What kind of Antifreeze? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 11-27-2009, 03:20 PM   #1
FocU
FocU's Avatar
Fan#: 36693
What I Drive: 2000 Red ZX3
FF Reputation: 4 FocU Good Standing Member
Today I realized there is not a single drop of coolant in my tank lol. I put in the Prestone 50/50 prediluted type for my 2000 Zx3. Is this the correct one. Just want to make sure! Thanksss
FocU is offline
Old 11-27-2009, 03:26 PM   #2
lightning2nd
love my red focus
lightning2nd's Avatar
Fan#: 54938
What I Drive: 2006 Red ZX4 SES w/SAP
Points 1,324, Level 20
Points: 1,324, Level: 20 Points: 1,324, Level: 20 Points: 1,324, Level: 20
Level Up 24% Completed
FF Reputation: 3 lightning2nd Good Standing Member
i do think you are using the right one, does it say for all makes and models thats what im using
Built on 1-18-06
06' Red ZX4 SES 2.0L Duratec/ with S.A.P.
member of Focus Nation / Sedan Revolution#105 / Sap Crew#23 / Team Duratec#189 / Midwest Crew#31
lightning2nd is offline
Old 11-27-2009, 07:49 PM   #3
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
I don't think it matters what brand, but it does matter what color. Check to make sure you put in the right color...and never let that run out that much again lol.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 11-27-2009, 07:51 PM   #4
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,097, Level 34
Points: 3,097, Level: 34 Points: 3,097, Level: 34 Points: 3,097, Level: 34
Level Up 32% Completed
FF Reputation: 11 hEaT Great Standing Member
I've used that in mine with no issues.
Check your coolant again after a short drive. Depending on how low it was, you may have to burp some air out of the system. Also, check for leaks. That's a lot of coolant to lose.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 11-27-2009, 07:55 PM   #5
DrkKnight614
GO Green
Fan#: 14522
HEAAATTT...whats uupppp, I haven't seen you post in the longest time lol. Still rocking that awesome sig I see...
Yes def keep tabs on it, draw a line or use tape on the coolant tank. My thermostate housing went and had to get it replaced. Shop drained the whole system, things seemed fine, but then I overheated one day. Air in the lines, not good...Coolant looks fine in the tank but non makes it to the engine.
Old 11-27-2009, 08:29 PM   #6
hEaT
Fan#: 20699
Haha, yeah, same sig. I don't spend a lot of time over here anymore. Just reading now and again.
ZETEC Crew #49
hEaT is offline
Old 11-27-2009, 09:39 PM   #7
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
Points 3,454, Level 36
Points: 3,454, Level: 36 Points: 3,454, Level: 36 Points: 3,454, Level: 36
Level Up 70% Completed
FF Reputation: 16 arlenn Great Standing Member
thermostat housing is probably leaking... you should not be losing coolant!
arlenn is offline
Old 11-27-2009, 10:44 PM   #8
uh60james
uh60james's Avatar
Fan#: 6968
What I Drive: 2010 Sterling Grey SE Sedan
FF Reputation: 6 uh60james Good Standing Member
I wouldnt reccomend using that Prestone that claims to be forall makes and models. There are 3 major different types of coolant, the green one, Dexcool, and and the gold coolant (G-05 I think). I dont know what year Ford switched to the gold coolant but if thats what your manual calls for thats what I would use. Obviously you wont see any immediate problems using a different type since they all serve the same purpose but they do offer different levels of protection based on the vehicles cooling system. I'm sure someone will disagree with me but I just dont believe Prestone has figured out some magical way to meet the specs of all auto manufacturers.
uh60james is offline
Old 11-29-2009, 02:16 PM   #9
CopperMach
CopperMach's Avatar
Fan#: 42945
What I Drive: 2002 Copper Mach Audio Focus ZTS
Points 501, Level 10
Points: 501, Level: 10 Points: 501, Level: 10 Points: 501, Level: 10
Level Up 2% Completed
FF Reputation: 10 CopperMach Great Standing Member
The Motorcraft green coolant that your car originally came with and Motorcraft gold coolants are compatable. The gold coolant has a better protection package, and a longer life expectancy (100,000 mile) than the green. Most of the universal coolants will mix well with either green or gold. Motorcraft orange coolant or GM dexcool is completely different and should not be mixed with green or gold (has a tendancy to gel when mixed which is a very bad thing in a cooling system.) The universal coolants work just fine to top off a system or get you by, but I would recommend finding your coolant leak and after it is fixed flush your system and fill it with either green or gold.
Last edited by CopperMach; 11-29-2009 at 11:16 PM. Reason: typing faster than my brain works
CopperMach is offline
Old 11-29-2009, 02:17 PM   #10
CopperMach
CopperMach's Avatar
Fan#: 42945
Also, if you mix green with gold consider the protection level based on the lesser of the two coolants (green.)
