SVT cylinder head on a standard zetec block - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-20-2014, 07:51 PM   #51
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by iminhell View Post
Head is shaved 0.045".
Cams, ... ... I can't recall exactly. I set them a different way that I never found on any Focus or zetec site. See if I can remember here.
I went by lift @ TDC --> http://www.catcams.com/products/camshafts/datasheet.aspx?ENGINE_id=163&CAMSETUP_id=543
Or at least used that as a baseline.
I downloaded a picture of a degree wheel and printed it to a CD. Used one of those sticky CD label things.
--Good degree wheel picture --> http://www.xs650.com/forum/picture.php?albumid=1438&pictureid=14776
Made a little pointer out of a wire.
Used a cam bolt and couple washers to hold the CD in place.
Rotated the cam and watched my dial caliper until I got about to where the Cat specs were.
Or something similar to that.
Then I had a baseline to adjust the cam gears.
Trying to use the cam bar and one of the cam gears at full advance/retard and bringing it back to zero just never worked for me. Or at least no as well as degreeing the cam did.
And when I had the parts out I made this --> http://www.focusfanatics.com/forum/showthread.php?t=259167 (which you've probably found)
basically, I didn't use any of the cam tools.
Also, i find TDC by forcing #2 to BDC. If the cams aren't in the head, the valves are closed. So I used air pressure. Works great.
This means I'm totally out of time. I'll read all of these and come back was hoping for help from Tom and you.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is online now
Old 02-20-2014, 08:01 PM   #52
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
Actually I should ask this too,
What pistons are you on?
Keep in mind that I'm on stock zetec pistons/rods. And I have very limited, IMO, valve movement / interference. I can almost move the cam gear lock to lock W/O touching a valve to piston TDC. Almost.
Being you're shaved a bit more, keep the valve to piston contact in mind. Always rotate the engine by hand first.
iminhell is offline
Old 02-20-2014, 08:18 PM   #53
Mother Focus
Fan#: 73292
Probe 9:1's, trying to wake up the turbo sooner and have more power @ 20psi and be finally done with it. Thanks for the heads up
PTE 6262CEA
Old 02-20-2014, 11:00 PM   #54
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
This is very easy , use a compression gauge and get a base then move the cam gears 1-2 marks and check compression again , your not going to hit the pistons if your close on the cams and there install , if the compression comes up go 1 - 2 marks more till it stops , I have done this dozens of times and never bent a valve , you should see the compression come up to about mid 190`s
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-21-2014, 08:06 AM   #55
Mother Focus
Fan#: 73292
Thanks! That's exactly the number I was hoping. Goin to recalibrate the head and try again.
PTE 6262CEA
Old 02-27-2014, 08:02 PM   #56
Mother Focus
Fan#: 73292
Advance 12 degrees in the intake and retarded 2 on the exhaust got me to 190's. That's full advance in the cam gear, to go further would had to time it locking it in retard.
PTE 6262CEA
Old 02-27-2014, 08:10 PM   #57
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 11%
That's about what I'd found too. And is why I went to degreeing instead.
Ended up that I have both gears zero'd and can adjust like I could on a normal zetec. Lots of extra work, but the result was what I wanted.
It ran good the way you are at now. but it was that 'what if' that got to me and eventually I couldn't take not knowing. And now that I know, it was off some and I was loosing some power.
iminhell is offline
Old 02-27-2014, 10:43 PM   #58
Mother Focus
Fan#: 73292
Idle and starting is so much better, was concerned about interference and too much timing with boost. How much cranking compresion were you able at what degree?
PTE 6262CEA
Old 02-27-2014, 11:03 PM   #59
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 11%
You can't relate the cam timing on the gear to mine. Or even what I got the similar way you set yours. As you already know, 1* makes a difference.
Exact same process, then you can compare results. Otherwise it's all meaningless.
Basically, if it seems to run well and you're happy,,, let it be. If you get that bug like I did, degree the cams.
Keep in mind that the VCT adjust the cam about 40*.
iminhell is offline
Old 02-27-2014, 11:06 PM   #60
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
You need to go further on the Int cam gear, there is more to get , you will have to loosen the Intake cam gear and turn the cam till your back to " 0 "
the do your cranking compression again , this only gets you close you will need to dyno tune/adjust them
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Similar Threads
Engine Light zummracer General Technical Chat 18 12-10-2013 10:08 PM
The Ultimate 03-09 Focus Thread, SUPER LARGE AMOUNTS OF INFO. honhon DURATEC Performance (2008-2011) 59 08-04-2013 11:41 PM
E-85, 12:1 compression, zetec block w/ ported SVT head ... tune? iminhell Focus-Power Tuning 3 04-25-2009 05:31 PM
SVT Block with non-SVT Head mpsii ZETEC Performance (2000-2004) 2 07-29-2008 07:21 AM
