| ZETEC Performance Chat The place to chat about any 2.0L Zetec engine performance, tuning and exhaust related upgrades. |
Thread Tools | Search this Thread | Display Modes |
#1 |
01 BBK TB on a 02? will it work??
SO i got a 65mm bbk Tb from a friend, it for a 2001 zetec 2.0, Will it work on my 2002 zetec?? the only difference i noticed between a actuall 02 Cfm tb was it has one little hole next to the main hole instead of three little ones... does anyone know if this will work.. I put it on and my car wont start, it turns but doesnt want to run... my wires and plugs are good ... and when i put stock tb on it works fine. whats up with this thing?
~ ONE.SIC.FUC.N.LOWRIDER ~ |
#2 |
SNOWMOBILING 4 LIFE
it should work just fine. i don't see why it wouldn't. maybe the TPS off the other zetec isn't mounted right.
SALE: 3 JRSC zetec SC's, Rally skid plate, s2 spoilers, Tires, Headlights, 65 mm tb duratec (pending), my LAST SVT JRSC w/ BBK and tuning voucher, 3" MAF, 2 zetec/svt turbo kits, built zetec/svt bottom end! PM me |
#3 |
I just realized i might have moved the inside rotating part of the sensor when i connected it... would that mess it up?? maybe its keeping the thing closed.
#4 |
Everything mounted on it exactly the way the stock looks, what could be making the car not start? it turns like once then stops... if i hold the gas a little when i start it it runs like crap...sputtering and shit! HELP!
#6 |
Im going to put a new one on today and try it, could that stop the car from starting cause its not taking in the air through the MAF sensor?
#8 |
SNOWMOBILING 4 LIFE
the TPS sensor is like super sensitive, i'm guessing thats broken, especially after transfering htem.
#9 |
but if its broken wouldnt it not work on the stock throttle body? i put the stock on tb back on when the bbk didnt work, and the car ran perfect.
#10 |
SNOWMOBILING 4 LIFE
o ya, forgot. i'd think its possibly the holes. try putting the tps in diferent holes to see if it starts
#11 |
ST
One big hole next to the main hole instead of three little ones? It sounds like you are describing the idle air control part of the throttle body and it would seem that it might be letting too much air bypass during idle, due to the different size hole, causing it to die. Try unplugging the IIAC and see if it will idle. If that doesn't work, you might want to crack the throttle body open just a little using the throttle pedal, in essence bypassing the IIAC to see if it will run.
#12 |
先生滑稽很多 do what?
it doesnt take much air bypassing the MAF to mess up the idle and cause the car to stall. i would gamble on it being a vacuum leak due to those little holes you're talking about or a bad throttle body gasket.
Knowing is half the battle of course the other half is violence Time-Out: A disciplinary method designed to ready many of today's youth for where they will eventually need that skill the most.....Prison The pills made me say it! |
| Bookmarks |
| Display Modes | |
