Map sensor and TPS location - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-11-2009, 03:41 PM   #1
griffith00
Fan#: 68113
What I Drive: 2005 zx3
FF Reputation: 1 griffith00 Good Standing Member
Hi, Im throwing an engine code for low input on map sensor and TPS sensor, I cant seem to find any free repair manuals online for the focus. Can someone help me locate these im thinking about pulling them from the junk yard tomorrow. thanks
griffith00 is offline
Old 08-11-2009, 03:52 PM   #2
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
the tps should be on the throttle body
PumkinSvt is offline
Old 08-11-2009, 03:53 PM   #3
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
What I Drive: '05 CD silver ZX3 ST
FF Reputation: 77 roosterst Excellent Standing Member
Buy-Sell-Trade Rating: (14)
What are the codes you're getting?
FR valvebody, 91 tune = 16.296 @ 84.08mph
roosterst is offline
Old 08-11-2009, 04:14 PM   #4
griffith00
Fan#: 68113
I dont remember the codes but i stopped by autozone to get it checked out. I lend my car to my parents for awhile and it had some problems when I got it back. It runs like crap right now, bogs like crazy. There were multiple engine codes but the guy at autozone told me these 2 were likely causing the other codes to go off.
Old 08-11-2009, 05:46 PM   #5
roosterst
фанатик
roosterst's Avatar
Fan#: 61461
This pic is a general overview. TPS is in the upper left, and MAF is in the lower right.
This is a close up of the TPS, on the throttle body.
This is the MAF, buried down low.
Old 08-11-2009, 06:23 PM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
You should go back to Autozone, read the codes again, and then come back here and let us know what the code numbers are. You can also double check the code in our DTC code guide in the "Technical Chat Stickied Threads" at the top of this forum.
Autozone guys are there to sell you parts, so if the code actually says "MAF sensor self test fail, or possible incorrect TPS reading" then they will sell you both parts- neither of which you can return if it doesn't work. You should not trust these guys, or even the code scanner. The code scanner is a diagnosis tool, not something that points out the exact problem. You still have to interpret the codes, and then test the parts, if possible, yourself. Your whole problem with these codes could be a loose air intake, and replacing both parts would not solve the problem. Then you'd be out more money, and on your way to a shop to have the car sit there until you pay what they say you have to pay.
Oops, I just saw it was a low input code supposedly, anyway, if this were my car, I'd be tracing down the wiring harness for the first connector I could find on both of those, then unplug it, clean the pins with an old toothbrush, then put di-electric grease on the connections and plug it back in. I'd also inspect that wiring harness for physical damage.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-11-2009, 07:35 PM   #7
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
X2.
It is suspicious that both the MAF and the TPS are showing out-of-range readings, and the problems both seem to have appeared simultaneously..
penguin is offline
Old 08-11-2009, 11:04 PM   #8
griffith00
Fan#: 68113
Whoa great pics. Thanks for the input guys. I had a leaking battery with battery acid on the wires i looked at it briefly but ill take another look and clean it.
