2008+ Focus Test Mode - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-18-2009, 07:22 PM   #1
uh60james
uh60james's Avatar
Fan#: 6968
What I Drive: 2010 Sterling Grey SE Sedan
FF Reputation: 6 uh60james Good Standing Member
I know there are already plenty of threads on the Engineering Mode or Test Mode on earlier Foci but I wasn't sure that those of us with the new 3 button system could access it or not, we can.
1. Insert Key into Ignition
2. Press and hold Reset button
3. Start Car (IIRC you didnt have to start it in my previous Focus but I couldnt get it to work without starting this time)
4. Watch for ENGINEERING MODE to Appear on Odometer
5. Release Reset, to Scroll Tap Reset
Some of the info you can get from here can be used by all, some may be usefull for some and some may be absolutely worthless. I may have missed one or two things but I think my list is fairly complete and in order.
1. SWEEP ALL GUAGES
2. TELLTALE TEST (PICTURED ABOVE)
3. PART NUMBER
4. ROM LEVEL
5. NVM ROM LEVEL
6. NVM LEVEL
7. MANUFACTURE TEST DATE
8. MANUFACTURE CONFIG
9. VOPS CONFIG
10. DTCS
11. SPEEDOMETER MPH
12. SPEEDOMETER km/h
13. SPEEDOMETER DC
14. TACHOMETER
15. TACHOMETER DC
16. FUEL LEVEL A/D INPUT
17. FUEL LEVEL FLPS INPUT
18. FUEL LEVEL DC
19. FUEL LEVEL INIT REF
20. FUEL RAFE
21. TEMP GUAGE (COOLANT?)
22. TEMP GUAGE DC
23. FAIL SAFE COOL MODE
24. ODOMETER ROLL COUNT
25. TRIP ODOMETER A
26. TRIP ODOMETER B
27. BATTERY VOLTAGE
28. BATTERY A/D COUNTS
29. RUN/START SENSE
30. DIMMING INPUT
31. DIMMING STEP
32. DOOR AJAR STATUS
33. GEM INFO STATUS
34. ABS INFO STATUS
35. PCM INFO STATUS
36. OIL PRESSURE RA/D
37. MC SWITCH RA/D
38. A/D PORT 0
39. A/D PORT 5
40. A/D PORT 6
41. A/D PORT 7
42. A/D PORT PL2
43. A/D PORT PL3
44. DIGITAL INPUT PORTS E
45. DIGITAL INPUT PORTS L
I highlighted the info I find immediately useful in green.
A few more pics.
uh60james is offline
Old 11-18-2009, 07:38 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Thanks for the info bro, I'll see about getting it added to the sticky since it's a little different. We should probably change the title to "Test Mode" or something else that will will be closer to what people will be looking for.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-18-2009, 07:43 PM   #3
uh60james
uh60james's Avatar
Fan#: 6968
Changed it!
Old 11-18-2009, 07:47 PM   #4
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
Points 3,454, Level 36
Points: 3,454, Level: 36 Points: 3,454, Level: 36 Points: 3,454, Level: 36
Level Up 70% Completed
FF Reputation: 16 arlenn Great Standing Member
that new cluster looks bad-a$$ in the dark!
arlenn is offline
Old 11-18-2009, 07:54 PM   #5
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
good to know. I was wondering if there was one on the 08+
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 11-18-2009, 08:23 PM   #6
jarchie
jarchie's Avatar
Fan#: 51811
What I Drive: 2010 Midnight Black SES 4-Door,
FF Reputation: 5 jarchie Good Standing Member
Very Cool!!
If you can make it go, I can make it go faster.
SEDAN REVOLUTION MEMBER #72 TEAM DURATEC #30
FORD F.A.C.T. INSTRUCTOR, FORD TRAINING CENTER INSTRUCTOR, TECHNICIAN. LOVER & OWNER
jarchie is offline
Old 11-19-2009, 12:04 AM   #7
In Focus
Fan#: 56840
What I Drive: 2009 Silver SES
FF Reputation: 2 In Focus Good Standing Member
Cant get it to work at all in my 09 ses???
what am i doing wrong!!!
In Focus is offline
Old 11-19-2009, 12:40 AM   #8
uh60james
uh60james's Avatar
Fan#: 6968
1. insery key into ignition
2. press and hold reset (do not release)
3. start the car
4. still holding the reset button watch the odomoter to display ENGINEERING MODE
5. release reset once that shows up
6. tap reset to cylcle through the pages
not sure if this will affect it or not but release the parking brake if you have it on and make sure you have more than 50 miles of fuel left. This may not make a difference but the first time I tried it I had the parking brake on and it just showed CHECK BRAKES or something like that.
Old 11-19-2009, 12:56 AM   #9
In Focus
Fan#: 56840
okay so i get in
put the key straight in don't twist it
hold the reset button and start the car
ive done that and nothing happens it says
park brake then goes to tire pressure sensor (cause i have after market rims)
back and forth while im still holding the reset button
In Focus is offline
Old 11-19-2009, 12:59 AM   #10
In Focus
Fan#: 56840
opps
ive had the park break on everytime cause im kinda on a hill
i'll have to try it with out
In Focus is offline
