ABS sensor test with meter? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2009, 09:01 PM   #1
boatingfool
Fan#: 69193
What I Drive: 2002 Red Focus SVT
Points 923, Level 16
Points: 923, Level: 16 Points: 923, Level: 16 Points: 923, Level: 16
Level Up 23% Completed
FF Reputation: 1 boatingfool Good Standing Member
My Haynes manual states I can check my ABS sensors with a volt meter by connecting the meter, reading VAC and spinning the wheel. Either this is bogus or I have 4 bad sensor/wheel bearings.
I recently replaced all 4 wheel bearings and I have the ABS light. See other post.
http://www.focusfanatics.com/forum/showthread.php?t=212910
Thanks for any info
Vincent
boatingfool is offline
Old 10-09-2009, 09:27 PM   #2
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
What I Drive: '05 CD silver ZX3 ST
FF Reputation: 77 roosterst Excellent Standing Member
Buy-Sell-Trade Rating: (14)
How fast are you spinning the wheel? Was the ABS light on before replacing the bearings?
FR valvebody, 91 tune = 16.296 @ 84.08mph
roosterst is offline
Old 10-09-2009, 09:39 PM   #3
boatingfool
Fan#: 69193
I don't know the exact speed I was spinning, but it was by hand and pretty fast. The meter didn't budge. I tried the left front which is a new bearing (black ring inboard towards sensor) and on the right rear wheel which the bearing and hub was purchased preassembled from Ford (Trousley). Spinning by hand with the wheel installed as fast as I can and the meter didn't change.
If I read for ohms across the sensor, I only get a reading if I put the probes on a particular way, almost like it is a diode.
The ABS light wasn't on before I started the project. I removed/inspected all 4 sensors, installed, no visual damage. I checked all 4 connectors, connected.
I drove the vehicle after replacement. I tried disconnecting the battery before, but it didn't didn't reset. I tried again tonight, but nothing.
Vincent
Old 10-09-2009, 09:46 PM   #4
jarchie
jarchie's Avatar
Fan#: 51811
What I Drive: 2010 Midnight Black SES 4-Door,
FF Reputation: 5 jarchie Good Standing Member
Send me your OHM readings. Do you have traction control? They use a different kind of sensor that will not produce voltage readings. pm me and I will try to help.
If you can make it go, I can make it go faster.
SEDAN REVOLUTION MEMBER #72 TEAM DURATEC #30
FORD F.A.C.T. INSTRUCTOR, FORD TRAINING CENTER INSTRUCTOR, TECHNICIAN. LOVER & OWNER
jarchie is offline
Old 10-09-2009, 09:46 PM   #5
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
Can you measure how big the gap is between the tone rings, and the sensors?
Old 10-09-2009, 09:49 PM   #6
jarchie
jarchie's Avatar
Fan#: 51811
By the way, on parts like these, i always go OEM.
jarchie is offline
Old 10-09-2009, 10:18 PM   #7
boatingfool
Fan#: 69193
The car does not have traction control.
The front wheel sensors read 3.625mohms/3.680mohms. I don't remember what the rears were and I just cleaned up for the night (frustrated) .
I will check the rears tomorrow.
Again, I am only able to ohm the sensor if I have the test leads oriented one direction. If you reverse the leads, it reads open.
Thanks for the help.
Vincent
Oh, the front bearings were CFM but Ford OEM. The 2nd set of front I have to install were purchased from Trousley and are the same exact ones. I checked the black ring and it has a slight magnetic field. I removed the driver's side sensor and placed a ferrous tool (Snap on pick) and the wheel sensor ring pulls at the pick.
Old 10-10-2009, 10:11 AM   #8
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
Hall-effect sensors can't be tested the same way the older-technology tone-ring (relucator) and coil systems can be tested with a volt meter. I get zero volts on my voltmeter from all four of my ZTS's sensors while spinning the wheels (fast) (w ABS & traction) and both systems work fine.
drjkel is offline
Old 10-10-2009, 04:18 PM   #9
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Well, it also depends on the sensitivity of your meter. What AC range is it set to?
And, as someone said, if it is a hall effect sensor, rather than an inductive pickup type, the AC voltmeter test probably will not work.
I don't know which type the Focus uses, hall effect or inductive coil.
penguin is offline
Old 10-10-2009, 10:16 PM   #10
jarchie
jarchie's Avatar
Fan#: 51811
At Ford, we refer to them as Active and Passive. Passive sensors are tested with an OHM meter and can be tested to see if they produce AC voltave (in milivolts) and Active require a 12V power source and are tested in AMPS. Your meter has to be wired in series with the negitive lead from the sensor to the module and the positive wire has to be complete with the key on. The signal should toggle from 7mA to 14mA. If you are in Charlotte NC week after next, I am teaching Advanced Brakes.
jarchie is offline
