spi valve adjustment - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2009, 01:01 AM   #1
brencklf
Fan#: 69731
What I Drive: 2000, white focus
FF Reputation: 1 brencklf Good Standing Member
I had the usual valve drop on my 2000 focus 2.0 sohc. Had the blocked sleaved and new valve seats installed at the machine shop. Installed new rings, gaskes and motor mounts. Motor is running really well except for a slight valve tapping at lower RPMs. I'd like to do a valve adjustment, but the Haynes manual doesn't do a real good job explaining how to adjust, just how to check the clearance. It mentions hydraulic lifters? Is the 2.0 spi valves self adjusting? If not, how can I adjust the valves or is there another reason for the tapping?
Thanks
brencklf is offline
Old 10-24-2009, 07:27 AM   #2
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Buy-Sell-Trade Rating: (4)
AFAIK there isn't a valve adjustment procedure because.....they aren't adjustable. But you had already guessed that.
A 'little' tapping is normal, these motors have always been said to have a noisy valve train. Mine has made a 'little' tapping ever since I've owned it (40k to 170k miles)
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
Old 10-24-2009, 09:41 AM   #3
brencklf
Fan#: 69731
Thank you Focusnewb, I won't worry about then. Hopefully I'll get another 100,000 miles out of her.
brencklf is offline
Old 10-24-2009, 04:03 PM   #4
NAD23ZX3
Fan#: 59327
What I Drive: 2004 Red Zx3
FF Reputation: 9 NAD23ZX3 Good Standing Member
Did you store the buckets in oil while you did the rebuild? If not, you got air in them hence the tapping noise. Try idling it at 2k for a little bit. They should bleed down and be good after that. If the tapping doesn't go away (not sure on the spi, but the duratec always has some slight noise) you need to buy new ones.
NAD23ZX3 is offline
