sitting at a stop light, you don't even get the advantage of airflow. So without that, the wideband is going to cook.
