spark plug and oil issue? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-22-2009, 08:46 PM   #1
zinsavage123
zinsavage123's Avatar
Fan#: 69910
What I Drive: 2001 focus zx3, 2001 mustang gt
FF Reputation: 1 zinsavage123 Good Standing Member
I went to check my spark plugs and seen oil on the ring of where the plug comes out as well as on the spark plug boot. I was told I need a new valve cover gasket, cause some oil is noticable on the outside of the valve cover as well. Is this true for both issues? Also what causes those two issues is it anything major I should fix like asap? cause the oil isnt on the actual tip of the plug, but was on the plug and outer ring where you go to untighten them.
2001 silver zx3 - mods in my profile
2001 black mustang gt - k&n drop in filter, upr o/r xpipe, flowmaster super 44 mufflers, cobra R 17" rims w/ 315/35's on the rear
zinsavage123 is offline
Old 11-22-2009, 08:49 PM   #2
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,625, Level 43
Points: 4,625, Level: 43 Points: 4,625, Level: 43 Points: 4,625, Level: 43
Level Up 38% Completed
Forum Activity 3%
FF Reputation: 28 ah1f39 Great Standing Member
Will only get worse. May cause the plug to misfire.
ah1f39 is offline
Old 11-22-2009, 08:53 PM   #3
ajp
ajp's Avatar
Fan#: 54748
What I Drive: Red 2003 EAP
FF Reputation: 8 ajp Good Standing Member
the valve cover gasket is indeed the issue and needs to be replaced. i would get it done at a place that offers a warranty....
if it is not replaced sooner than later, the issue may compound and you may start having thermostat housing problems
ajp is offline
Old 11-23-2009, 12:38 AM   #4
zinsavage123
Fan#: 69910
is this normal for that to happen in these cars? also since u said a warrant to cover it im assuming its expensive to replace the gasket or no?
Old 11-23-2009, 12:47 AM   #5
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,806, Level 54
Points: 6,806, Level: 54 Points: 6,806, Level: 54 Points: 6,806, Level: 54
Level Up 28% Completed
FF Reputation: 4 ChrisRobin Good Standing Member
I'm coming across the same problem...
The valve cover gasket costs about $40 and then to change it doesn't look all that difficult.
Originally Posted by WRCwannabe View Post
...and then slap a supercharger on it and rape their tits off.
ChrisRobin is online now
Old 12-21-2009, 04:43 PM   #6
zinsavage123
Fan#: 69910
what would the effects be if it caused the thermostat housing to go bad, cause I have been having overheating issues here and their not constantly though.
Old 12-21-2009, 04:48 PM   #7
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
Well your thermostat housing should be fine as long as you don't have coolant dripping/leaking everywhere. I think it's just your thermostat that's buggered and that's a $8 part.
Old 01-03-2013, 04:40 PM   #8
gtompkins09
Fan#: 107739
What I Drive: 2008 Blue Focus
FF Reputation: 1 gtompkins09 Good Standing Member
Me too! Found oil in two. If Chris said, "it doesn't look difficult." Then, I should be able to replace the valve cover gasket. Sounds like fun. wink
Let's see what Autozone have there.
Replaced valve cover gasket that Autozone did have. All is well.
gtompkins09 is offline
