Duratec Intake Manifold Removal and PCV hose replacement - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-05-2010, 04:23 PM   #31
crazyjess
Fan#: 46890
What I Drive: 2004 light-tundra zx3
Points 1,169, Level 18
Points: 1,169, Level: 18 Points: 1,169, Level: 18 Points: 1,169, Level: 18
Level Up 69% Completed
FF Reputation: 2 crazyjess Good Standing Member
anyone?
crazyjess is online now
Old 12-11-2010, 02:39 AM   #32
Fredness
Fan#: 26710
What I Drive: 2005 Cloud White ZX3
FF Reputation: 7 Fredness Good Standing Member
Rock Auto had the hose for 1/3 of what Ford wanted.
'05 ZX3 ("S") Team Duratec #56
Engine: Modified MBRP Stainless Exhaust, K&N AirCharger, SCT LiveWire (dealer), ScanGauge, poly "dogbone" bushings.
Stereo: '05 Mustang Shaker500 H/U, Polk DB570's and an Infinity BassLink SubWoofer.
Fredness is offline
Old 12-11-2010, 09:22 AM   #33
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,240, Level 72
Points: 12,240, Level: 72 Points: 12,240, Level: 72 Points: 12,240, Level: 72
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 77 S0C0nFused Excellent Standing Member
So! what is inside the PCV valve? (the "black box"). I always thought PCV was just a hose from the crankcase to the intake to relieve pressure buildup. Not getting the "valve" part.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 12-11-2010, 11:40 AM   #34
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
I never knew the EGR port was so huge on these intakes.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 12-11-2010, 11:57 AM   #35
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
What you need to figure it out is to play around with an old PCV valve like a Zetec or V8 valve. If you suck on the hose side, you'll pull the little stopper up, if you blow on it, the stopper will go down and you can't blow through it. When it's bad, you can blow through it. The PCV is connected to engine vacuum after the TB. The oil breather (valve cover connection) is connected in front of the TB in the air intake.
The PCV opens when vacuum is high, and the oil breather works when air intake flow is high. Both of them suck oil smoke/misty oil back into the engine to be burned up.
Go read up on Wiki about it, and you'll find the automotive history behind why modern PCV and oil breather are routed back through the engine. It's for emissions. Yeah, you don't need it to run, but if we didn't have it- we'd be wearing face masks like people in Hong Kong on high pollution days. If anyone wants to see what the USA would be like without EPA and eco-terrorists, keep an eye on China over the next 10 years or so. I'll have to go check, but I think their air pollution is already higher than ours was in the early 70s.
Be eclectic.
Old 12-11-2010, 06:31 PM   #36
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
I took whynotthinkwhynot suggestion and read-up on the PCV system. I sounds like the long term solution is to move the PCV valve out from under the intake and use an oil separator (if you so choose) to extract the oil before it gets to the intake. Also, tap a new hole in the intake in a more human friendly spot. Can the stock PCV valve be gutted (remove the internal valving)?
This should be 100% legal as were not dumping anything to atmosphere. Were simply relocating the PCV, and extracting the oil component so as not to gunk up the intake internals (as fast).
Old 07-27-2011, 09:45 AM   #37
evoasis
Fan#: 24497
What I Drive: 2005 zx3
FF Reputation: 1 evoasis Good Standing Member
Quick note: Removal of radiator or dropping it, is not needed. With all 1/4" drive tools I was able to remove the hidden bolt without needing to even remove the grill.. Got some super long 20"+ extensions from Harbor Freight for less than 10.00 too. Also, having universals or flex socket adapters makes this task much easier. Thankyou for the writeup though!!!
evoasis is offline
Old 09-10-2011, 04:33 PM   #38
autofocus1
Fan#: 89743
What I Drive: 2004 focus se
FF Reputation: 1 autofocus1 Good Standing Member
pvc hose
I found this very helpful in replacing the PVC hose.
1 shortcut to save some time.
i used 2 3" extensions and i was able to reach the center intake bolt without removing the radiator
autofocus1 is offline
Old 09-10-2011, 05:28 PM   #39
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
Originally Posted by warneej View Post
Then using a cap (such as a radiator bypass cap, which come in a multi-pack at your local autoparts store in the HELP! section, use one here and another on the intake tube. I didn't need clamps as they fit snugly but you make the call):
Some of the wording is confusing for my pea brain. When you say using a cap put it here and another on the intake tube. You mean the cold air intake tube?
Not on the intake manifold? I only plugged one hole on my intake MANIFOLD.
This one im not sure i get as well. When i deleted mine, i bought a new PCV valve and i cut the end off and let all the springs and valve fall out. So now its just an OPEN elbow. I then put a hose on the PCV elbow and ran that down to the ground. I left my top like it was hooked to the intake to filter the crankcase vent. The top is the vent IN, the PCV is the pressure OUT right?
Also when you say its bad you can blow threw it? Tom said that if you just gut the PCV and leave it as an open vent to the ground its fine. I figured removing all the springs and valve will prevent it from ever clogging and failing.
And by capping the back of the intake you dont have to worry about it leaking and sucking in unfiltered air from back there.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 09-10-2011, 07:55 PM   #40
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
By the top, I assume you mean the oil breather. To understand the PCV, you should understand why there is a PCV. It's there only for emissions. Back in the day, crankcase pressure was released the same as you have your setup. When people first started caring about reducing emissions, the PCV was invented. It's a valve that prevents air from flowing from the intake to the crankcase, but not from the crankcase to the intake manifold. There is a difference between vacuum in front of throttle body, and in the intake manifold depending on throttle plate position. With the throttle plate closed, there's a ton of vacuum in the intake manifold, and very little on the other side of the TB where the oil breather connects. At WOT, there's more vacuum at the oil breather than at the PCV, which with a good spring would be closed. Pressure is fairly well equalized between the top of the head and the crankcase anyway- unless the particular engine puts a ton of oil at the top, and has tiny drains to the bottom.
I was just giving people an easier way to test the PCV valve. Blow through the vacuum line hose, and if you don't feel resistance, then you need a new PCV valve. This is how it works for NA engines. Tom advises turbo engineers to gut the PCV and vent crankcase gasses to the atmosphere because boost would push past the PCV valve. It's not a perfect seal, but it doesn't have to be in an application where only vacuum is applied to it. I'm not quite sure how factory turbo PCV's are done, but emissions regs would require the crankcase gasses to be either caught in a catch can or somehow sucked back into the intake.
Be eclectic.
