Need help diablo Mafia adjustments - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-01-2009, 09:09 PM   #1
CatMostFeared
FocusXtreme
CatMostFeared's Avatar
Fan#: 20987
What I Drive: Wicked 2000 Turbo Zx3
Points 22,756, Level 93
Points: 22,756, Level: 93 Points: 22,756, Level: 93 Points: 22,756, Level: 93
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 20 CatMostFeared Great Standing Member
Buy-Sell-Trade Rating: (23)
Exclamation Need help diablo Mafia adjustments
Ok my mafia was set on 2 and now I need to mve it up to setting 3 for 60lb injectors.
This is in my instructions
The best way to use the MAFia is to tune the vehicle for idle and cruise and lower RPM ranges at
wide open throttle rpm before you install the MAFia.
Once you have the car running properly install the mafia and set it to 0.
Start the vehicle and make sure that it runs just like it did before the installation of the mafia.
(check fuel trims and load)
Once you have checked to make sure the vehicle runs the same, you can set the mafia to the
desired setting to support the horsepower you intend to make.
Make sure the key is off whenever you change the setting on the MAFia.
You will now apply the necessary changes to your tune to accommodate for the new setting on the
MAFia. This can be accomplished two ways.
Method One – works for all tuning software
Using the settings chart, reduce the following parameters in your software by the correction factor.
Fuel Injector Low Slope
Fuel Injector High Slope
Air Mass Displacement of one cylinder
Setting Correction Factor Range Notes
0 No tuning required Stock Stock/No Change
1 No tuning required Stock minus 5% Leans Signal
2 24% or multiply by .76 5.5v – 5v or .90 Tuning Required
3 41% or multiply by .59 6v-5v or .83 Tuning Required
4 53% or multiply by .47 6.5v-5v or .77 Tuning Required
5 62% or multiply by .38 7v -5v or .71 Tuning Required
6 70% or multiply by .30 7.5v – 5v or .67 Tuning Required
7 No tuning required Stock plus 5% Richens Signal
For example
Original tune has a value of 40 for the Fuel Injector Low Slope. You install the MAFia on setting
2. Your new setting for Fuel Injector Low Slope will be 40 x .76 = 30.4
I believe this is were I make the adjustments and these are the settings for the #2 setting
2000 Turbo ZX3
CatMostFeared is offline
Old 09-01-2009, 10:54 PM   #2
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
you also need to change engine displacement like it says...
I have also heard of people just tuning the mtf while its on the setting you will use, and leaving the injector and displacement settings alone. Not sure if this is correct?
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 09-02-2009, 01:15 AM   #3
CatMostFeared
FocusXtreme
Fan#: 20987
well if all else fails call Tom. I had to change Fuel Injector Low Slope,
Fuel Injector High Slope, and engine displacement.
Its almost like starting the tune over again so I'll be doing some data logging and tuning tomorrow
2000 Turbo ZX3
Old 09-02-2009, 07:56 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,508, Level 100
Points: 52,508, Level: 100 Points: 52,508, Level: 100 Points: 52,508, Level: 100
Level Up 0% Completed
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
Buy-Sell-Trade Rating: (28)
You didnt tell me you were already set to 2 , what we did will have to be changed some , I thought you were on 0
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Similar Threads
For Sale: Diablo Mafia egbertnr Archive 8 08-12-2009 10:28 PM
Warning Diablo MAFia users having intermittent AFR problems xp0s3d General Forced Induction 5 01-29-2008 07:57 PM
Q? on Diablo MAFia SpeedOften General Forced Induction 7 10-18-2006 08:34 AM
Diablo MAFia Correcting more misinformation 1turbofocus General Forced Induction 23 12-26-2005 08:35 AM
anyone using a Diablo MAF'ia with the SCT PRP?? hurtinfocus General Forced Induction 1 09-08-2005 09:37 PM
