Replacing battery cables - Focus Fanatics
Old 10-09-2009, 05:17 PM   #1
norge01
Fan#: 69572
What I Drive: 2003 white 4 dr sedan
FF Reputation: 1 norge01 Good Standing Member
Hi, this is my first posting. My son got a $500 quote from a dealer to replace his battery cables. Can that be correct? How hard is it to replace them? Is there an easy way to do it? It's a 2003 4dr sedan.
Where can I get some step by step instructions? i
norge01 is offline
Old 10-09-2009, 05:22 PM   #2
norge01
Fan#: 69572
Help for replacing battery cables
My son has a simple 2003 4 dr sedan. A dealer gave him a $500 quote to replace his battery cables. That seems crazy. I'm new to this forum. Where can I get instructions on how to do it? Hopefully there is some sort of simple electrical harness I can plug them into. Any advice?
norge01 is offline
Old 10-09-2009, 05:37 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
It's easy to do and doesn't take long. Majority of that quote is the cost of the cables. The positive cable is out of this world high. Maybe $100 of the quote is the actual labor.
I'd say go through the cable and test resistances first and make sure it in fact needs replacing. Maybe you'll get lucky and just the ground is bad. Who knows.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is online now
Old 10-09-2009, 05:43 PM   #4
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
FF Reputation: 2 streetfocus Good Standing Member
I thought it was just bolt them in to the ground/block. Seems pretty simple. The Moderators are going to move this thread to the proper area (Zetec performance chat?). Welcome to the Forums, they're great for help!
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
Old 10-09-2009, 06:53 PM   #5
greddy339
Fan#: 63304
What I Drive: 2k ford focus zx3
FF Reputation: 9 greddy339 Good Standing Member
cost $100 bucks from the stealership..
pretty straightfoward install..what i did was start by disconneting both neg/pos posts..
it's easier to have the car on ramps to have access to the bottom...
step 1.
put new pos/neg post beside old one..but don't put them on!
2. get underneath and you will see the red wire is the power wire to the alternator..put that on..
3. there is a starter block..with 2 connections..have to take off the 2 bolts off that holds it to the starter..you will see it on the new one..put that on
4. now put the small black ground that is in a black box on..it's right beside the starter block you just put on..next goes the small black wire that is a ground that is hooked to the fenderwell..then there is a black connector..can't remember off hand where that goes..but just follow the old one and you will find it..
greddy339 is offline
Old 10-09-2009, 09:54 PM   #6
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
FF Reputation: 34 tukaniSVT Great Standing Member
Welcome to the site ... I will move this to the right spot of the forum so that you can have lots more help then just to the help of our region.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 10-09-2009, 10:00 PM   #7
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
Oh and here's a link for what I found ...
http://www.ehow.com/how_4507669_repl...ord-focus.html
It should be pretty simple ... If I remember correctly there are zipties and plastic ties keeping it where it is. Just follow the cables and you should be able to take the old ones off and then reverse the procedure for the new ones.
Good Luck.
-Ray-
Old 10-09-2009, 10:06 PM   #8
hardSVT
Turbo Freak
hardSVT's Avatar
Fan#: 53566
What I Drive: 03 svtf
FF Reputation: 5 hardSVT Good Standing Member
Buy-Sell-Trade Rating: (7)
its pretty simple if u have small hands, the hardest part is getting the 2 bolts of the back of the starter, then u have a ground and the rest of the wire connects to the back of the alti
RIP SVT
300hp mazdaspeed3
Rocco's built turbo zetec mine now!
hardSVT is offline
Old 10-09-2009, 10:13 PM   #9
Ricochet
Ricochet's Avatar
Fan#: 60300
What I Drive: 2004 Focus SE
FF Reputation: 2 Ricochet Good Standing Member
Ive never replaced tehm in my Focus, but I did replace them in my Nissan Xterra and it took about 25 minutes.
I cant see any reason why it would cost $500!
Check elsewhere because thats insane.
Ricochet is offline
Old 10-10-2009, 09:40 AM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
You can purchase OEM cables for the main hot and main ground from any parts store. The cost should be around $30 for both. The main hot goes to the starter, the main ground goes to the block. Installation is the reverse of removal. I would suggest using some blue thread lock on the ground connection to the block. You'll likely need to remove the battery from the vehicle as well as the air cleaner in order to gain enough access to reach in there, and you might need to jack the vehicle.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
