Scan tool info - Focus Fanatics
Old 09-13-2009, 11:00 PM   #1
wilecoyote
Fan#: 55318
What I Drive: 2003, Charcoal Gray, ZX3
FF Reputation: 1 wilecoyote Good Standing Member
Scan tool info
Can anybody tell me what they see in the scan tool data. This is a 03 zx3 2.3
Global OBDII
Non OBD Freeze Frame
Frame 1 Mod $00
MIL STATUS OFF
TROUB CODE P0171
ABSLT TPS % 21.1
ENG SPEED RPM 1357
CALC LOAD % 29.4
MAF FLOW GR/SE 5.19
MAP KPA 37
COOLANT F 195
IAT F 84
IGN ADVANCE DE 18.0
SECOND AIR ATMOS
ST FTRM1 % 20.3
LT FTRM1 % 27.3
ST FTRM3 % -100.6
LT FTRM3 % -100.6
VEH SPEED MPH 8
REL FRP KPA 2.86
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.645
ST FTRM11 % 20.3
O2S12 V 0.060
ST FTRM12 % 99.2
O2S13 V 0.065
ST FTRM13 % 99.2
Recorded Data
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 878
CALC LOAD % 36.8
MAF FLOW GR/SE 4.35
MAP KPA 42
COOLANT F 159
IAT F 78
IGN ADVANCE DE 6.0
SECOND AIR ATMOS
ST FTRM1 % -21.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.65
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -21.5
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame -1 Time -2.0
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 889
CALC LOAD % 36.8
MAF FLOW GR/SE 4.35
MAP KPA 42
COOLANT F 159
IAT F 78
IGN ADVANCE DE 5.5
SECOND AIR ATMOS
ST FTRM1 % -21.7
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.75
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -21.7
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 889
CALC LOAD % 36.8
MAF FLOW GR/SE 4.59
MAP KPA 42
COOLANT F 159
IAT F 78
IGN ADVANCE DE 5.0
SECOND AIR ATMOS
ST FTRM1 % -23.1
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.78
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.790
ST FTRM11 % -23.1
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 1 Time 2.1
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 875
CALC LOAD % 38.8
MAF FLOW GR/SE 4.43
MAP KPA 43
COOLANT F 159
IAT F 78
IGN ADVANCE DE 5.0
SECOND AIR ATMOS
ST FTRM1 % -24.3
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.74
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -24.3
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 2 Time 4.1
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 883
CALC LOAD % 38.4
MAF FLOW GR/SE 4.31
MAP KPA 45
COOLANT F 159
IAT F 78
IGN ADVANCE DE 5.0
SECOND AIR ATMOS
ST FTRM1 % -25.6
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.76
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -25.8
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 3 Time 6.1
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 883
CALC LOAD % 39.6
MAF FLOW GR/SE 4.63
MAP KPA 45
COOLANT F 159
IAT F 78
IGN ADVANCE DE 7.0
SECOND AIR ATMOS
ST FTRM1 % -26.0
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.78
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -26.0
O2S12 V 0.010
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 4 Time 8.1
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 917
CALC LOAD % 40.3
MAF FLOW GR/SE 4.95
MAP KPA 46
COOLANT F 159
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % -27.2
LT FTRM1 % 25.0
VEH SPEED MPH 0
REL FRP KPA 2.73
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -28.4
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 5 Time 10.0
MIL STATUS ON
ABSLT TPS % 19.6
ENG SPEED RPM 1758
CALC LOAD % 29.8
MAF FLOW GR/SE 7.60
MAP KPA 34
COOLANT F 161
IAT F 78
IGN ADVANCE DE 16.5
SECOND AIR ATMOS
ST FTRM1 % -29.9
LT FTRM1 % 22.6
VEH SPEED MPH 0
REL FRP KPA 2.71
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -29.9
O2S12 V 0.015
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 6 Time 12.0
MIL STATUS ON
ABSLT TPS % 19.6
ENG SPEED RPM 1708
CALC LOAD % 30.1
MAF FLOW GR/SE 7.60
MAP KPA 35
COOLANT F 161
IAT F 78
IGN ADVANCE DE 19.0
SECOND AIR ATMOS
ST FTRM1 % -31.3
LT FTRM1 % 22.6
VEH SPEED MPH 0
REL FRP KPA 2.79
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.795
ST FTRM11 % -32.5
O2S12 V 0.010
O2S13 V 0.000
MIL DIST mi 57
OBD2 STAT CA
Frame 7 Time 14.0
MIL STATUS ON
ABSLT TPS % 21.9
ENG SPEED RPM 1839
CALC LOAD % 38.4
MAF FLOW GR/SE 10.55
MAP KPA 40
COOLANT F 161
IAT F 78
IGN ADVANCE DE 17.5
SECOND AIR ATMOS
ST FTRM1 % -13.3
LT FTRM1 % 14.0
VEH SPEED MPH 0
REL FRP KPA 2.76
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % -7.7
O2S12 V 0.025
O2S13 V 0.015
MIL DIST mi 57
OBD2 STAT CA
Frame 8 Time 16.0
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 2289
CALC LOAD % 18.0
MAF FLOW GR/SE 6.29
MAP KPA 25
COOLANT F 161
IAT F 78
IGN ADVANCE DE 6.5
SECOND AIR ATMOS
ST FTRM1 % 0.8
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.74
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.045
ST FTRM11 % 0.0
O2S12 V 0.045
O2S13 V 0.020
MIL DIST mi 57
OBD2 STAT CA
Frame 9 Time 17.9
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 1722
CALC LOAD % 21.5
MAF FLOW GR/SE 5.31
MAP KPA 28
COOLANT F 161
IAT F 77
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 2.3
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.72
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.055
ST FTRM11 % 3.9
O2S12 V 0.055
O2S13 V 0.025
MIL DIST mi 57
OBD2 STAT CA
Frame 10 Time 19.9
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 1518
CALC LOAD % 20.7
MAF FLOW GR/SE 4.31
MAP KPA 28
COOLANT F 161
IAT F 78
IGN ADVANCE DE 4.0
SECOND AIR ATMOS
ST FTRM1 % 4.6
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.70
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.050
ST FTRM11 % 5.4
O2S12 V 0.045
O2S13 V 0.015
MIL DIST mi 57
OBD2 STAT CA
Frame 11 Time 21.9
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 1021
CALC LOAD % 26.6
MAF FLOW GR/SE 3.29
MAP KPA 34
COOLANT F 161
IAT F 78
IGN ADVANCE DE 0.5
SECOND AIR ATMOS
ST FTRM1 % 7.0
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.75
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 7.0
O2S12 V 0.030
O2S13 V 0.005
MIL DIST mi 57
OBD2 STAT CA
Frame 12 Time 23.9
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 986
CALC LOAD % 27.4
MAF FLOW GR/SE 3.14
MAP KPA 35
COOLANT F 163
IAT F 78
IGN ADVANCE DE 2.0
SECOND AIR ATMOS
ST FTRM1 % 8.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.78
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 9.3
O2S12 V 0.025
O2S13 V 0.005
MIL DIST mi 57
OBD2 STAT CA
Frame 13 Time 25.8
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 930
CALC LOAD % 28.2
MAF FLOW GR/SE 3.03
MAP KPA 35
COOLANT F 163
IAT F 78
IGN ADVANCE DE 2.5
SECOND AIR ATMOS
ST FTRM1 % 10.1
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.72
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 10.9
O2S12 V 0.025
O2S13 V 0.005
MIL DIST mi 57
OBD2 STAT CA
Frame 14 Time 27.8
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 934
CALC LOAD % 27.4
MAF FLOW GR/SE 2.77
MAP KPA 34
COOLANT F 163
IAT F 78
IGN ADVANCE DE 3.5
SECOND AIR ATMOS
ST FTRM1 % 12.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.77
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 12.5
O2S12 V 0.025
O2S13 V 0.005
MIL DIST mi 57
OBD2 STAT CA
Frame 15 Time 29.8
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 906
CALC LOAD % 27.8
MAF FLOW GR/SE 2.80
MAP KPA 34
COOLANT F 163
IAT F 78
IGN ADVANCE DE 3.5
SECOND AIR ATMOS
ST FTRM1 % 14.0
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.75
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 14.8
O2S12 V 0.025
O2S13 V 0.005
MIL DIST mi 57
OBD2 STAT CA
Frame 16 Time 31.7
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 901
CALC LOAD % 28.2
MAF FLOW GR/SE 2.77
MAP KPA 34
COOLANT F 165
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 16.4
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.80
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 16.4
O2S12 V 0.025
O2S13 V 0.010
MIL DIST mi 57
OBD2 STAT CA
Frame 17 Time 33.7
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 901
CALC LOAD % 27.4
MAF FLOW GR/SE 2.50
MAP KPA 34
COOLANT F 165
IAT F 78
IGN ADVANCE DE 4.0
SECOND AIR ATMOS
ST FTRM1 % 17.9
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.72
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 18.7
O2S12 V 0.025
O2S13 V 0.010
MIL DIST mi 57
OBD2 STAT CA
Frame 18 Time 35.7
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 910
CALC LOAD % 27.0
MAF FLOW GR/SE 2.46
MAP KPA 34
COOLANT F 165
IAT F 78
IGN ADVANCE DE 3.5
SECOND AIR ATMOS
ST FTRM1 % 20.3
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.78
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 21.0
O2S12 V 0.025
O2S13 V 0.010
MIL DIST mi 57
OBD2 STAT CA
Frame 19 Time 37.7
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 898
CALC LOAD % 27.0
MAF FLOW GR/SE 2.38
MAP KPA 34
COOLANT F 167
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 22.6
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.81
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 23.4
O2S12 V 0.025
O2S13 V 0.015
MIL DIST mi 57
OBD2 STAT CA
Frame 20 Time 39.6
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 918
CALC LOAD % 26.2
MAF FLOW GR/SE 2.38
MAP KPA 33
COOLANT F 167
IAT F 78
IGN ADVANCE DE 4.0
SECOND AIR ATMOS
ST FTRM1 % 25.0
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.71
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 25.7
O2S12 V 0.025
O2S13 V 0.015
MIL DIST mi 57
OBD2 STAT CA
Frame 21 Time 41.6
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 906
CALC LOAD % 26.6
MAF FLOW GR/SE 2.25
MAP KPA 33
COOLANT F 167
IAT F 78
IGN ADVANCE DE 4.5
SECOND AIR ATMOS
ST FTRM1 % 27.3
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.76
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 28.1
O2S12 V 0.025
O2S13 V 0.015
MIL DIST mi 57
OBD2 STAT CA
Frame 22 Time 43.6
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 901
CALC LOAD % 27.0
MAF FLOW GR/SE 2.34
MAP KPA 33
COOLANT F 167
IAT F 78
IGN ADVANCE DE 3.5
SECOND AIR ATMOS
ST FTRM1 % 29.6
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.73
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 30.4
O2S12 V 0.030
O2S13 V 0.020
MIL DIST mi 57
OBD2 STAT CA
Frame 23 Time 45.6
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 902
CALC LOAD % 26.6
MAF FLOW GR/SE 2.32
MAP KPA 32
COOLANT F 167
IAT F 78
IGN ADVANCE DE 4.0
SECOND AIR ATMOS
ST FTRM1 % 32.8
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.77
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 33.5
O2S12 V 0.030
O2S13 V 0.020
MIL DIST mi 57
OBD2 STAT CA
Frame 24 Time 47.5
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 905
CALC LOAD % 26.2
MAF FLOW GR/SE 2.12
MAP KPA 32
COOLANT F 168
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 35.1
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.77
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 35.9
O2S12 V 0.030
O2S13 V 0.025
MIL DIST mi 57
OBD2 STAT CA
Frame 25 Time 49.5
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 884
CALC LOAD % 25.4
MAF FLOW GR/SE 2.29
MAP KPA 32
COOLANT F 168
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 38.2
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.73
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 42.1
O2S12 V 0.030
O2S13 V 0.025
MIL DIST mi 57
OBD2 STAT CA
Frame 26 Time 51.5
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 909
CALC LOAD % 25.0
MAF FLOW GR/SE 2.01
MAP KPA 31
COOLANT F 168
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 44.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.70
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.035
ST FTRM11 % 44.5
O2S12 V 0.035
O2S13 V 0.030
MIL DIST mi 57
OBD2 STAT CA
Frame 27 Time 53.4
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 901
CALC LOAD % 25.0
MAF FLOW GR/SE 2.10
MAP KPA 31
COOLANT F 168
IAT F 78
IGN ADVANCE DE 3.5
SECOND AIR ATMOS
ST FTRM1 % 44.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.70
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.035
ST FTRM11 % 44.5
O2S12 V 0.035
O2S13 V 0.030
MIL DIST mi 57
OBD2 STAT CA
Frame 28 Time 55.4
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 889
CALC LOAD % 25.0
MAF FLOW GR/SE 1.92
MAP KPA 31
COOLANT F 170
IAT F 78
IGN ADVANCE DE 3.0
SECOND AIR ATMOS
ST FTRM1 % 44.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.75
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 44.5
O2S12 V 0.035
O2S13 V 0.030
MIL DIST mi 57
OBD2 STAT CA
Frame 29 Time 57.4
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 860
CALC LOAD % 25.4
MAF FLOW GR/SE 2.03
MAP KPA 32
COOLANT F 170
IAT F 78
IGN ADVANCE DE 4.0
SECOND AIR ATMOS
ST FTRM1 % 44.5
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.71
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.035
ST FTRM11 % 44.5
O2S12 V 0.035
O2S13 V 0.030
MIL DIST mi 57
OBD2 STAT CA
Frame 30 Time 59.4
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 878
CALC LOAD % 25.0
MAF FLOW GR/SE 1.85
MAP KPA 31
COOLANT F 170
IAT F 78
IGN ADVANCE DE 4.5
SECOND AIR ATMOS
ST FTRM1 % 43.7
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.71
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.025
ST FTRM11 % 43.7
O2S12 V 0.030
O2S13 V 0.025
MIL DIST mi 57
OBD2 STAT CA
Frame 31 Time 61.3
MIL STATUS ON
ABSLT TPS % 18.4
ENG SPEED RPM 860
CALC LOAD % 25.0
MAF FLOW GR/SE 1.77
MAP KPA 32
COOLANT F 170
IAT F 78
IGN ADVANCE DE 4.5
SECOND AIR ATMOS
ST FTRM1 % 43.7
LT FTRM1 % 27.3
VEH SPEED MPH 0
REL FRP KPA 2.78
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.030
ST FTRM11 % 43.7
O2S12 V 0.030
O2S13 V 0.030
MIL DIST mi 57
OBD2 STAT CA
Frame 32 Time 63.3
MIL STATUS($00) ---
ABSLT TPS($00) ---
ENG SPEED($00) ---
CALC LOAD($00) ---
MAF FLOW($00) ---
MAP($00) ---
COOLANT($00) ---
IAT($00) ---
IGN ADVANCE($00) ---
SECOND AIR($00) ---
ST FTRM1($00) ---
LT FTRM1($00) ---
VEH SPEED($00) ---
REL FRP($00) ---
FUEL SYS 1 N/A
FUEL SYS 2 CLSD
O2S11 V 0.030
ST FTRM11 % -93.6
O2S12 V 0.055
O2S13 V 0.065
MIL DIST mi 4630
OBD2 STAT N/A
Frame -1 Time -26.0
MIL STATUS OFF
ABSLT TPS % 100.0
ENG SPEED RPM 0
CALC LOAD % 0.0
MAF FLOW GR/SE 0.00
MAP KPA 0
COOLANT F -40
IAT F -40
IGN ADVANCE DE -64.6
SECOND AIR N/A
ST FTRM1 % -100.6
LT FTRM1 % -100.6
VEH SPEED MPH 0
REL FRP KPA 0.00
FUEL SYS 1 N/A
FUEL SYS 2 N/A
O2S11 V 0.000
ST FTRM11 % -100.6
O2S12 V 0.000
O2S13 V 0.000
MIL DIST mi 0
OBD2 STAT N/A
Frame 14137 Time1336.3
MIL STATUS OFF
ABSLT TPS % 0.0
ENG SPEED RPM 0
CALC LOAD % 0.0
MAF FLOW GR/SE 0.00
MAP KPA 0
COOLANT F -40
IAT F -40
SECOND AIR N/A
ST FTRM1 % -100.6
LT FTRM1 % -100.6
VEH SPEED MPH 0
REL FRP KPA 0.00
FUEL SYS 1 N/A
FUEL SYS 2 N/A
O2S11 V 0.000
ST FTRM11 % -100.6
O2S12 V 0.000
O2S13 V 0.000
MIL DIST mi 0
OBD2 STAT N/A
Frame 0 Time -25.9
MIL STATUS OFF
ABSLT TPS % 0.0
ENG SPEED RPM 0
CALC LOAD % 0.0
MAF FLOW GR/SE 0.00
MAP KPA 0
COOLANT F -40
IAT F -40
SECOND AIR N/A
ST FTRM1 % -100.6
LT FTRM1 % -100.6
VEH SPEED MPH 0
REL FRP KPA 0.00
FUEL SYS 1 N/A
FUEL SYS 2 N/A
O2S11 V 0.000
ST FTRM11 % -100.6
O2S12 V 0.000
O2S13 V 0.000
MIL DIST mi 0
OBD2 STAT N/A
Frame 0 Time -25.9
Wilecoyote
A smart man only believes half of what he hears, a wise man knows which half
wilecoyote is offline
Old 09-13-2009, 11:10 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Memberpenguin Excellent Standing Member
I see way too much information at this point of the diagnosis (The hazard of modern computer tools).
P0171
Have you tried cleaning the MAF?
http://www.obd-codes.com/p0171
penguin is offline
Old 09-13-2009, 11:15 PM   #3
wilecoyote
Fan#: 55318
I've cleaned the MAF twice. Changed the fuel filter. Run fuel cleaner through the system.
Wilecoyote
Old 09-13-2009, 11:16 PM   #4
2wheeladict
2wheeladict's Avatar
Fan#: 69029
What I Drive: 2005 focus zx4, 2003 cbr f4i
FF Reputation: 8 2wheeladict Good Standing Member
i can see for one your fuel trims are WACK. ill give a good look at it
2005 ZX4: CAI, FRPP, eibach sportlines, hids
1983 kawasaki KZ550 cafe project
4 wheels move the body, 2 wheels move the SOUL
2wheeladict is offline
Old 09-13-2009, 11:20 PM   #5
wilecoyote
Fan#: 55318
What should the numbers read for normal. Does it mean there is a vacuum leak.
Wilecoyote
Old 09-13-2009, 11:21 PM   #6
2wheeladict
Fan#: 69029
wile, do you have aim? id like to be able to talk to you while im reading these numbers.
Old 09-14-2009, 12:26 AM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Who wants to bet that the TPS is broken?
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 09-14-2009, 12:53 AM   #8
2wheeladict
Fan#: 69029
no, its at idle the whole time, he reved it once during the recording. the maf is reading more incoming air than it should be at hot idle, and the post o2 is off i think.
Old 09-14-2009, 09:29 AM   #9
justjake
Fan#: 60533
What I Drive: 2001 zx3
FF Reputation: 7 justjake Good Standing Member
Looks like your fuel trim is all over the place. You want to be as close to stoic as possible. Stoic would be a reading of 0.
You're TPS seems to be a li'l wonky too if you're at idle.
Also the p0171 code, you should be checking your 02.
justjake is offline
Old 09-14-2009, 12:14 PM   #10
wilecoyote
Fan#: 55318
2wheeladict...I'm not sure if my unit has aim. It's a Actron cp9180. If you want me to give you a call let me know. I'm also getting a high idle, around 1500 to 1200 when I push in the clutch when I coming to a stop. I have a hard code of P0171 and soft codes P0300, 301, 302, 316.
Wilecoyote
