cooling fan sensor? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-31-2004, 11:51 PM   #1
focusowner
focusowner's Avatar
Fan#: 10363
What I Drive: 2001 red zx3
FF Reputation: 1 focusowner Good Standing Member
cooling fan sensor?
Im not sure if anyone has posted this , but just yesterday my car temp. gauge was showing
hot,i mean almost to the red mark.So i pulled over and looked under the hood.I had fluid and
everything else looked ok.Then i noticed my fan wasent working.Does anyone know how
much the sensor would cost ,and where would be the best place to get one?thanks
zx3 4 life
focusowner is offline
Old 08-01-2004, 12:21 PM   #2
BornAgainFordOwner
Fan#: 9408
What I Drive: 2004 Liquid Grey ZX3 PZEV 5Sp.
FF Reputation: 7 BornAgainFordOwner Good Standing Member
If your temp gauge is working, the temp sensor is probably OK. Depending upon whether you have one or two cooling fans, there are fuses and relays in the Battery Junction Box. At least that's what my '04 manual shows. Of course, the fan motor could be bad also.
BornAgainFordOwner is offline
Old 08-01-2004, 05:11 PM   #3
greystealth
greystealth's Avatar
Fan#: 1416
What I Drive: Ford Focus ZX3
FF Reputation: 1 greystealth Good Standing Member
I'm dealing with this problem right now. My fan wasn't working, only when my a/c was on it would turn on but only on high speed. I pulled out the resistor in the cooling fan and noticed that the plug (harness) that goes into the sensor was all fried up. Thats why my fans werent working. Dont know why this happened, i guess water must have gotten into it. I went to for and ordered a new sensor for 30.00 and as for the harness i just went to a local junk yard and pulled like 3 of them from a focus. Hope this helps. Here are some pics
Domestic Disturbance Houston member
greystealth is offline
Old 08-02-2004, 05:17 PM   #4
focusowner
focusowner's Avatar
Fan#: 10363
cooling fan sensor
Thanks man.I called my local ford dealership and they said it could be the fan.
Im gonna take a closer look and see if mine is fried too.thanks again.
zx3 4 life
Old 03-20-2005, 10:16 PM   #5
wayne1ca
Fan#: 20267
What I Drive: 2000 focus
FF Reputation: 1 wayne1ca Good Standing Member
I will answer my question from one of my previous posts. Cylinder head temperature sensor (cht) resistence @70 deg about 29K ohms @ 212 Deg or boiling about 2K ohms. I checked a new one and the one I removed. Unfortunitely this was not the problem. This can be checked on the vehicle before removing. (wish I would have had this info before I bought a new sensor) When I turn the a/c on only one fan turns on. I have checked the resistor and the connection, They are fine. When I jumper 12 volts into the fans one at a time they work fine. Looks like I will have to remove the fans and check all the wires. Anyone got any ideas?
wayne1ca is offline
Old 03-20-2005, 10:23 PM   #6
sidney61199
sidney61199's Avatar
Fan#: 7904
What I Drive: 2002 Black Focus SVT
FF Reputation: 1 sidney61199 Good Standing Member
I'm glad this subject was brought up. I wanted to know if anyone has tried those adjustable cooling fan kits sold at auto stores? There like $20 and like they say you can adjust the temp at which your fan comes on at. Has anyone tried or used one of these kits? I don't have any problem with over heating but my fan has never came on to my knowledge. I'm sure it has and I was not aware but after almost a year and a half of owning my car I have never heard my fan come on once so I was thinking about getting one of these kits. Thanks for any info.
sidney61199 is offline
Old 03-20-2005, 10:31 PM   #7
wayne1ca
Fan#: 20267
If your temp gauge is not getting over to the hot side, I was wondering why you would want to put in an adjustable kit.??
wayne1ca is offline
Old 03-20-2005, 11:51 PM   #8
sidney61199
Fan#: 7904
True, I just thought that since my fan was there I might as well use it and the kit was only $20 but I thought about your point also.
Old 03-21-2005, 07:57 AM   #9
soffiler
Registered User
soffiler's Avatar
Fan#: 372
What I Drive: '03 ZX3 PZEV 5-spd Twilight Blue; '97 F-250 4x4 w/ 351 V8 & AT
FF Reputation: 1 soffiler Good Standing Member
Relay. Located in battery junction box.
soffiler is offline
Old 03-21-2005, 11:49 AM   #10
kdsatucf
Fan#: 20032
What I Drive: 2002 liquid grey ZX3
FF Reputation: 1 kdsatucf Good Standing Member
I put up a post last week with the same problem you are having. It was tiltled Overheating on Highway. My car almost went into the red in a traffic jam on the highway and I hit the A/C to bring the guage back to the middle. It was also 60 degrees at the time, not your usual hot Florida weather.
Ford had my car for 2 days (still under warranty at the time) and couldn't find any bad senors or relays. They also couldn't recreate the problem and I watched as the car's fan worked properly. I am just waiting for it to happen again and I don't know what to do.
kdsatucf is offline
Similar Threads
Ford Focus Cooling Fan problem defies all logic diagnostics JJDetroit General Technical Chat 21 05-16-2012 05:18 PM
Cooling fan issue ibanezjeepguy General Technical Chat 6 04-01-2010 04:44 PM
i think it is the dpfe? zx32nr General Technical Chat 27 08-27-2009 07:50 PM
Could use some help please? Iceberg General Technical Chat 13 06-30-2009 10:26 PM
Cooling Fan - On from Cold..??!! MustangMark General Technical Chat 6 12-17-2007 04:00 PM
