ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#1 | ||||
anyone out there tuned w/o a j&s
I know its not wise but I really don't wanna shell out over 500 bucks for it. anyone out there done it sucessfully.
Remove Advertisements |
Fan#: 1
#2 | ||||
Yes. but at lower boost & power levels with a consertvative tune.
Current ride 2000 mustang gt Built motor and on the bottle. My former car. 04 focus 2.3 Duratec turbo. C Wifes Car 03 ZTS focus ATX W/ E&S Turbo Systems Powered!!! |
#3 | ||||
Shot me 3 deer!!!
sure, any dyno shop can do it for you.
Group buy, CARBON FIBER bezels till July 28 check in the Group buy section! Owner of Custom Carbon! PM me w/ CF needs! |
#4 | ||||
Token Engin-nerd
I am tuning without any knock control (sensor turned off due to jibberish) and its going well, just have to keep tabs on it until I get the cold weather spark addition worked out.
http://www.focusfanatics.com/forum/showthread.php?t=207523 A lot of people are skeptical about this but I assure you it is working great for me and the 4 other Focus owners that have tried it to my knowledge (including 1 SVT)
#5 | ||||
Yeah, it's definitely doable seeing that some cars don't even have knock sensors. The thing I like about the J&S is I don't have to do anything...it does it all for me
1992 Eagle Talon TSi - sold (POS) 2002 Mustang GT - sold 2002 SVTF - sold 2008.5 Mazdaspeed3 GT - cursed 2003 350Z Track - basically stock, and it runs |
#6 | ||||
omn-nom-nomnomnomnom
The J&S doesn't quite do EVERYTHING for you. The J&S is better than nothing, but you can definitely hear knock before the J&S will detect it.
I'm the SVT owner/tuner illinipo mentioned. I started off using both a datalogged J&S and the "listening to the knock sensor" method, and wound up selling the J&S because I deemed it an unnecessary expense. With that said, I still understand why guys like Tom insist their customers use a J&S. Datalogging knock is a necessity for remote tuning a boosted SVTF, and AFAIK the J&S is still the only way to do that. Here's a thread about my tuning/datalogging setup... http://www.focusfanatics.com/forum/showthread.php?t=207339
SCT PRP FTMFW! |
#7 | ||||
I've had my S/C tuned without since I've had it for nearly 60K miles although I have a pretty conservative tune. I know it's not technically the safest way of doing thing and if I had higher a boost application like 10psi+ with a turbo or Procharger I would def have one.
Are you talking being tuned N/A without J/S? If so it's perfectly safe.
02 Jackson Racing supercharged SVT SOLD Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler |
#8 | ||||
FF Affiliate
Ill say it again, I have been playing with the J&S vs listening to it and have found some issues that are not the same car to car , I am not through playing with this method but do not at this time trust it enough to do boost with it just yet , Keep in mind that what you hear is AFTER the sensivity adjustment through the ECU that has proven to be incorrectly set on the SVT and if you have a ZX3 that the KS isnt working on then that alone tells you there is already issues with the readings the KS is sending the ECU and what your hearing , if the sensivity is wrong then what your hearing is wrong as well , to low of timing can be as bad as to much timing
There is other ways I am backing up is the timing I am taking out from what I hear +/- HP/TQ , I can remove timing from what I hear and I loose power and if you have knock and take out the right amount of timing there should be no power loss and there is Im just saying this hasent fully been tested and from what I am seeing so far there is no way I would trust this over a J&S at this time , I feel the issue with the Focus is the sensivity adjustment (all 4 cyl have there own sensivity/gain setting) and most out there dont have the ability to adjust this setting , This setting needs to be correctly set before any readings ,logs , listening to should be done And no you cant hear it faster then the J&S can respond to it , you have to have knock to get a response from the J&S once it hears it its gone either that or you can think faster then the next time the piston can come to the top of the cyl and altho you are a smart guy your not that fast , you would hear the same even if your KS was working properly , you have to have knock to activate the knock sensor The BIG downfall to the listening for knock tuning is ? Are you going to ride around all day every day every tank of tuel every time you make boost to see if you have got bad gas , info from sensors that can cause knock at any time , and a large number of other things that will cause knock NO your not , BUT the J&S will do this for you , take out a safe amount of timing and let you know it is doing it SAFELY I understand you dont have the funds for a 500.00 J&S , do you have 1500-2000 for a new engine ? My o2 Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#9 | ||||
The Librarian
MOVED to "Forced Induction Chat"
^^^Since I'm assuming, it's for this: SPA turbo kit still in progress
WD40 Reverend GripShift - FF Moderator Member's Rules and Signature Guidelines Member FAQ and Information Archive Complete 'How To' Archive Complete Acronym/Abbreviaton and Forum Terminology List |
#10 | |||||
Token Engin-nerd
Overall, Tom makes a lot of good points here and like we have both said this method is not for everyone.
| Thread Tools | |
| Display Modes | |
