pedal travel issue after rear disc conversion? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 09-04-2009, 10:39 AM   #11
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
We know that many people have replaced rear drums with rotors without the mentioned problem. I'm guessing, that not many of those (if any) had ABS. You mentioned you removed the ABS system. I don't know what's involved in doing so, having never done it, but I'm guessing some new plumbing was in order to replace what was removed or bypassed. Was this properly sized? Is it all solid tubing? If it were me, and the ABS replacement plumbing is correct, I'd focus my attention to the master cylinder and the bias bar.
Geezer is offline
Old 09-04-2009, 10:42 AM   #12
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 24,566, Level 95
Points: 24,566, Level: 95 Points: 24,566, Level: 95 Points: 24,566, Level: 95
Level Up 22% Completed
FF Reputation: 47 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Originally Posted by runfocusrun View Post
Isn't there a simple way to just adjust the pedal ?? I'm just guessing here. Also IMO if you have OEM ABS why change for a non ABS, just my .02c's
SCCA class rules, some allow ABS, some don't.
I'm not a big fan of ABS for competition events, it's a great feature on the road for emergency manouvers or unexpected road conditions, but it has only marginal benefits on track.
Even if I were running a class that allowed it, I'd rather ditch the 10 lbs by removing the pump/valve block.
As for the pedal adjustment, there is no simple adjustment. and it's not just the pedal height that's a problem, it's the total distance of travel.
If I adjust it to have the depressed position higher, then it's at rest location would be that much higher too...
I've already lowered the throttle pedal a bit by adjusting the cable mounting, but if I have to correct the brake pedal, it will be a bit more complicated.
If I don't get any better ideas on this post, I'll probably try modifyng the pivot points on the pedal to move the attachment point for the pedal rod that actuates the booster/master cyl.
Anyone have an extra brake pedal floating around?
213 whp / 160 wtq D23 NA with stock intake and TB.
Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap.
I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
tb1999 is online now
Similar Threads
Rear disc conversion on wagon? Focus_Happy Brakes, Suspension & Body Chassis 4 05-08-2009 11:07 AM
rear disc conversion.... lolocaust Brakes, Suspension & Body Chassis 14 11-15-2007 10:01 AM
Finished Rear disc conversion.....FINALLY !! *pics* yachtmechanic Brakes, Suspension & Body Chassis 18 03-15-2007 07:56 PM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
