MT removal, clutch slave cylinder and clutch replacement - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-21-2012, 01:54 AM   #21
blueoval23
Fan#: 46630
What I Drive: 2004 Silver ZX3
FF Reputation: 10 blueoval23 Great Standing Member
Update 1, put in Exedy stage 1 clutch:
http://www.focusfanatics.com/forum/showthread.php?t=245226
Update 2, removed the transmission AGAIN. Short story: Vibration noise led to believe trans was shot. Long story:
http://www.focusfanatics.com/forum/s...46#post4175046
Having now taken the transmission out of this car 3 times I thought I'd post a few helpful things I've learned. The main tip is to loosen the crossmember until its about to fall out. I've read of people removing it but to do that you have to disconnect the steering rack.
I removed all but 1 bolt on the passenger side and it was loose, like 2 threads hanging
I removed all the bolts on the driver side (the bolts you see are for the A-arm, not holding the crossmember to the chassis)
This shows how far the crossmember drops away from the car
This shows how much the steering rack has moved down
Remove the tow hook thingy in the front on the drivers side
With the crossmember super loose you can push it towards the back of the car 3-4" which gives you a bunch more room to swing the transmission when removing and re-installing.
Also, in case you were wondering, the inside of your MTX75 looks like this
Happy wrenching!
2004 silver ZX3, Focus Sport stealth exhaust.
1990 Bronco, custom almost everything.
Under Construction 4x4 - www.uc4x4.com
blueoval23 is offline
Old 08-22-2013, 11:30 PM   #22
2006FocusST
Fan#: 116557
What I Drive: 2006 Black ZX4 ST
FF Reputation: 1 2006FocusST Good Standing Member
So my friend accidentally pulled the tri ball thing apart, and i am unsure how to put it back together. Any help?
2006FocusST is offline
