How-to Hook up AEM UEGO to X3 for Data Logging - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-20-2009, 08:31 PM   #1
gonefhsn
BEWST AGAIN YAY!!!!!
gonefhsn's Avatar
Fan#: 45759
What I Drive: 13 Tangerine Scream ST2,12 RAM 2500
Points 96,869, Level 100
Points: 96,869, Level: 100 Points: 96,869, Level: 100 Points: 96,869, Level: 100
Level Up 0% Completed
FF Reputation: 21 gonefhsn Great Standing Member
Ok I am not sure that this goes here. When I was hooking up my AEM to data log it I searched and searched and found nothing that really helped. So I spent a couple days messing with thing till I got it to work. So here is my Write up.
First get your fire wire cable and whack an end off (needs to be a 6 pin). Now you should have a Red, White, Green, Orange, Black and Blue.
Next go here http://www.tricktuners.com/data_logging_info.htm they have the pin out correct but the colors may be off I performed a continuity check to get the colors correct for the pins.
Once you have the color combination ground out all three Grounds (in my case it was black, orange and red). Then hook up the analog 1 wire (which is pin 3) from the fire wire to the white +5 wire from the AEM gauge.
as you can see I used the green wire from the fire wire cable to the white on the AEM gauge.
You now must go in to your X3 and set up your analog reading.
Plug in your fire wire cable and start the car
once you do that you will see the wide band registering on your X3.
This next portion is if you want to data log using Live Link Software.
Once you have that shut the car off open live link, hook up the Xcal to your laptop using a USB Cable, Turn the key two clicks (do not start car) Hit the little graph up in the top left corner and the system will connect to your car and open the select signals menu select your signals, make sure to select analog 1 so you can get your analog readings. After you made your selections hit ok.
You must select other PIDS or it wont read (at least I did)
Now you must go to the commands tab, select analog equations
Check the block behind Analog 1 EQ, use the drop down to select AEM then apply change, ok.
Now when you start the data logging session if you get this error just hit ok
Start the car you will be able to see your wide band registering in live link with the proper A/F reading.
If you do not set the equation all you will see is a voltage reading. And your tuner needs the proper A/F reading for data logging. Hope this helps you guys out in hooking up your AEM UEGO. Now this may as well work with with other UEGO Gauges but I can not say since I have an AEM one.
gonefhsn is offline
Old 08-20-2009, 11:23 PM   #2
daveyboy
daveyboy's Avatar
Fan#: 61480
What I Drive: 06 Mustang GT, 09 Focus SE
FF Reputation: 7 daveyboy Good Standing Member
Not a bad write up. What made you deside on the AEM as opposed to the others. Just curious.
Hard work never hurt anyone, but why take a chance
Originally Posted by ranger_mclaren View Post
Wheel gap is like a vagina the more fingers you can fit in the worse it is.
daveyboy is offline
Old 08-20-2009, 11:26 PM   #3
gonefhsn
gonefhsn's Avatar
Fan#: 45759
A recommendation
gonefhsn is offline
Old 08-21-2009, 08:36 AM   #4
tetra
pwned
tetra's Avatar
Fan#: 60621
What I Drive: 2009 Black Clearcoat SES Sedan
Points 13,912, Level 76
Points: 13,912, Level: 76 Points: 13,912, Level: 76 Points: 13,912, Level: 76
Level Up 66% Completed
FF Reputation: 10 tetra Great Standing Member
Too bad this doesn't work for 2008+ ECU's :(
tetra is offline
Old 08-22-2009, 02:38 PM   #5
coupefocus
coupefocus's Avatar
Fan#: 58004
What I Drive: 2008 vapor silver coupe
FF Reputation: 1 coupefocus Good Standing Member
why won't this work for the 08s+? i jsut got my x3 in the mail and i have already installed my aem wideband.
do you just have to use a different equation?
or is it just some stupid ecu problem?
focus sport exhaust
focus sport CAI
F2 header
steeda sts
coupefocus is offline
Old 08-22-2009, 05:02 PM   #6
gonefhsn
gonefhsn's Avatar
Fan#: 45759
They say it is a ecu problem. But i dont understand why when this is an analog connection to the x3
gonefhsn is offline
Old 08-22-2009, 05:27 PM   #7
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
Nice write up, Josh. Nice to see you finally got it to read right. Do you still need to do the WOT datalogging?
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 08-22-2009, 09:09 PM   #8
gonefhsn
gonefhsn's Avatar
Fan#: 45759
Nope it is all dialed in
gonefhsn is offline
Old 08-22-2009, 09:18 PM   #9
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Sweet.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 08-23-2009, 06:41 PM   #10
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Not to down you but there was already a write up that shows all of this. but still good write up
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Similar Threads
Aem Uego *installed*!! Darth Focus General Forced Induction 12 01-28-2007 06:18 PM
Aem Cold Air Darth Focus SVT Performance (2002-2004) 9 04-20-2005 10:43 AM
aem cold air sensor hook ups? jdztec3 ZETEC Performance (2000-2004) 11 12-17-2004 08:59 PM
AEM Gauge type UEGO gauge - Wide Band Russell Archive 5 10-15-2004 08:12 PM
Aem Sucks!!!!!!!! rfinger Ford Focus & General Car Chat 46 09-03-2004 10:41 AM
