Downstream o2 Sensor Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-18-2009, 02:47 PM   #1
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
My question is this - does the downstream o2 sensor have any bearing on how the car times itself? I just installed a high flow cat, but I know my old downstream sensor is bad. I plugged the hole in the new cat where the second o2 sensor would go, and simply unplugged the harness for it.
Now I'm running WAY rich (~180 miles on this tank of gas...), but only at times. I'm getting a CEL for the second o2 sensor, which is to be expected. However, I always thought that only the first o2 sensor was used for air/fuel adjustments, which makes me wonder why I'm getting the misfire, as the first sensor is still there. I thought the front sensor may have gotten damaged, but I'm only getting a CEL for the downstream one, not for the front.
Can unplugging the downstream o2 throw the computer off that much? Figured I'd get a better chance of a reply here than in the tech chat.
svtguy88 is offline
Old 10-18-2009, 03:15 PM   #2
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,460, Level 75
Points: 13,460, Level: 75 Points: 13,460, Level: 75 Points: 13,460, Level: 75
Level Up 53% Completed
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
I would assume that if its not tuned to run just the one, then yeah it will throw it off, but I am not really sure.
04 ZX3 Mostly Stock ["Best Non-SVT" FITF '12][3/13 ROTM][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 10-18-2009, 07:57 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,496, Level 100
Points: 52,496, Level: 100 Points: 52,496, Level: 100 Points: 52,496, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
No the rear o2 even unplugged wont have anything to do with engine running or performance
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 10-18-2009, 10:18 PM   #4
svtguy88
svtguy88's Avatar
Fan#: 13476
...hmm. Well now I'm at a loss as to where to look to find the root of my problem. Thanks for the reply Tom.
svtguy88 is offline
Old 10-22-2009, 06:36 PM   #5
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
What I Drive: '02 Sonic Blue SVT Focus, '03 Wagon
Points 5,296, Level 46
Points: 5,296, Level: 46 Points: 5,296, Level: 46 Points: 5,296, Level: 46
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 34 WuNgUnSVT Great Standing Member
The car is probably going into 'Open Loop, fault' mode because of this...in which case, it runs off a 'safe' AFR (very rich)...which is why your mileage sux.
I had Open Loop, fault issues from running a ristrictive MAF housing, and my mileage also sucked.
Originally Posted by MattyKrackSVT View Post
...go threw your posts and see who can't spell retard...
WuNgUnSVT is online now
Old 10-22-2009, 07:02 PM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
The rear o2 does nothing to cause it to go open loop
I would see what the front o2 is doing among other things , do you have a way to log things ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 10-22-2009, 08:04 PM   #7
svtguy88
svtguy88's Avatar
Fan#: 13476
I own an Xcal II, but haven't played with the datalogging at all. I suspected the front o2, but I would have thought a CEL for it would have gone on.
Anyway, I pulled the front sensor and cleaned it, following some tutorials that a Google quest gave me. My problem is gone...at least for the most part. It goes back to the old problem (only not *quite* as severe. Before it would almost die, now when it comes back, it's not nearly that bad) at times, but seems to clear up after a little while (1-2 minutes at most).
My assumption is the front oxygen sensor really does need to be replaced, as from what I have read, no level of cleaning can completely dissolve the carbon deposits that build up on the sensor.
The next time I get a chance to grab my Xcal from home, I"ll see what I can get it to tell me.
svtguy88 is offline
Old 10-22-2009, 08:50 PM   #8
boostedsvtf
boostedsvtf's Avatar
Fan#: 68495
What I Drive: 04 CD Silver SVT 5-Door
Points 747, Level 14
Points: 747, Level: 14 Points: 747, Level: 14 Points: 747, Level: 14
Level Up 47% Completed
FF Reputation: 1 boostedsvtf Good Standing Member
does the second o2 throw cel if its unplugged?
boostedsvtf is offline
Old 10-22-2009, 09:42 PM   #9
calvin1234
calvin1234's Avatar
Fan#: 67836
What I Drive: 09 Vista Blue SE Sedan & 99 Tracker
FF Reputation: 8 calvin1234 Good Standing Member
Yes and it will cause the car to go rich (open loop). Back in the day it wouldn't because it only monitored the cat, but now the computer will very briefly fluctuate between rich and lean once per drive cycle to check both front and rear and if it gets contradictory results a certain number of drive cycles in a row it will go to open loop.
The important thing to remember is that today's OBD systems are so complex that you can't unplug one sensor and not have it screw at least one other thing up.
"You will be assimilated, resistance is futile"
Give a rep when someone is helpful
calvin1234 is offline
Old 10-22-2009, 09:53 PM   #10
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
FOR THE LAST TIME THE SECOND O2 HAS NOTHING TO DO WITH IT GOING INTO OPEN LOOP!!!!
The Second O2 sensors ONLY job is to determine the efficentcy of the CAT NOTHING ELSE.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
