2008-2009 manual transmission shifting problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-29-2009, 12:56 PM   #1
Darthenstein
Darthenstein's Avatar
Fan#: 63587
What I Drive: 2009 Ford Focus SES
Points 1,534, Level 22
Points: 1,534, Level: 22 Points: 1,534, Level: 22 Points: 1,534, Level: 22
Level Up 34% Completed
FF Reputation: 4 Darthenstein Good Standing Member
Hey everyone,
2009 Focus SES 5spd man, 11,000 miles.
I have had problems shifting the car, ever since it was new. It felt as if the clutch wasn't engaging, even when pressed to the floor, which would result in the shifting not being as free and smooth as it should have been. Shifting felt more like I had to time it to the engine, in other words like shifting without the clutch.
I had the brakes bled (the clutch works off of brake fluid in the new cars) almost right after I bought the car new, and that solved the problem for a few months, however, the problem came back when the weather was cold. I have noticed this a few times on this forum.
My service advisor believes that the problem may be with the slave cylinder, which pushes the fluid down. It may not be pushing enough and may need to be replaced.
I am posting this because I have noticed this a few times on this board and it may be of benefit to other users, as it is covered under warranty. I believe that it will be quite expensive as it requires pulling out the tranny.
I have not yet had this done, however, in my years of working on cars, motorcycles, bicycles, and other fluid-related equipment it does make sense.
Enjoy!
"It isn't what you drive that matters, it's how you drive it" - Jeremy Clarkson, Top Gear
Ford: Taurus ('91, 01) Focus ('09); Mercury: Sable ('95); Dodge: Neon ('95); Trek: 1000SL ('07) Yamaha: VStar 650 ('03)
Darthenstein is offline
Old 09-29-2009, 12:58 PM   #2
theheat
I Nom Cones
theheat's Avatar
Fan#: 59123
What I Drive: 2008 Vermillion Red S Coupe
FF Reputation: 3 theheat Good Standing Member
warranty time!!!!
im my car, you barely have to press the pedal to engage the clutch, its really nice!!!
Team Duratec # 219
2008 Coupe S:
Born on 12/17/2007
theheat is offline
Old 09-29-2009, 01:00 PM   #3
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
FF Reputation: 16 arlenn Great Standing Member
your under warranty, so it is much easier for you.
i have a similar issue, shifts are not crisp unless you fully fully fully depress the clutch. I was going to try a simple bleed of the clutch assembly. i don't notice any leaks but i would like to think that though entropy after 8 years, a small amount of air could enter the system.
arlenn is offline
Old 09-29-2009, 04:19 PM   #4
Darthenstein
Fan#: 63587
yeah i am glad i am under warranty...otherwise it would be $$$
Old 09-29-2009, 04:32 PM   #5
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
Surely the dealer wasn't that dumb. Why would they have bled the brakes only and not the clutch? I think that they probably actually did bleed the clutch (and possibly the brakes as well), but you misunderstood the info. You did have an improvement with the clutch which would have occurred only if they had bled the clutch. To clarify.......pushing the pedal down disengages the clutch, when the pedal is up.......it's engaged. Let us know what they do or replace next.
Grumpy is offline
Old 09-29-2009, 04:59 PM   #6
Z_interactive
Z_interactive's Avatar
Fan#: 69219
What I Drive: 2007 blue 1.6
Points 5,402, Level 47
Points: 5,402, Level: 47 Points: 5,402, Level: 47 Points: 5,402, Level: 47
Level Up 26% Completed
FF Reputation: 2 Z_interactive Good Standing Member
I've been on this forum only a week and I saw few people complain about transmission.
Sorry I can't help you but all I know Ford's transmissions (at least Focus MkII EU) is excellent. Really excellent.
Z_interactive is offline
Old 09-29-2009, 05:05 PM   #7
Darthenstein
Fan#: 63587
That's what I was implying...the clutch works from the brake fluid...bleed the brakes, you are working for the brakes and the clutch. sorry i did not mention this
Old 09-30-2009, 09:39 AM   #8
nibyak
Fan#: 25443
What I Drive: 2012, RedCandy, 5-Door, SE
Points 71, Level 1
Points: 71, Level: 1 Points: 71, Level: 1 Points: 71, Level: 1
Level Up 43% Completed
FF Reputation: 1 nibyak Good Standing Member
The Clutch works on Brake Fluid not on THE Brake fluid. Your clutch and your brakes are two totally separate systems which both happen to be hydraulic and use brake fluid. The dealer bled the clutch, not the brakes (I hope). Leaking clutch slave cylinders and master cylinders are not unheard of. Since the car is relatively new and under warranty, this should be sorted out by the service department for free.
nibyak is offline
Old 09-30-2009, 11:28 AM   #9
Darthenstein
Fan#: 63587
right...what I am trying to do is tell owners of the 2008-2009 (and possibly 2010) Focus with a manual transmission is that they may have a defective slave cylinder in their transmission.
What I was talking about the bleeding of whatever has already been done and only fixed the problem for a little bit, and there is something else up in there. Hopefully other people can read this and get their cars fixed under warranty before getting a huge bill!
Old 09-30-2009, 11:34 AM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
It sounds like the slave cylinder will have to be replaced IMO. The slave cylinder doesn't push fluid, it's what the fluid is pushed to. The slave fills up and expands, and that's what pushes on the release bearing and pressure plate to engage the clutch. Mine stuck a few times keeping the clutch engaged, and over a few hours it would disengage properly. These slave cylinders are plastic, and plastic is prone to manufacturing and temperature related problems. It should always be replaced when changing the clutch IMO.
Are you noticing that the clutch pedal is harder to push down when you can't get it to engage?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
