Duratec Intake Manifold Removal and PCV hose replacement
1 reading
284K views 158 replies 56 participants last post by  rkpatt
#1 ·
So my Focus was recently making an odd noise. At idle it had a whining noise and after shutting off the engine it would hiss/wine for several seconds. I tinkered with it for a while and decided it was a vacuum leak but after spending hours under the hood poking around at everything vacuum related I came up with nothing. Short on time, I took it to Ford who told me the PCV hose was cracked and it was going to cost $600 to fix. I told them to order me the part and told them I'd come get the car. So I paid $138 for diagnostic and $40 for the PCV hose.
FYI, my car is a 2004 ZX3 2.3L manual transmission.
I found this page very helpful due to the diagrams showing you where all the bolts are
http://duratec.wikispaces.com/modification-cosworthIM
There is a video in this thread and the noise this car is making is identical to mine. I'm assuming it was the same problem.
http://www.focusfanatics.com/forum/showthread.php?t=196726&highlight="intake+manifold"&page=2
So this weekend I went to swap the PCV hose, which is much more work then I had anticipated and I see why Ford wanted $600… I wasn't intending on doing a full write up on here so the pictures aren't a complete how to but show some of the issues I encountered.
Also I cant guarantee that my methods are by any means the "easiest" but it worked.
There are a total of 8 bolts holding the intake manifold onto the head/block. 7 of them are near the intake runners just as you would expect and there is one that you access from under the car that goes into the block. All of the bolts are fairly obvious except one and it is located between intake runners 2 and 3 (assuming the pistons are labeled 1-4 in order). To get to this bolt I had to remove the following:
- Electric fan - 2 electrical connectors and 2 clips, pretty easy and straightforward, the fan comes out of the bottom of the car not through the top.
- Cover of the plastic grill and the plastic grill (the one with the turn signals in it).
- Remove the lower radiator support (2 10mm bolts on each side of the car, 4 total) and then use a floor jack to lower the radiator and AC condenser about 2"
Then I used a 12" and an 8" extension and a 10mm socket to remove the final bolt in the intake manifold. The pictures below should help to explain this. Also the link above shows pictures of the intake manifold removed so you can visualize it.
Once the bolts are out and all the electrical connectors and vacuum hoses are disconnected the manifold comes out pretty easy.
In this picture you can see the black box on the block with the yellow/whiteish plastic hose outlet on it, this is where the PCV hose connects.
And here's the stupid hose that caused all my problems. Thanks for burying that on me Ford!
While I had it apart I flushed the inside of the intake manifold with some degreaser and warm water.
All back together
Its all back together and working fine, then noise is gone and I managed not to F up anything else. Total repair time took me about 6 hours, mostly because I didn’t know about that bolt between the 2 and 3 intake runners and then once I learned it was there had to figure out how to get to it! It’s a pretty tough repair and I'd say you have a be a pretty competent mechanic to take on this one. Oh and your fingers will be cut up from working in all the tiny little places you have to get to.
So that’s about it for me. Like I said its not a complete write up but details the issues I ran into which is the most important part I suppose. Hopefully this helps someone save $500 by not having Ford do the repair. Good luck if you have to do this.
#3 ·
Hah. Done this twice. I hate that hose.
I just deleted mine now finally.
I removed the entire radiator support and it made it super easy. Also my fans came out through the top but I'm sure they can go down too.
That whining noise is what I was txting you about the other day Jet. Sounded like a fire alarm or whatever you call it. The thing the station blares at noon and 6pm and when there is a fire.
Great write up [thumb]
#5 ·
How did you delete it? Is this SMOG legal? I live in CA and have worry about that garbage.
Informative. I kinda want to do this over the next weekend as preventative before winter.
I am interested though, how was the condition of the PCV? Was it still operational or was it pretty clogged? And the hose, was it full of oil? How many miles are on the car?
The car just turned 60K. I drove it several days with the leak and it had no noticeable affect on power or mileage.
I really didnt look at the PCV because I didn't know what to look for in assessing if there was anything wrong with it. If you look at the picture of the cracked hose you can see signs of moisture where the crack is, so there was definetly some oil going through it but not a lot, there was no oil leaking out of it, no oil dripped on the ground or anything. There was some slight oil buildup in the intake manifold itself but no pooling anywhere. I might kill some one if the PCV goes out soon! [gunfire]
#7 ·
Yeah, if it whines at idle and if you shut off the engine and it hisses for a few seconds, I'd say its more than likely the PCV hose. Oh and if someone knows of a cheaper source, that would be nice to post up, because I felt like a chump paying Ford $40 for a 6" formed house with 2 clamps on it [rant]
  • Like
Reactions: jetrinka
#8 ·
That hose is a piece of shit too. Be ready to replace it again. I bought a $10 hose from AutoZone and made it work however the Cosworth IM requires a different hose be used. Regardless that one lasted like a year on the dot too so who knows.
To delete it probably isn't smog legal but its like impossible to tell. I capped the intake on the intake manifold and ran a dump hose from the valve. Then I capped the spot on the air hose and put a filter on the valve cover. This made it independent from the air induction system. I won't have to worry about it causing a vacuum leak anytime soon [thumb]
#9 ·
sounds promising... I guess if (or when) it fails again I'll look into replacing it with a better quality hose, maybe some of the high mileage goodyear stuff.
#10 ·
im waiting for mine to go...
i dont know about you Evan or anybody else with the Cosi Mani but with that freakin plumbing thread i could literally only get that tap to go in halfway, i didnt want to crack anything...so rather than a short hose that the instructions call for...i just have a longer one :-D ...
#16 ·
Yeah i had the same issue with the hose fitting, it seems as though every piece of hardware that came with the manifold was either the wrong thread pattern or too long. My first fix was with a longer hose but that ripped as well.
Did anyone else having this failed hose have a problem with the idle being too high or get a lean code? It took me a while before I realized what was causing all of that.
This job is a serious PITA. I wish I'd have done what warneej did--I sure don't feel good about the new Ford piece I put back on there.
There's no telling what all got sucked up by that damned crack. My intake manifold was all gunked up. The tumble flaps were pretty caked too. It took a while to clean it all up. Hope there's no long term damage.
I highly recommend putting something sticky/gooey on your socket--a dab of grease should do it--when reinstalling bolts. I dropped one and it took a while to figure out which bottomless pit the thing disappeared down!
I hope the next time I have to do this, I'll remember what I did before. ;)
I didn't get a code or anything and the symptoms were different both times. The first time my engine started running like I had a massive vacuum leak, although I couldn't find one. Symptoms included idling like I had a massive cam, terrible gas mileage, lean spikes, etc. The second time the car ran just fine however it just made that super loud whining noise.
When I pulled off my stock manifold (the PCV hose was still working fine mind you) mine too was caked with goo. I think its what comes through the EGR that causes that. I deleted that in my tune.
#11 ·
#13 ·
I still think its wierd but my car ran great, no codes, no wierd idle, same great mileage, same performance, etc...
The pcv hose isn't the worst when it comes to quality, it's not gold but it's also just a hose. There are a vast majority that have them last quite awhile and then of course polar opposites. If it lasts 100k then hell I'm pleased (but I do have lower standards) I already have a new one sitting around.
You sound like the wife whose husband always beats her, but its ok because "he loves me". [:D]
The hose is a poorely engineered piece of shit. Just admit it. I have 20 year old hoses on my bronco that still work, including the PCV hose which BTW I could replace in about 10 minutes and that includes the time to open my first beer, finish it while working and go for a second.
#12 ·
#15 ·
Don't get me started though on the pain that is FWD. I'd much rather argue about the engineering on that than a hose
Amen! I don't know how many times I've looked at the manual for an R&R procedure and said, "You gotta pull WHAT?!
#23 ·
warneej, any chance you have pictures with the IM off of your PCV delete? I get what you're saying, but I just can't quite picture how you dumped it in my head. Everything else (cap the IM, cap the intake, filter on the breather on the valve cover) all make sense.
I'm just waiting for the weather to clear to (basically) pull off my front end for a super-thorough cleaning and a bit of painting in the engine bay, and would like to take care of the PCV while I have the IM off.
#24 ·
Your wish is my command, old old old images but they'll work:
First, remove the hose that runs from the intake tube to the valve cover. Plug the intake hose and put a filter (or a filtered catch can is best) here:
Out of here run a hose straight to the ground (I just bought a foot or two of properly sized heater hose and routed it down:
Then using a cap (such as a radiator bypass cap, which come in a multi-pack at your local autoparts store in the HELP! section, use one here and another on the intake tube. I didn't need clamps as they fit snugly but you make the call):
Or if you have a Cosworth then plug the corresponding port on the back of that.
#28 ·
Sorry to bump an old thread. My wife's car had this buzzing noise develop recently and eventually threw a code (P0171-System lean). It sounded just like the OP problem. Thank you all again for posting this since I actually came to this thread via a search on Google. You ppl saved me alot of cash since I was able to do it myself(4 hours- had a mishap with the EGR vacuum conn on the intake.. ). Im a Subaru guy but I really appreciate these car forums for all the good knowledge and resources they offer. BTW the car only has 50K.
#35 ·
What you need to figure it out is to play around with an old PCV valve like a Zetec or V8 valve. If you suck on the hose side, you'll pull the little stopper up, if you blow on it, the stopper will go down and you can't blow through it. When it's bad, you can blow through it. The PCV is connected to engine vacuum after the TB. The oil breather (valve cover connection) is connected in front of the TB in the air intake.
The PCV opens when vacuum is high, and the oil breather works when air intake flow is high. Both of them suck oil smoke/misty oil back into the engine to be burned up.
Go read up on Wiki about it, and you'll find the automotive history behind why modern PCV and oil breather are routed back through the engine. It's for emissions. Yeah, you don't need it to run, but if we didn't have it- we'd be wearing face masks like people in Hong Kong on high pollution days. If anyone wants to see what the USA would be like without EPA and eco-terrorists, keep an eye on China over the next 10 years or so. I'll have to go check, but I think their air pollution is already higher than ours was in the early 70s.
#36 ·
I took whynotthinkwhynot suggestion and read-up on the PCV system. I sounds like the long term solution is to move the PCV valve out from under the intake and use an oil separator (if you so choose) to extract the oil before it gets to the intake. Also, tap a new hole in the intake in a more human friendly spot. Can the stock PCV valve be gutted (remove the internal valving)?
This should be 100% legal as were not dumping anything to atmosphere. Were simply relocating the PCV, and extracting the oil component so as not to gunk up the intake internals (as fast).
