NA SVTF Tuning: AFR for 93 octane? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-21-2009, 02:50 PM   #1
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 10,941, Level 69
Points: 10,941, Level: 69 Points: 10,941, Level: 69 Points: 10,941, Level: 69
Level Up 23% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
I have an NA SVTF and the PRP. I just figured I'd share what I did "on the way" to work this morning. Maybe it'll help someone understand a bit more about the tuning process.
I'm running 12.8:1 AFR at high loads (except 12.7:1 for >6500 RPM at 0.9-1.0 Load). I only run 93 Octane gas, and almost always from the same reliable gas station.
I was using really safe spark settings to dial in the MTF, and when that was done I started increasing my timing advance via the Borderline Spark Table. I slowly increased the timing, listening for knock during 3rd & 4th gear WOT pulls after each increase. I started close to stock and made it all the way to the MBT spark from SCT's value file (which is oddly different than stock MBT) before I heard any knock!
Using illinipo's AUX-IN knock sensor idea, I was able to hear a little knock on 3rd and 4th gear WOT pulls (0.95 Load at 6400 RPM and 6700-6900 RPM). Reviewing my datalog confirmed it:
Pulling back 1.5 degrees at >4000 RPM and >0.8 Load, and 0.75 degrees at 0.7 load completely erased that knock.
So, tuning pros, "Am I doing it right?" If I'm screwing up anything obvious, please let me know! Both and are more than welcome.
Also, since I'm new to tuning I could really use some fueling advice: 12.8:1 AFR is a bit rich for an NA Zetec with ~10.3:1 CR, right? Should I try going 13:1 AFR or even leaner because I'm on 93 Octane? If there isn't usually much power there then I'd rather just run a little rich for safety against variables like bad gas, etc...
SCT PRP FTMFW!
mellephants is offline
Old 08-21-2009, 03:19 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,320, Level 100
Points: 51,320, Level: 100 Points: 51,320, Level: 100 Points: 51,320, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
There isnt enough info here to make that decision , a log is needed
A good safe AF is about 13.2 I dont go much more then that on the SVT NA 13.0 is safer
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-21-2009, 03:59 PM   #3
mellephants
Fan#: 52400
The screenshot of the datalog is just to show what knock looks like when datalogging the J&S activity.
The AFR question shouldn't need a datalog; I just want a rough goal. I didn't know where most SVTFs stop making power or become unsafe. Sounds like I'll try at least 13.0, and probably wait for a dyno to measure any power gains before going past that.
SCT PRP FTMFW!
Similar Threads
Duratec "Intake Tuning Valve" zxtunerdotcom DURATEC Performance (2003-2007) 41 03-27-2011 11:26 AM
Gas with Ethanol with FI SAFE? FOCUS ZTS General Forced Induction 93 05-04-2007 04:48 AM
Tuning my SVTf TwighlightBlueZx5 SVT Performance (2002-2004) 6 01-21-2006 10:10 PM
Mcnews automotives Diablosport CMR custom tuning focaltech Ford Focus & General Car Chat 18 10-16-2005 06:58 PM
