Duratec Intake Manifold Removal and PCV hose replacement - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-01-2011, 04:24 PM   #71
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,240, Level 72
Points: 12,240, Level: 72 Points: 12,240, Level: 72 Points: 12,240, Level: 72
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 77 S0C0nFused Excellent Standing Member
My thought was to run a metal pipe either to atmosphere or a catch-can. I think it would be to tight a fit for a PCV to intake setup (good pics btw!).
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 12-01-2011, 07:06 PM   #72
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,797, Level 100
Points: 51,797, Level: 100 Points: 51,797, Level: 100 Points: 51,797, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
You would have no issues doing this , In my opinion on anything performance the PCV SHOULD NOT be going back to the intake anyway and the valve cover breather should not as well , vent them both
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 07-05-2012, 08:37 PM   #73
bamakodaker
bamakodaker's Avatar
Fan#: 30132
What I Drive: 2005 Tweety Bird Yellow ZX3
FF Reputation: 1 bamakodaker Good Standing Member
blasted problem
I am STOPPED at being unable to remove the dipstick tube from where it's attached to the intake manifold with a 4.5 mm hex screw. I have FINALLY found a 4.5 hex wrench but the screw will NOT budge!!! I'm afraid of stripping it out! Any suggestions??
Much thanks,
bamakodaker
bamakodaker is offline
Old 07-06-2012, 08:45 AM   #74
exploring/carolina
exploring/carolina's Avatar
Fan#: 84418
What I Drive: 2004 White ZX3
Points 169, Level 3
Points: 169, Level: 3 Points: 169, Level: 3 Points: 169, Level: 3
Level Up 38% Completed
FF Reputation: 5 exploring/carolina Good Standing Member
Always hate rounded off nuts/bolts/allen head bolts and take care to prevent that when possible.
I am sure there are other ways, but when I run into a stripped allen head or rounded bolt head, I drill the bolt head out using a drill bit the same diameter as the threaded portion of the bolt. You may have a tough time getting a drill in the tight space to drill out the allen head. The radiator may have to be removed and if there is still not enough room a 90 degree angle drill head would need to be used. Only drill the depth of the allen "head" & not into the threads. Once finished drilling, remove the drill bit from the drill and use the other end of the bit to snap out the bolt head out. The dip stick can then be removed and use a small punch with a sharp point to back out the bolt.
Bill
2004 ZX3 2.3L 5 speed-Sold
exploring/carolina is offline
Old 09-10-2012, 09:34 AM   #75
plapinta
Fan#: 16093
What I Drive: 2004 red ZX5
FF Reputation: 1 plapinta Good Standing Member
I removed the intake manifold of my 2004 ZX5 2.3 in order to replace the PCV hose. The IM is coated with a wet carbon gunk, what should I ise to clean it and how?
Thanks
Paul
plapinta is offline
Old 09-10-2012, 09:49 AM   #76
SilverST05
SilverST05's Avatar
Fan#: 103209
What I Drive: 2005 Silver Frost ST
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 SilverST05 Good Standing Member
Thanks
Paul
Any carb/choke cleaner should work. Or 3M has a really good throttle plate & carb cleaner. P/N 8866. $7 a $8 at O'Reillys or other parts stores. It works really really good. I use it all the time to clean the throttle plate in the throttle bodies.
2005 ZX4 ST, Stealth CAI (so far)
Used to have, and will always regret selling, 1970 Mach 1.
"Everday is a good day, just try missing one."
"As soon as we're born we start dying, so you might as well have a good time."
SilverST05 is offline
Old 09-10-2012, 09:06 PM   #77
plapinta
Fan#: 16093
Thanks for the quick reply. I bought two cans at a local CarQuest retailer, it seems to work pretty good. I do have lots of carbon buildup above the valves, that's not coming off.
BTW, I was able to easily remove the PCV valve from it's cover. With the cover off of the car I could use a needle nose pliers to grab and squeeze the locking ring at the two notches and turn counterclockwise, it came right off.
Thanks again.
plapinta is offline
Old 09-10-2012, 09:11 PM   #78
SilverST05
SilverST05's Avatar
Fan#: 103209
Points 325, Level 6
Thanks again.
Nice to hear it. That's a project I will need to do in the near future.
Old 09-17-2012, 08:40 AM   #79
plapinta
Fan#: 16093
I was able to put everything back together and the car is running much better, no CEL! A couple of things when you reassemble:
Insert the hidden bolt first.
There's a vacuum hose from the fuel injection rail that snakes it's way through the IM and plugs into the IM from below, not easy to see except from under the car with a flashlight.
I accidently broke the electrical connecto on the idle control valve, had to buy a new one for $54 from AutoZone, be careful with that connector.
plapinta is offline
Old 09-17-2012, 09:59 AM   #80
SilverST05
SilverST05's Avatar
Fan#: 103209
Points 325, Level 6
Thanks for the tips. Those connectors seem to get brittle. I broke a coil connector changing the plugs. Luckily I work in auto parts where I have a discount. O o o O'Reilly...
