SVT cylinder head on a standard zetec block - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2010, 05:41 PM   #31
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
Plug design differences. I'd like to see what the NGK racing plugs can do.
The G style.
Running the NGK LZTR5A right now.
OH, you're not playing dumb ...
iminhell is offline
Old 06-05-2010, 09:38 PM   #32
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,844, Level 100
Points: 51,844, Level: 100 Points: 51,844, Level: 100 Points: 51,844, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
I am not a fan of NGK and think there one of the BIGGEST POS plugs on the market from many years of testing them on the dyno , dirt track and drag strip
I doubt seriously there colder then the SP463 Motorcrafts , a quick way to tell is measure the porcelain height inside the plug below the wire and if its longer then the 463 then there hotter , If the porcelian is shorted then there colder , what I have found is the NGK is about 4 steps hotter then everyone else but they list them as 2 colder
The "G" is nothing more then a cut back wire and you can do that to any plug , I was doing it on my race dirt bikes in 1979 and it helps , Autolite started doing it again in 1998 with the AR series plugs that I did a Mag artical on and Autolite used that and the dyno we did of many plugs as there advertise ment for many years
For my high HP Turbo Focus I took some AR Autolites and remachined them to .980 and used then and they worked great but was costly to do
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 06-06-2010, 09:16 AM   #33
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
What I Drive: '02 Sonic Blue SVT Focus, '03 Wagon
Points 5,041, Level 45
Points: 5,041, Level: 45 Points: 5,041, Level: 45 Points: 5,041, Level: 45
Level Up 46% Completed
FF Reputation: 34 WuNgUnSVT Great Standing Member
Those "G" cut down plugs also have an interesting 'squish band' conical shape to them as well...
I guess that'll either concentrate some mixture around the spark for enhanced flame speed, or isolate the rest of the combustion chamber from the spark!
I've run NGK's in my bikes for over 20 years...2 and 4 stroke...you can do a lot worse!
Weird about the heat ranges though!
Originally Posted by MattyKrackSVT View Post
...go threw your posts and see who can't spell retard...
WuNgUnSVT is offline
Old 09-30-2010, 03:03 PM   #34
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
My screenname is CaysE, not CasyE.
Did you ever run into issues with the cooling setup?
CaysE is offline
Old 10-22-2010, 10:13 PM   #35
nlsolja123
Fan#: 18854
FF Reputation: 1 nlsolja123 Good Standing Member
so someone bent 3-4 valves on a stock block and svt head combo???? i saw in first coupls posts
nlsolja123 is offline
Old 12-22-2011, 07:40 AM   #36
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
If I run aftermarket (Crower) cams, do I still need the VCT eliminator kit? Are the front cam caps the same in the SVT head or can I interchange the regular Zetec ones if they are different?
Thanks,
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 12-22-2011, 07:55 AM   #37
bennyfocus
bennyfocus's Avatar
Fan#: 50465
What I Drive: 2001 Blue Zx3
Points 1,211, Level 19
Points: 1,211, Level: 19 Points: 1,211, Level: 19 Points: 1,211, Level: 19
Level Up 11% Completed
FF Reputation: 6 bennyfocus Good Standing Member
I dont think anyone makes aftermarket cams for the svt head if thats what you are getting at. The exhaust cam and everything with it should be interchangeable between the svt and anything for the zetec however the intake cam on the svt is way different. Its 12degrees off, the front cap is different, and the cam sensor wheel is different.
If you want to use the svt head on a zetec cliff notes are as follows.
Svt head, vct eliminator, adjustable gears, alternator bracket, svt water outlet and temp sensor. Then you need to decide if you are going to try and make a DSI svt intake work or drop some cash on a single plane aftermarket intake manifold for the svt head.
Thanks,
bennyfocus is offline
Old 12-22-2011, 08:02 AM   #38
teamDFL
teamDFL's Avatar
Fan#: 92060
Thanks. I am looking for a way to use the head without having to do all the extra work, even if it less than optimal. Basically, what is the minimum I need do to get that high flow casting to work on a Zetec. Would using Zetec cams (aftermarket) not fixing the timing problem?
A used SVT head is cheaper than any ported Zetec head, but if I have to add all this extra junk, it probably won't be.
teamDFL is offline
Old 12-22-2011, 08:16 AM   #39
bennyfocus
bennyfocus's Avatar
Fan#: 50465
Many people say its not worth the extra effort and to be honest the only reason I did it was because I got a smoking deal on a built svt head that was ported and polished with oversized valves and it came with the vct and adjustable gears already on it. The minimum is basiclly that little note at the end of my last post but obviously there are other things you will need also, timing belt, gasket set, change the oil when you are done general jobber stuff.
Basiclly change your alternator bracket and wateroutlet to their svt counterparts, bolt on the head, install the vct delete and gears, get a cheap single plane intake manifold otherwise you need to figure out how to control the svt dual plane intake. On a side note when I say cheap the cheapest intake will most likely cost as much as the svt head you buy. Then basiclly you dont connect the cam sensor or vct solenoid and you need to search the forms for how to set the timing on the intake cam with the vct kit. Its not super hard but gains to cost there are better ways to spend your money and I think most people on here would tell you the same.
Obviously its more involved than that but thats the basics.
Old 12-22-2011, 08:23 AM   #40
teamDFL
teamDFL's Avatar
Fan#: 92060
Thanks for the great reply bennyfocus. Figured it was too good to be true. Bugger.
teamDFL is offline
Similar Threads
Engine Light zummracer General Technical Chat 18 12-10-2013 10:08 PM
The Ultimate 03-09 Focus Thread, SUPER LARGE AMOUNTS OF INFO. honhon DURATEC Performance (2008-2011) 59 08-04-2013 11:41 PM
E-85, 12:1 compression, zetec block w/ ported SVT head ... tune? iminhell Focus-Power Tuning 3 04-25-2009 05:31 PM
SVT Block with non-SVT Head mpsii ZETEC Performance (2000-2004) 2 07-29-2008 07:21 AM
