How to re-install the serpentine belt - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-01-2004, 11:04 PM   #1
j.pavlov
Fan#: 11227
What I Drive: 2002 Silver SVT
FF Reputation: 1 j.pavlov Good Standing Member
I just finished installing underdrive pulleys on my 2002 SVT Focus. However, try as I might, I can not get the belt back on. I'm sure that I'm installing the belt properly as I matched up the route on our 2001 ZX3. Is there a way to loosen the belt tensioner? The main bolt (15 MM I think) just pulls of the the entire pulley.
Any help or suggestions would be greatly appreciated as I'm now without a car!
-JP
j.pavlov is offline
Old 08-02-2004, 12:26 AM   #2
mr.squatch
mr.squatch's Avatar
Fan#: 4112
What I Drive: 02 zx3
FF Reputation: 1 mr.squatch Good Standing Member
The tensioner is a pain, very difficult without the right long tool. easiest way we've found is to jack up the passenger side and take off the wheel. take off the lower pulley cover (2 10mm bolts, black piece from underneath), then find the tensioner and push it up with the heel of your hand from underneath while someone else pulls it onto the last pulley. Easiest to do upper front-most pulley last. Hope this helps,
g
mr.squatch is offline
Old 08-02-2004, 12:33 AM   #3
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
r u sure you're pulling on the correct bolt of the tensioner assy?
Mike
just visiting now....
whiteboyslo is offline
Old 08-02-2004, 10:16 PM   #4
joshandlauri
Fan#: 11168
What I Drive: Focus ZX3 pitch black
FF Reputation: 1 joshandlauri Good Standing Member
hi
i just did this, i fought with it for a while. this s how i did it. i went to sears and got the longest 15mm wrench i could buy ($13) i routed the belt over everything buy the ps pump, i grabbed the pulley bolt and moved it toward the firewall until i could move no more, i had a friend use a pry bar and hold it in place. i took the wrench off and regripped the bolt again going toward the firewall until he got it around the ps pump pulley. what a bitch!!!!
hope this helps
josh
josh
joshandlauri is offline
Old 08-02-2004, 10:19 PM   #5
EuroZX3
EuroZX3's Avatar
Fan#: 39
What I Drive: 05 Black Scion TC
FF Reputation: 1 EuroZX3 Good Standing Member
Buy-Sell-Trade Rating: (7)
your not supposed to loosen the bolt on the tensioner pulley. its spring loaded, just put a wrench on there, and push it, the pulley will move, slip the belt on, and then let the tensioner go back in place.
Originally posted by darkpuppet
needs more cowbell
EuroZX3 is offline
Old 08-03-2004, 11:41 PM   #6
j.pavlov
Fan#: 11227
Ok, I finally got the belt back on. Like everyone said, this definitely a two man job. One of us got under the car and pushed the belt tensioner up (at first it didn't even move!) and the other pulled hard to put the belt over the upper most pulley.
It was worth it as I installed the focus central underdrive pulleys and noticed a nice performance boost. My tale of woe for changing the small alternator pulley is a story for another time...
As a wise man once said, your two choices are to accelerate or brake...
j.pavlov is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Can a motor mount cause a serpentine belt to fray? jdl_131 General Technical Chat 5 06-20-2009 06:57 AM
serpentine belt question TBIDDY83 SVT Performance (2002-2004) 5 05-15-2008 08:04 PM
FIRST START after Procharger install!!! Slight belt problem.... itbparada General Forced Induction 4 07-01-2007 05:10 PM
serpentine belt zx5go General Technical Chat 4 11-28-2005 11:25 AM
