LED's not working properly... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2009, 02:01 PM   #1
V8FordTempo
Fan#: 67291
What I Drive: 2007 SE, 2006 SES ZX4.
FF Reputation: 1 V8FordTempo Good Standing Member
Lightbulb LED's not working properly...
I just got all of my LED's for the '07 and started on the passenger side.
I put in the reverse lights, OK no problem, nice.
I put in the rear tail bulb... EWW, first off it flashes fast (due to less current draw) second the LED is dimmer than the old bulb, cause it doesn't
reflect off of the rear of the lense.
I then put in the front turn LED, looks nice, but again confused the heck out of the circuit.
only flashes with hazard lights, and when the parking lights are on, the console flash indicator is lit. lol
All probably due to the current sensor (or whatever)
MY QUESTIONS:
1: would one of those rectangular (?) 360 degree 3157 LED's
make my tails brighter? or can I leave the old bulbs there
(even though the rest are led's, and dont want ANY normal bulbs)
2: What do I do about the current sensor? somone mentioned a new
"LED compatible" turn signal relay... what and where is it?
would this solve my problem with adding all LED's?
please help, I need to get this project done, and the car
out of the garage, back on the road.
Steve M. - Akron, Ohio - USA
2007 Focus SE (35,000 miles) (wrecked)
2006 Focus SES ZX4 (65,000+ miles)
1969 Dodge Charger, 1977 Ford F100 Ranger XLT,
1988 Ford Tempo GRT, 1993 Ford Tempo GLO.
V8FordTempo is offline
Old 11-19-2009, 02:39 PM   #2
2wheeladict
2wheeladict's Avatar
Fan#: 69029
What I Drive: 2005 focus zx4, 2003 cbr f4i
FF Reputation: 8 2wheeladict Good Standing Member
yaaaa i did the same thing with the front signals. they worked for about half a day until something melted in the bulb and current was going where it shouldnt. put the stock bulbs back in and itll fix it. the problem is all the turn signals/tail lights run through a modual that monitors current draw. es gay. theres pretty much no way to use led signals unless you get high quality ones or make your own circuitry (which ive been thinking about doing)
2005 ZX4: CAI, FRPP, eibach sportlines, hids
1983 kawasaki KZ550 cafe project
4 wheels move the body, 2 wheels move the SOUL
2wheeladict is offline
Old 11-19-2009, 04:06 PM   #3
05yellowd20
Fan#: 62464
What I Drive: 2005 Yellow ZX3 2.0 Duratec
FF Reputation: 15 05yellowd20 Great Standing Member
Buy-Sell-Trade Rating: (4)
that is incorrect. you can buy "load equalizers" from advance auto. maybe autozone. for about 12 bucks. they look like rectangular ceramic tubes with wires on them . they are resistors that make a higher load in the circuit and stop the module from freaking out.
i had a set in my car. just be sure to wire them right and in an area with some airspace because they can get as hot as incandescent bulbs.
05yellowd20 is offline
Old 11-23-2009, 02:21 AM   #4
V8FordTempo
Fan#: 67291
Lightbulb
Will this work?
I suppose I need two of them. (one left and right (not front and rear)
as the driver side is flashing normal with the LEDs only on the passenger side.
http://cgi.ebay.com/ebaymotors/LED-T...Q5fAccessories
Please reply!
Steve M.
Old 11-23-2009, 07:24 AM   #5
05yellowd20
Fan#: 62464
They should work. I assume they do the same thing as the ones i've bought in the past. You can get them at autozone or advance auto maybe pep boys....... but if you'd rather buy em from ebay then yes.
and yes one for each side
Old 11-24-2009, 11:36 PM   #6
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,240, Level 72
Points: 12,240, Level: 72 Points: 12,240, Level: 72 Points: 12,240, Level: 72
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 77 S0C0nFused Excellent Standing Member
The "load equalizers" are the way to go to satisfy the module. As far the the 3157 LED's, there probably bigger than the stock bulbs. The thing about LEDs is that you have to pay attn to not only the lumens but also the angle (some are narrow beam, some are wide beam). regarding the rears, I would think that without benefit of the reflector however they would appear to be very dim as the light is not concentrated/directed towards drivers to your rear. The have to be pretty bright to overcome direct sunlight as an example.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 11-30-2009, 02:17 AM   #7
V8FordTempo
Fan#: 67291
Lightbulb
I got the load equalizers, gonna hook up the front first, since I am putting the blackout headlights in.
The tails are the problem, as the LEDs dont direct the light to the reflector
the tails are dimmer with LEDs than with the regular bulbs...
I found these...
http://cgi.ebay.com/ebaymotors/360-D...Q5fAccessories
360 degree bulbs, is there reflective material all the way from the rear of the lense housing up to the red lense?
would one of these work?
or even the short ones?
Old 11-30-2009, 10:53 AM   #8
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
This is the problem with trying to 'upgrade' from bulbs to LED, the reflectors were made for bulbs. Soooo! In short, I don't know. Bulbs are a single point of light, LED clusters are multiple points dispersed over distance. If the LED clusters are similair in size to the bulbs (and there light output in omni-directional) then I would think they would work. But there as so many variables......
The only way I ever reasoned how to do this using the OE taillight assy is to use 1 (and only 1) of the very new, very expensive, very high intensity LED shining into the reflector (not outward as you would expect). But these LED are (or were?) hard to get (at retail), require a heat sink etc. It might actually be cheaper to purchase aftermarket LED taillights and mod them for durability and longevity (I.E. > IMHO, there cheaply made with no included circuitry to insure they don't burn out prematurely, have consistent output etc). In other words, you got the tail of the dragon, so go ahead and try it and report what you get if your willing.
Old 12-13-2009, 09:04 AM   #9
john m.
john m.'s Avatar
Fan#: 55541
What I Drive: 2008 Focus SES Vista Blue 5 speed
Points 2,016, Level 27
Points: 2,016, Level: 27 Points: 2,016, Level: 27 Points: 2,016, Level: 27
Level Up 11% Completed
FF Reputation: 0 john m. Newbie
nnnn
john m. is offline
Old 12-14-2009, 03:05 AM   #10
uh60james
uh60james's Avatar
Fan#: 6968
What I Drive: 2010 Sterling Grey SE Sedan
FF Reputation: 6 uh60james Good Standing Member
I havent ordered from them yet but this seems to be a pretty good site to get bulbs from. They sell flashers as well as load resistor kits in additon to bulbs. http://www.superbrightleds.com/cgi-b...rn.html#Table2 There is even a small section on the site dedicated to the issues of converting.
Team Duratec #39 / Sedan Revolution #35
uh60james is offline
Tags
bulb , led , light , signal , turn
