#11 | ||||
But! We digress. The question was where could seige123 locate a bung for his A/F meter on his stock mani-cat. A header is tempting, but regardless of what catalytic converter you stick on the end of it, it won't pass emissions if they do a cold start sniff test. Which around here they would if they saw an aftermarket header (and they will), or just fail it as it's not OEM. But, things are diff in various parts of the country so its really a local issue.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance. Last of the Hatches #28 |
| Sponsored Links | |||
Advertisement | |||
#12 | ||||
FF Affiliate
In NC the engine has to be at running temp to do the sniff test so the CAT would be heated , place the wide band o2 in the second hole and you will be fine
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#13 | ||||
Tom >> You think the wideband will have sufficient exhaust flow? (Yes I am aware that the bung is somewhat imbedded deeper into the canister, but its only ~1/2").
#14 | ||||
Guest
I'll do the 2nd o2 from what tom said for now. I live in illinois and its illegal to remove the cat but I have gone to do my emmision testing and they do not check under the hood or sniff the tail pipe. They just do the obdII. So I think I would be fine as long as I do not get a failed signal on the o2 sensor readings, which from what Tom said, it should not be a problem if the rear o2 sensor is disabled (this I have to test out unless someone has done it already in illinois).
Also, Im just setting up for a turbo in the future and a header would be a waste of money for me unles I get another focus or I could sell it locally... |
#15 | ||||
You're suggesting that the stock SVT would fail an emissions test? That's hard to believe.
2004 Zetec infrared ATX sedan SE "Ruby" CarDomain page: http://www.cardomain.com/ride/3345563 |
#16 | ||||
FOCUS REVOLUTION
I am emissions certified and In IL what they told me about people like us" that cheat the test" is that is to small of a percentage to worry about So if ur in IL and the tune disables the rear O2 you'll be fine
FOCUS REVOLUTION FSWERKS MASSIVE SPEED SYSTEMS SCSCC #320 |
#17 | ||||
Not as hard as believing you would inject an SVT into a Duratec discussion.
#18 | ||||
#19 | ||||
FF's Quadriplegic!
As a matter of fact, My car has never been tested since I bought in 2004.
513whp on Race Gas; Tuned by Fernando@RacingPartsSolution.com"] Pump gas? Ppffff! Part III: Install Handicap Driving Controls Ma Cah: http://imgur.com/a/TuyYL |
#20 | ||||
i would recommend putting the sensor BEFORE the CAt. I was told this buy a fellow SCT tech. and a AEM tech. reason is, installing after the cat will cause the reading to flux. you won't get a accurate reading. the flow of flume builds up in the cat and release a reading only a wack job can read.
when i had mine in my second o2, i had reading from 11 to 14..... and it should of really been around 11 to 12, 13 is getting close and 14 is past.... just my cent... but what do i know?
my focus is for sale.... |
| Thread Tools | |
| Display Modes | |
