How to remove your starter - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-06-2009, 09:58 PM   #1
RallieConGoggle
RallieConGoggle's Avatar
Fan#: 50774
What I Drive: 2007 CD Silver ZX4
Points 2,146, Level 27
Points: 2,146, Level: 27 Points: 2,146, Level: 27 Points: 2,146, Level: 27
Level Up 98% Completed
FF Reputation: 9 RallieConGoggle Good Standing Member
Disconnect both of the battery cables.
Disconnect the MAF sensor connector
Take off the air cleaner and hose to the throttle, then take off the air cleaner box. Just gently pull it up, it's got tabs in 3 holes.
undo the hose from the valve cover to fully remove the air cleaner box.
Chock the rear wheels, jack up the car and secure with jack stands.
From below, disconnect the three electrical nuts from the starter. Here is a view of the three bolts. There are 2 13mm nuts and one 12mm bolt, and pull off the connector.
The starter is tough to get to, it is right under the IAC, which is right under the intake manifold. This is a view from below.
Remove the three mounting bolts. When replacing, note that the frontmost bolt (the one that's almost impossible to get to) has a ground connector attached to it.
This is a view from the transmission's perspective
Maneuver the starter out from beneath between the axle and the frame.
Any questions?
Rally with your goggles on!
2000 Pitch Black ZTS Auto (230,000+ miles)
2007 CD Silver ZX4 SES 5spd
Zetec Crew #190
RallieConGoggle is offline
Old 08-06-2009, 11:14 PM   #2
CarDemon
CarDemon's Avatar
Fan#: 63700
What I Drive: 2003 Silver ZTS
FF Reputation: 3 CarDemon Good Standing Member
Buy-Sell-Trade Rating: (18)
Great thread! What year is the Focus you're working on there?
CarDemon is offline
Old 08-07-2009, 08:41 AM   #3
RallieConGoggle
Fan#: 50774
It's the 2000 Zetec auto in my signature.
Zetec Crew #190
Tags
starter
Similar Threads
How to: Install an RS center console and Starter button lunarc MK1 Interior Mods & Upgrades 27 01-12-2015 08:38 PM
How To Remove Hatch Trim & Reinstall Trim FocusOhFive MK1 Focus 14 06-07-2012 11:22 PM
need help.............pulling head out!!! SALEEN_N2O DURATEC Performance (2003-2007) 59 08-11-2008 04:01 PM
Midwing (Remove or Keep?) S2 MK1 Focus 87 05-15-2006 10:19 PM
SPI engine removal wcbjr SPI Performance (2000-2004) 12 11-03-2005 10:15 AM
