Driver's door won't open!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-23-2009, 09:16 PM   #1
djblackout
djblackout's Avatar
Fan#: 61433
What I Drive: 02 sonic blue SVTF
Points 11,427, Level 70
Points: 11,427, Level: 70 Points: 11,427, Level: 70 Points: 11,427, Level: 70
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 11 djblackout Great Standing Member
I can pull on the handle and it comes all the way out and stays out.
Im comfortable with taking off the panels and lookin & fixin. Has anyone had this problem, and how do i fix it?
Ive noticed my door handle has been acting a little funny lately with it not going down flush after opening the door, but it was only a minimal thing. it didnt stay out lol
can someone fix the title? I meant driver door wont open....im sure you can tell how stressed i am lol
02 SVTF
djblackout is offline
Old 10-23-2009, 09:24 PM   #2
djblackout
djblackout's Avatar
Fan#: 61433
thanks to whoever fixed the title <3
02 SVTF
Old 10-23-2009, 09:27 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
There's the fix. No need to shout- there will be plenty of that later.
Are you able to open the door from either side of the door? If one side won't open, but the other will, then the problem is likely to be the rod that connects to the latch pull itself.
If it won't open from either side- you should start searching local junkyards for a correctly colored replacement panel now. Look at your passenger side to see what you're up against. You'll likely have to remove the driver's seat to get good access to the whole panel and make it easier to work on. That won't be any fun either, but take your time, think about it, and you can get it out without damaging it or anything else. You might have some luck if you're able to remove the trim on the pillar in the rear, but I don't think there's any way to save destroying the front side of the panel.
Once you get the panel off, then you should be able to tell what the problem is.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-23-2009, 09:28 PM   #4
djblackout
djblackout's Avatar
Fan#: 61433
it opens from the inside
im not sure what youre telling me to remove. I have a hatch not a sedan.. why remove the driver seat? and pillar trim?
02 SVTF
Old 10-23-2009, 10:14 PM   #5
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Buy-Sell-Trade Rating: (4)
Well then, you can skip all the words after "If it won't open from either side"
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
Old 10-23-2009, 10:22 PM   #6
djblackout
djblackout's Avatar
Fan#: 61433
so i was lookin on the inside. it looks like that metal lever that connects to the rod doesnt go back up after the door opens.
like I can push it up and it feels fine opening it, but once I let go, the rod doesnt extend back up.
what can alleviate this?
02 SVTF
Old 10-23-2009, 10:57 PM   #7
Focusnewb
Focusnewb's Avatar
Fan#: 27975
I haven't been inside a Focus door but assuming all the parts are there (I would be looking for some sort of missing return spring from your description) then lubricate all of the friction areas and see if that helps.
If you can see a hole or hook for a spring with no spring in it, or better yet, look for pieces of it in the inside bottom of the door, just get another to replace it and it should take care of you.
Old 10-23-2009, 11:09 PM   #8
djblackout
djblackout's Avatar
Fan#: 61433
If you guys experience this problem, go get some spray white lithium grease.
soak the crap out of the hinge that holds the rod. I even sprayed some on the inside of the door by where the latch is. then play with your door handle over and over
problem solved.
02 SVTF
Old 10-25-2009, 08:48 AM   #9
ssvhto72
Fan#: 65145
What I Drive: 03, CD silver SVTFocus
FF Reputation: 1 ssvhto72 Good Standing Member
I had this happen, would not open from outside but would open on the inside. what I did was I took the door apart from the inside and I looked at the outside door handle from the inside, saw that a plastic piece was missing from the linkage rod. so the rod would not stay in the hole on the opening mechanism. I later found the little plastic piece that goes on the linkage rod at the bottom of the door.
ssvhto72 is offline
Old 10-31-2009, 10:18 AM   #10
lduran
lduran's Avatar
Fan#: 18554
What I Drive: '02 ZX5
Points 2,853, Level 32
Points: 2,853, Level: 32 Points: 2,853, Level: 32 Points: 2,853, Level: 32
Level Up 69% Completed
FF Reputation: 1 lduran Good Standing Member
Buy-Sell-Trade Rating: (6)
I have been looking for a fix for when the door won't open from either side. My rear passenger's side door won't open at all and the automatic door lock does not move when all the other doors are locked or unlocked. I guess I am going to have to cut the panel off. I was hoping others had experienced this problem and found a better fix than cutting it off, but looks like I am SOL!
2002 Sangria Red ZX5 with ABS, Moonroof, K&N Air Charger, Borla Cat-back exhaust, Edelbrock header, Random Tech Cat, Bosal Flexpipe, Magnaflow Resonator, SVT Suspension, Auto tranny
lduran is offline
