Hood Insulation - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-20-2003, 01:23 PM   #1
oldman
Fan#: 816
What I Drive: 2003 SE PZEV ATX
FF Reputation: 1 oldman Good Standing Member
Hood Insulation
I've got a '03 PZEV SE. I've seen other topics about the need for hood insulation since the engines run hot. Is this true with the PZEV ? Mine has no insulation-does this mean my hood paint will be a mess in a few years ?
oldman is offline
Old 10-20-2003, 02:03 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
I thought it was more of a NVH item. My 2001 ZX3 didn't have hood insulation (it was phased out mid 2001), and after 30,000 miles, its still fine.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 10-20-2003, 02:08 PM   #3
FocusOnThis
Fan#: 984
What I Drive: 2 built Honda Civics/pearl white-SHOW & graphite grey-GO/Focus ZX3 daily driver
FF Reputation: 1 FocusOnThis Good Standing Member
If you're concerned, try installing dyno mat (used to line trunks when you have a sound system to keep trunk from vibrating) It works great for heat too. I have carbon fiber hoods on both cars and to keep the hoods from warping from heat and protect the custom paint work on the edges of the hoods, I've installed the dyno-mat. NO warp, no messy paint
It's hard to drive at the limit, but it's harder to know where the limits are.
FocusOnThis is offline
Old 10-20-2003, 02:13 PM   #4
guerro
guerro's Avatar
Fan#: 339
What I Drive: 2013 Focus ST Oxford White
FF Reputation: 1 guerro Good Standing Member
I would think that if there was a need for insulation on the inside of the hood, Ford would have put it there. I highly doubt you will have any problems with your paint. I am sure Ford researched this when testing the Focus. I see no reason to give Ford a way out of warranty coverage if you have put something on your hood that doesnt belong there. I am also pretty sure that if you do have a problem with the paint on your hood, Ford will fix it for you.
Oh yeah, its Dynamat. http://www.dynamat.com/
Unless you bought some kind of copy of Dynamat.
Annoy a Liberal: Work hard, succeed, be happy.
guerro is offline
Old 11-01-2003, 08:54 AM   #5
teddyrob
Fan#: 1500
FF Reputation: 3 teddyrob Good Standing Member
mine has no hood padding and personally i think it looks awesome! it looks like a racer.
teddyrob is offline
Old 11-01-2003, 10:12 AM   #6
01CobaltTiburon
01CobaltTiburon's Avatar
Fan#: 96
What I Drive: 2001 Hyundai Tiburon
FF Reputation: 1 01CobaltTiburon Good Standing Member
Here's my 2 cents on this subject.
The PZEV may run hot, but there is no way that it can rut hot enough, under normal conditions, to cause any damage to the paint on the hood, even long term.
I used to have a '94 Mercury Sable that had a severe overheating experience, and I mean SEVERE, like, just short of catching fire. It was a 108 degree day one summer and the water pump gave out. I was in the middle of nowhere, with no cell phone, and someone else's kid in the car with me... so I continued driving to the nearest gas station, which was like 6 miles. (I should also mention that the car was under an extended warranty) By the time we got there, the cooling system was dry as a bone, and the heat coming off the engine was unbelievable. It ended up warping the aluminum heads, etc etc. My point is... even with this kind of extreme heat, the only damage done to the paint was a dime sized area directly over the engine that kind of did that paint cracking thing. It wasn't even noticeable unless you knew it was there.
So I seriously doubt that one of these engines is going to cause any kind of damage to the paint on your hood because of a lack of insulation, at least not without some kind of engine malfunction first. So just relax. If Ford thought it needed insulation, it would have provided insulation.
I love this Tiburon but would give it up in a heartbeat to have my 2002 ZX5 back...
01CobaltTiburon is offline
Old 11-01-2003, 10:15 AM   #7
fokuzsport
Fan#: 418
What I Drive: Pitch black FoKuZ zx3
Points 35,712, Level 100
Points: 35,712, Level: 100 Points: 35,712, Level: 100 Points: 35,712, Level: 100
Level Up 0% Completed
FF Reputation: 1 fokuzsport Good Standing Member
a racer?
fokuzsport is offline
Old 11-01-2003, 01:00 PM   #8
teddyrob
Fan#: 1500
by racer i just mean it looks bare bones and light. the way its all skeletonized looks cool.
teddyrob is offline
Old 11-01-2003, 02:46 PM   #9
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
I like mine without the liner too.
Egz is offline
Old 12-31-2012, 10:43 PM   #10
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
Points 26,532, Level 97
Points: 26,532, Level: 97 Points: 26,532, Level: 97 Points: 26,532, Level: 97
Level Up 19% Completed
FF Reputation: 1 DidHeFocus? Good Standing Member
I thought it was worth reviving this old thread.
Mine is a 2003 with 2.3 pzev and I'm getting a cracking/spitting of the paint above the exhaust manifold. I believe that insulation would have avoided this.
It's been garaged since I got it new and the paint is immaculate everywhere else. The small cracks are too small to show up on photos or I would have posted some.
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Similar Threads
Need Hood Insulation NCFazer SVT Performance (2002-2004) 23 04-18-2006 11:35 PM
VIS OEM Hood Problem *Update* Stephs2.0Focus MK1 Focus 10 01-04-2006 12:18 PM
Hood Pins osiris_vdc MK1 Focus 1 08-15-2005 01:53 PM
Hood Companies S2 MK1 Focus 1 06-20-2005 09:57 AM
CF hood recieved - Good & Bad news dwdgsi03 MK1 Focus 29 03-18-2005 08:03 PM
