New Predator tune from Tom in the SVT! (I think!) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-01-2009, 01:51 PM   #1
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
What I Drive: '02 Sonic Blue SVT Focus, '03 Wagon
Points 5,041, Level 45
Points: 5,041, Level: 45 Points: 5,041, Level: 45 Points: 5,041, Level: 45
Level Up 46% Completed
FF Reputation: 34 WuNgUnSVT Great Standing Member
...had a HELL of a time trying to install it! While trying to back up the original, it would always stop at various percentages.
Took 4 hours and probably 15 attempts, but it finally backed it up...only to fail on the write/flash!
So started over...finally got it to flash...
Go for a drive, and...nothing. No change...can't feel/hear any difference what so ever!
Tom is certain the tune didn't 'take'...
Mike from Diablo says if the flash reads that the tune is installed, it's installed...and that's what it tells me.
I reflashed it since, and tested again...no change.
BTW, pulled #46 fuse (ABS) whilke flashing...reliable now.
The only conclusion I can come up with is, maybe Tom accidently loaded a stock tune? Or forgot to load a tune altogether?
The file on the Predator is simply called 'Predator Performance Tune'...
Is that the stock tune from Diablo maybe?? Or does Tom overwrite this file with his own?
Tom is unavailable at the moment...been trying to get ahold of him...
Originally Posted by MattyKrackSVT View Post
...go threw your posts and see who can't spell retard...
WuNgUnSVT is offline
Old 09-01-2009, 06:35 PM   #2
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
Turns out, what with my push button starter, the first few attempt to flash the car were WITHOUT the key in the cylinder (PATS), as I'm able to fire up the ACC/IGN without the key by holding down my start button for 2 seconds...
After talking with Tom, and Tom talking with Mike at Diablo, it would seem this keyless process most likely wiped Tom's tune from the flasher!!
Thank God Tom is here to help, else I'd be stuck with the crappy Predator/SVT tune!
Old 09-02-2009, 12:11 AM   #3
focusguy87
I AM DA FOCI FANATIC
focusguy87's Avatar
Fan#: 40962
What I Drive: 03 Red EvO & 03 TURBO SVT
FF Reputation: 9 focusguy87 Good Standing Member
Buy-Sell-Trade Rating: (6)
Tom has ALWAYS helped me as much as he can whenever I had issues with the Predator.
I was going to say it should say Custom Tune, Not predator Tune
FOR SALE,
2003 Turbo SVT ZX5 318WHP (SOLD)
2003 Evolution 8 320AWHP
focusguy87 is offline
Old 09-02-2009, 08:19 AM   #4
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
All fixed! Tom was able to email me my tune..I uploaded it to the Predator and flashed the car...
And your right, 'Custom tune' is the one!
Right away I noticed the higher idle and smoother shifting. Took 'er out on the highway for some WOT, 7200rpm pulls...maybe not quite as impresive, but likely due to the fact that the power delivery has been smoothed out...
In all honesty, if I had to spend that kinda money on a mod again ($500 CDN after buying cables/adapters), it likely wouldn't be for a tune...
Then again, it'll probably take the ECU a few cycles to 'settle in'...I'll report back any changes...
Old 09-02-2009, 10:10 AM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,935, Level 100
Points: 51,935, Level: 100 Points: 51,935, Level: 100 Points: 51,935, Level: 100
Level Up 0% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
Buy-Sell-Trade Rating: (28)
Dont blame the tune/Predator for the issues with tune loading , If you had mentioned to Mike at first about the no key/push button start he would of told you what to do right off the bat
Security/alarms really mess with the PATS and will keep tunes from loading
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-02-2009, 11:11 AM   #6
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
Yeah, I admit the first few attempts were without the key...but the 15 or so subsequent attempts were WITH the key in the car.
When I started talking with Mike at Diablo, it was LONG after I started attempting flashing with the key in the car. I figured it was a no-issue at that point, considering it didn't make any difference if the key was in or not with regards to the backing-up...it's was failing every time. I still think it was blind luck that it actually made it thru 100% when it did.
This was my first experience with a flasher...whether the keyless flashing up the Predator for the later attempts with the key, I honestly doubt it...but it wasn't a pleasant experience.
Once, however, I finally got the backup in the Predator, flashing was a piece of cake...Mike did recommend pulling the ABS fuse as well, which I did.
My alarm doesn't use a PATS bypass or anything either...as far as the car is concerned, the key is still needed for starting.
I never pointed blame to you Tom, or the tune...Mike only assumed that you might of accidently uploaded a stock tune, or forgot the tune altogether. You told me that when the Predator has a bad flash, it removes the custom tune and defaults back to the Diablo tune, which is what I initially flashed...
I can accept that, no problems...
You were there to 'right the ship' and get your tune back into my car, and it's much appreciated!
I'm pretty sure now though, I'm never going to restore the original tune back in the car, for fear of the backing-up going mental again!
Also, while out driving today, the car feels even smoother...and not just the shifting. Steady state throttle, tip-in, decelleration and acceleration are BUTTERY smooth...it's almost like I have an electric motor under the hood! No hiccups, surges, stutters or burps...
Thanks again Tom!!
Old 09-02-2009, 11:17 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
Godd , glad its getting better
I am 100% sure that your issues loading the tune are somehow related to the security/push button , as long as you pull the fuse you will be fine going back to stock or updating to new tunes as needed
Let me know if I can help further
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-02-2009, 01:21 PM   #8
kamann
Fan#: 6269
What I Drive: 02 Black SVT Focus
FF Reputation: 2 kamann Good Standing Member
Thanks again Tom!!
Wow I want a tune from Tom now. That sounds really nice.
kamann is offline
Old 09-02-2009, 02:12 PM   #9
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
Hey Tom...do we get any 'referal points' to redeem at your shop?? j/k
I was surprised with the fast shipping as well...it got here (Canada) sooner than another package I ordered a few days BEFORE I ordered the Predator...
He was also available 'one on one' thru IM when I was having issues.
Going up to Goderich this afternoon to look at a house...over an hours drive each way...and I'm looking forward to the drive!
Old 09-02-2009, 02:41 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
Yes you get 6 referal points LOL Good at any Hooters just go in and grab what you want LOL
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Similar Threads
"The Official/Unofficial SVT Header Conversion Guide" svtguy88 ZETEC Performance (2000-2004) 110 07-05-2013 02:54 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 03:04 PM
SVT is Dead lduran Ford Focus & General Car Chat 149 03-18-2006 01:48 PM
Damn I hope things work out for SVT! TORQUERULES Ford Focus & General Car Chat 7 12-16-2004 12:49 PM
