'05 wiring diagrams - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-22-2011, 11:02 AM   #31
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,857, Level 25
Points: 1,857, Level: 25 Points: 1,857, Level: 25 Points: 1,857, Level: 25
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
Thank you! Thank you! Thank you!!!
mainest is online now
Old 07-23-2011, 12:03 AM   #32
Diesel
Diesel's Avatar
Fan#: 86584
What I Drive: 99 zx2, 04 focus wife's car
Points 1,749, Level 24
Points: 1,749, Level: 24 Points: 1,749, Level: 24 Points: 1,749, Level: 24
Level Up 49% Completed
FF Reputation: 2 Diesel Good Standing Member
I have been looking for the wiring diagram for the brake fluid float 04 duratec. where it get it's signal from and too and is it on a can bus system,5v,or 12v? Is it from the abs module?
Rims, fog light conversion, Interrior lighting recolor from starfuryt
Diesel is offline
Old 07-31-2011, 02:52 PM   #33
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
What I Drive: '05 CD silver ZX3 ST
FF Reputation: 77 roosterst Excellent Standing Member
Buy-Sell-Trade Rating: (14)
I only have '05 diagrams. I'll look though, maybe they are the same.
EDIT: This looks pretty simple. Battery, to Fuse F2.61, to bulb in instrument cluster, to Brake fluid level switch, to ground 103.
So, no CAN bus. / 12v / Not connected to ABS.
I can scan these pages if you'd like, but I can't guarantee they will be the same.
What is the actual issue?
FR valvebody, 91 tune = 16.296 @ 84.08mph
roosterst is offline
Old 07-31-2011, 06:21 PM   #34
Diesel
Diesel's Avatar
Fan#: 86584
ya I finally found it. Now to figure out why Voltage at brake level sensor keeps changing. Cluster issue mabey? Weird thing both brake and abs lights flash on ond off all the time. really annoying driving around with a flashing dash.
Diesel is offline
Old 07-31-2011, 08:54 PM   #35
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
How are you reading the voltage change? It's only these two lights that flash? Over bumps? Any codes from the ABS system? Maybe try a DVOM from the battery, to the brake fluid. Contaminated brake fluid will conduct electricity.
Old 07-31-2011, 09:09 PM   #36
Diesel
Diesel's Avatar
Fan#: 86584
Voltage change at plug end using Multi with float disconnected. ranges from 2v-12v always changing. Only code is low brake fluid. (fluid full and new float) lights flash just driving down smoth highway. And your schematic is what I found finally flipping through all the diagrams.
Diesel is offline
Old 07-31-2011, 09:30 PM   #37
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
lol, I forgot it was posted already. There is more to section 60, but it doesn't apply to your issue. I really should just scan them all one day. Anyway...
Wow, I really don't know what to say. The volts just go up, and down sitting there? Meter plugged into where the float should be? Running, or not running? I can check Alldata for TSBs tomorrow, and see if the diagrams are different. Alldata isn't always right though. Did you post this in tech chat? The new float didn't fix the ABS code? Is the fluid new?
Old 07-31-2011, 09:43 PM   #38
Diesel
Diesel's Avatar
Fan#: 86584
Alldata was a night mare to find the float it wasn't listed onder ABS or Brakes. It's my buddies and I have to use it on my lunch when he brings it in.
Tech chat said mabey bad float they had nothing.
Ya just sitting there volts just all over board. I'm thinking cluster I have my schematic written on a napkin. I will pull the cluster and check volts going in and out. the little processor mabey bad?? IDK it's been doing it since like 33k now has just over 40k on it.
Diesel is offline
Old 07-31-2011, 09:50 PM   #39
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
We like to call it Nodata. It is kinda crappy sometimes. Yeah, it may be in the cluster. Good luck, hope you find it.
Old 07-31-2011, 09:53 PM   #40
Diesel
Diesel's Avatar
Fan#: 86584
Ya some times it tells you to do unneeded stuff. like remove steering rack to change inner tierod ends or something like that. We call it AllDeDe
Diesel is offline
Similar Threads
Electrical wiring diagrams Focus Cabrio jes2983 General Technical Chat 2 05-06-2009 12:48 PM
2004 Ford Focus Factory Wiring Diagrams Book N2O Focus Archive 6 05-21-2007 08:26 PM
HELP! wiring harness diagrams needed dappie_99 General Technical Chat 4 03-26-2007 09:26 AM
Wiring Diagrams Wyldstar General Technical Chat 1 10-24-2006 02:33 PM
HELLA wiring diagrams??? 123A46GT MK1 Focus 3 09-02-2004 03:08 PM
