o2 oxygen sensor wiring diagram - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2009, 03:31 PM   #1
Import Slayer
Import Slayer's Avatar
Fan#: 69357
What I Drive: liquid grey zx3 01'
FF Reputation: 2 Import Slayer Good Standing Member
Hi all,
we are in the middle of tuning with Tom, and our o2 sensor isn't working. when we put the key on the on position, we are definately getting 12v to one of the wires, but the o2 sensor won't heat up. we have 4 sensors, his original, one that came with his header, and 2 brand new bosch. does anyone here have a diagram of what all 4 wires should be at (voltage, etc)?? i have a volt meter and really want to get this fixed today... actually not only today, but within the next hour or 2. any feedback is appreciated
tia
Import Slayer is offline
Old 11-27-2009, 04:06 PM   #2
Import Slayer
Fan#: 69357
ok so I've ruled out that its not the 12v.... instead it is the ground. where does my o2 sensor ground to? i've checked the entire negative off my battery terminal, everything is checking out. i want to know, where does my o2 sensor ground to?? which is why i need a diagram
thanks
Old 11-27-2009, 04:34 PM   #3
Import Slayer
Fan#: 69357
is the black wire on the o2 sensor plug the ground? or the grey?
thanks
Old 11-27-2009, 05:17 PM   #4
Import Slayer
Fan#: 69357
we spliced into the other white wire to manually connect it to 12v. no luck. it will not heat up
i don't even know what to do anymore....
Old 11-27-2009, 06:06 PM   #5
calvin1234
calvin1234's Avatar
Fan#: 67836
What I Drive: 09 Vista Blue SE Sedan & 99 Tracker
FF Reputation: 8 calvin1234 Good Standing Member
http://www.fordfuelinjection.com/?p=31
"You will be assimilated, resistance is futile"
Give a rep when someone is helpful
calvin1234 is offline
