Duratec Intake Manifold Removal and PCV hose replacement - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-25-2010, 07:47 PM   #21
jaliles
Fan#: 68504
What I Drive: 2005 ST
FF Reputation: 1 jaliles Good Standing Member
Can you please describe the symptoms/problems you were having as the result of the pcv hose after installing the cossie manifold? I am having weird problems just(but not immediately) after installing the cossie.
jaliles is offline
Old 06-26-2010, 11:57 AM   #22
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 32,496, Level 100
Points: 32,496, Level: 100 Points: 32,496, Level: 100 Points: 32,496, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by warneej View Post
I didn't get a code or anything and the symptoms were different both times. The first time my engine started running like I had a massive vacuum leak, although I couldn't find one. Symptoms included idling like I had a massive cam, terrible gas mileage, lean spikes, etc. The second time the car ran just fine however it just made that super loud whining noise.
That
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 06-27-2010, 10:57 AM   #23
CapnGnarly
CapnGnarly's Avatar
Fan#: 50250
What I Drive: '04 ZX3, 2.3L Duratec
FF Reputation: 7 CapnGnarly Good Standing Member
warneej, any chance you have pictures with the IM off of your PCV delete? I get what you're saying, but I just can't quite picture how you dumped it in my head. Everything else (cap the IM, cap the intake, filter on the breather on the valve cover) all make sense.
I'm just waiting for the weather to clear to (basically) pull off my front end for a super-thorough cleaning and a bit of painting in the engine bay, and would like to take care of the PCV while I have the IM off.
2004 Pitch Black 2.3L, FSWerks CAI and Focus Central 65mm TB
FRPP Competition Rally Brake Kit
Team Duratec #333
CapnGnarly is offline
Old 06-29-2010, 01:31 PM   #24
warneej
warneej's Avatar
Fan#: 20372
Your wish is my command, old old old images but they'll work:
First, remove the hose that runs from the intake tube to the valve cover. Plug the intake hose and put a filter (or a filtered catch can is best) here:
Out of here run a hose straight to the ground (I just bought a foot or two of properly sized heater hose and routed it down:
Then using a cap (such as a radiator bypass cap, which come in a multi-pack at your local autoparts store in the HELP! section, use one here and another on the intake tube. I didn't need clamps as they fit snugly but you make the call):
Or if you have a Cosworth then plug the corresponding port on the back of that.
173.4whp
gump
crew #6
Old 06-30-2010, 12:59 PM   #25
CapnGnarly
CapnGnarly's Avatar
Fan#: 50250
Thanks a ton! That 2nd pic is what I was looking for. Rep added.
Team Duratec #333
Old 07-11-2010, 01:11 AM   #26
Binzer
Binzer's Avatar
Fan#: 73070
What I Drive: 2013 Ruby Red SE Hatch, 94 FLSTC
Points 155, Level 3
Points: 155, Level: 3 Points: 155, Level: 3 Points: 155, Level: 3
Level Up 10% Completed
Forum Activity 2%
FF Reputation: 1 Binzer Good Standing Member
Great Pictures.
Question, does the PCV valve pull out easily from that plastic assy??
Do you know what size hose??
I was looking online at pcv valves and every one looks different.
Tnx, Mike.
Binzer is offline
Old 07-12-2010, 11:38 AM   #27
warneej
warneej's Avatar
Fan#: 20372
The valve has some sort of removable collar around it. It does not just pull out. The hose is like 5/8s I believe. AutoZone stocks the PCV valve so don't mess around online for it.
173.4whp
gump
crew #6
Old 11-30-2010, 04:53 PM   #28
Ridge Racer
Fan#: 80876
What I Drive: 2004 Grey SE
FF Reputation: 1 Ridge Racer Good Standing Member
Sorry to bump an old thread. My wife's car had this buzzing noise develop recently and eventually threw a code (P0171-System lean). It sounded just like the OP problem. Thank you all again for posting this since I actually came to this thread via a search on Google. You ppl saved me alot of cash since I was able to do it myself(4 hours- had a mishap with the EGR vacuum conn on the intake.. ). Im a Subaru guy but I really appreciate these car forums for all the good knowledge and resources they offer. BTW the car only has 50K.
Ridge Racer is offline
Old 11-30-2010, 06:39 PM   #29
crazyjess
Fan#: 46890
What I Drive: 2004 light-tundra zx3
Points 1,169, Level 18
Points: 1,169, Level: 18 Points: 1,169, Level: 18 Points: 1,169, Level: 18
Level Up 69% Completed
FF Reputation: 2 crazyjess Good Standing Member
Maybe this why i been having bad milage. I havent replaced the pvc hose. Ill check if its clogged or caked.
crazyjess is offline
Old 12-04-2010, 12:51 AM   #30
crazyjess
Fan#: 46890
Today i took off my manifold wich was a pain in the a$$. Specially the bolts in between the manifold. My PVC hose was all messed up and had oil. Do i just go to Autozone and get a piece of hose or order one for my car?
