Noise/Vibration on right turn - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-17-2009, 11:36 PM   #1
mini_racer
Fan#: 68915
What I Drive: 2001 Drk Blue ZX3
FF Reputation: 1 mini_racer Good Standing Member
Ok, so at a slow speed (~15mph) right turn, I get a noise/vibration that sounds like it is coming from the front right wheel, but it is difficult to know for sure. The more the gas pedal application the greater the event.
Same speed and degree of left turn and all feels/sounds solid. I also hear/feel this same thing when going straight and going over a bump.
I have about 90k on the clock with plenty of city miles on my '01 ZX3.
My best guess is the front right wheel bearing is going out, or maybe the drive axle/hub nut is not torqued properly.
Is it possible that the passenger motor mount is bad and causing this when weight is shifted off of it?
ANY VOTES? Thanks for any help!
mini_racer is offline
Old 11-18-2009, 07:35 AM   #2
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
CV joint?
2004 svt focus EAP #658
Former Hatch Nation #08
alex62390 is offline
Old 11-18-2009, 07:41 AM   #3
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Money is in a rotten bearing CV's usually clatter or go click click click when turning
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Old 11-18-2009, 08:27 AM   #4
Esteban
Fan#: 54267
What I Drive: 03 ZX3 5spd
FF Reputation: 1 Esteban Good Standing Member
Find a big empty parking lot & go thru some slow turns with it.. All the way left for a full circle at just a couple mph's , then all the way right. Clicking/clunking, etc., will more than likely show up & will probably be CV joint.
Esteban is offline
Old 11-18-2009, 10:46 AM   #5
LongDucDong
LongDucDong's Avatar
Fan#: 59052
What I Drive: 2003 SVTF 3 door
FF Reputation: 10 LongDucDong Great Standing Member
Well if youre turning right, its your left bearing that is probably bad, as all the weight would be transferred to the left side. It can be difficult to trace the noise, especially when the bearings initially start to wear out. Mine started doing the same thing a few months ago and has progressively gotten worse. At first I thought it was the front right bearing, but as it gets louder over time, I can tell its the left front bearing thats on its way out the door.
"I will cast you down at the foot of the cross He hung from." -For Today
LongDucDong is offline
Old 11-18-2009, 11:22 AM   #6
mini_racer
Fan#: 68915
I do not believe it is a CV joint as the boots look fine, and I do not hear the classic clicking, clunking at all. I am definitely leaning more towards a wheel bearing. I do have a Haynes, but it is not with me at present, are the front wheel bearings crazy hard to replace?
Also, is this one of things that you just replace both sides for good measure?
I do still need to spend a little more parking lot time and try to get a little more precision on the symptoms.
Old 11-18-2009, 01:01 PM   #7
Gremage
Fan#: 70476
What I Drive: 04, metallic grey, 1.6 3dr Flight
FF Reputation: 1 Gremage Good Standing Member
I doubt it's a bearing, bearings get noisier at higher speeds and still make a noise when going in a straight line, they also get louder depending which way you turn
Probably a cv joint
Gremage is offline
Old 11-18-2009, 02:14 PM   #8
LongDucDong
Fan#: 59052
Probably a cv joint
Well, his car gets louder with more acceleration and makes more noise when turning right. Not all bad bearings make noise while going in a straight line. Mine only makes noise when turning right because the load is on the left bearing. Once the wheel is straightened out, its virtually inaudible.
Old 11-18-2009, 02:53 PM   #9
mini_racer
Fan#: 68915
I thought CV joints typically or maybe always made that clicking noise when they go bad. Maybe cars or rather different CV joint/half-shaft designs are different though, I am not sure.
And yes it does get louder with more acceleration and more speed while turning right, 0 - 30mph. above 30mph turns will tend to be more gradual. Left turns are fine at any speed or acceleration.
The second symptom is that is also makes noise while going straight at the low point of a bump or dip, when there is maximum weight momentarily in the front, as the suspension is compressing. I do not get the feeling that this is suspension related though.
Old 11-18-2009, 05:58 PM   #10
91Sickness
91Sickness's Avatar
Fan#: 59174
What I Drive: 2003 Metallic Grey Se 2.0 Zetec
FF Reputation: 2 91Sickness Good Standing Member
my syntoms are the same but it also does it in park when i start it in the morning when the car is cold, and it fades away after 5 or 10 miles of driving
03 Focus Dark Shadow Metallic Grey SE 2.0L Zetec
Sedan Revolution
Zetec Crew
91Sickness is offline
