J&S issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2009, 07:43 PM   #1
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
What I Drive: a wide svt
FF Reputation: 7 WRCwannabe Good Standing Member
Buy-Sell-Trade Rating: (9)
J&S issue
ok so i hooked my j&s up last week and i didnt start the car or test it cause it was late
so today i go to start my car and it doesnt want to start then it finally fires up but with like no umph and its missfiring o i turn it off and start it again and same thing.
CEL comes on and i get some code to the ignition coil channel a or something
so i look at the vampire splices and i get pliers and squeeze it down a little bit and it starts up like normal
well the light on the j&S light up and the guage sweeps like it is supposed to at start up.
at idle the monitor sensor on the back of the J&S is lit up.
so i turn all the channels down. or whatever, and i go to take it for a drive.
it feels like its missing power.
but the j&s gauge isnt moving or lighting up at all. and the back of the J&S light isnt on...
it comes on when im stopped or when im not on the gas.
but as soon as i hit the gas the light goes away...
idk what to do...
i grounded both of the black ground wires.
and its weirdhow it works at idle but as soon as i hit the gas it goes away
please help.
Wings & Teeth
Whatever I say is royal ocean
("I'm U.S. with a little bit of U.K. swagger" )
Jeremy Clarkson on the MK1 Focus RS "The reason it was so quick round our track is simple: this car handles like it's in a cartoon."
WRCwannabe is offline
Old 09-19-2009, 08:23 PM   #2
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
just read step 9 in the instructions.
the monitor led light will pulse at start up and idle.
with no knock retard the monitor led light will turn off.
when knock retard occurs the led will light up.
but what explains the power loss
it just seems smoother in a way but like not as much umph.
i messed up my VCT solenoid but fixed it, and it isnt throwing codes.
the engine seems a bit louder. like ticking or something. louder than usual.
i have the sensitivity at about 75%.
with all of the 1-5 'down'
Wings & Teeth
Old 09-20-2009, 09:37 AM   #3
3rdgeneration
3rdgeneration's Avatar
Fan#: 42534
Points 870, Level 15
Points: 870, Level: 15 Points: 870, Level: 15 Points: 870, Level: 15
Level Up 70% Completed
FF Reputation: 1 3rdgeneration Good Standing Member
try putting switch 1 up, and turning your sensitivity to exactly half.also email john and j&s hes very good at getting back to you
"drive it like you stole it"
03 infa red svt SC
09 Black SES
3rdgeneration is offline
Old 09-21-2009, 09:21 AM   #4
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
im getting no timing pulled from the j&s.
no activity on the gauge.
either i have a perfect tune or something idk.
i noticed my throttle response is down since i got that code for the igniton coil a or something.
i fixed the ignition coil thing but still feels weak on throttle.
Wings & Teeth
Old 09-21-2009, 12:35 PM   #5
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
ive set 1 switch up and turned the sensitivity pretty high and did a few pulls to about 5k rpms.
throttle response was weak after it.
but no movement on the j&s gauge
Wings & Teeth
Old 09-21-2009, 09:45 PM   #6
pitchedblack04
Bewst Anyone!!!
pitchedblack04's Avatar
Fan#: 62993
What I Drive: 2004 turbo'd svt
Points 3,266, Level 35
Points: 3,266, Level: 35 Points: 3,266, Level: 35 Points: 3,266, Level: 35
Level Up 44% Completed
FF Reputation: 7 pitchedblack04 Good Standing Member
Im guessing you tested the unit while stationary?
Car is for sale. Pm me for details.
pitchedblack04 is offline
Old 09-22-2009, 09:42 AM   #7
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
Is there a special sort of solder i should use to solder the connections?
im getting bad connections between the j&s and wire 26 (coil a or whatever) and its causing missing and stuff.
Ive also grounded the two black wires to the same ground. is this ok?
i doesnt specify what to do with it in the instructions.
it say ground the one black wire with the 12v source but for the knock sensor clear wire and then the black wire it doesnt tell yuo what to do with it.
please help
Wings & Teeth
Old 09-22-2009, 11:30 AM   #8
3rdgeneration
Fan#: 42534
john and J&S said the ground with the clear wire does not have to be grounded. but i already grounded with the other ground wire and the unit works fine. As far is the solder 5core solder has flux in at and will help get a better bond but i don't know if it really makes a huge difference
03 infa red svt SC
09 Black SES
Old 09-22-2009, 11:33 AM   #9
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
ok and do i just try to take some of the rubber off the wire and solder together?
Wings & Teeth
Old 09-22-2009, 11:40 AM   #10
WRCwannabe
Wings & Teeth
WRCwannabe's Avatar
Fan#: 48696
also what kind of soldering gun should i get
http://www.radioshack.com/family/ind...Price-RSK&pg=2
something cheap, but what wattage and etc.
i was thinking 15watt cause it says good for circuit work but what if i want to use for something else down the line couild i get a 40watt of 25 watt or something and it still work for this.
Wings & Teeth
