My in-car wiring diagram for datalogging/tuning - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2009, 02:56 PM   #1
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,083, Level 69
Points: 11,083, Level: 69 Points: 11,083, Level: 69 Points: 11,083, Level: 69
Level Up 59% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
I was trying to sort out connectors and things for tuning, and then I accidentally opened photoshop...
SCT PRP FTMFW!
mellephants is offline
Old 08-05-2009, 03:03 PM   #2
mellephants
Fan#: 52400
You might be "WTFing" at some of the connectors, don't worry, just ask what they are and I'll answer. If I have time later I'll summarize the whole thangy.
Basically I was just trying to figure out the best/easiest way to hook everything up without having to solder things together while in the car. I really hate it when things aren't easily removable. I'd rather spend the time cutting up some RCA cables to make custom connectors so that later when I decide to move my wideband I don't have to cut wires and re-solder everything.
SCT PRP FTMFW!
Old 08-05-2009, 04:37 PM   #3
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
wtf is that connector on the bottom right under your wideband gauge???
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 08-05-2009, 04:39 PM   #4
mellephants
Fan#: 52400
haha, IDK, some sort of thing for something or another...
SCT PRP FTMFW!
Old 08-05-2009, 04:40 PM   #5
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
and why does your dyno graph on your computer look so smooth??
SUV this!
illinipo is offline
Old 08-05-2009, 04:42 PM   #6
mellephants
Fan#: 52400
thats actually a 1920x1200 screengrab of my MTF, on Advantage, on 64-bit Windows 7
SCT PRP FTMFW!
Old 08-05-2009, 04:43 PM   #7
mellephants
Fan#: 52400
good thing i shrank it into unintelligible unreadability, otherwise I think I'd be breaking the EULA
SCT PRP FTMFW!
Old 08-05-2009, 05:50 PM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
iPod and radio, I'm confused on those 2 . . . explain?
121,000 members and still no sponsored racing.
iminhell is offline
Old 08-05-2009, 11:28 PM   #9
iceberg65
Fan#: 64382
What I Drive: 00 laser red cougar
FF Reputation: 2 iceberg65 Good Standing Member
are you running livelink on 64bit windows vista? I thought their were compatibility issues with the software. I couldnt get the new version to install on my laptop
iceberg65 is offline
Old 08-06-2009, 05:18 PM   #10
mellephants
Fan#: 52400
The iPod is just there to show that I can use an iPod + Aux-in at the same time (just have to switch sources using the head unit).
Audible Knock Monitor
The wires from the knock sensor signal to the cd-player allow listening for knock through the speakers in the car. This is very very useful because you eliminate exhaust and wind noise, and you can really hear any knock very clearly! I'm hoping it will work just as well on an SVTF as it does on the regular Zetec. Pete (illinipo) listens to his knock sensor this way, and has been really successful so far. I'm going to do it pretty much the same way, but I'll get my audio signal (ground & knock sensor) right from the J&S Safeguard harness (which are connected to the same ground and knock signal Pete suggests tapping into). This way if the audio signal is working I can be sure the J&S is also getting knock signal.
J&S Safeguard
The J&S Safeguard is hooked up as per the instructions on their website, the only difference is that for now I have the boost/vacuum port plugged so the J&S will monitor for knock all the time, not just above 5" of vacuum. The J&S Monitor wire is dataloggable, so I'm going to be running it into one of the Analog ports on my SCT XCAL2. I'm really happy about that, because I'll be able to review my datalogs to see exactly what conditions caused it to be active. The 3.5mm J&S Monitor wire is straightforward:
Wideband
My other analog input for datalogging is my Wideband O2 signal. I'm using an Autometer Wideband (#5778). It has an output meant for datalogging, so its connections are also very straightforward. For more info about that Wideband, you could check out its installation pdf.
Blue: Signal (0 - 5V)
Blue/Black: Ground
XCAL2 Analog Inputs
The XCAL2's analog inputs are easy to set up, especially if the signals you wish to log are already in the allowed range (0-5V). Luckily for me, both of my signals are in range, so I can just connect them right to the XCAL2.
Now comes the most annoying part about all of this: The XCAL2's non-standard 9-pin mini-DIN connector. IMO the most simple & durable way to pull this off is to buy a Male-Male cable, then chop it in half so you have one for you and one for a friend. I bought one on eBay, from the stockcable.com store... it is also available on their website, PN# R58190A-03. Whenever you're making custom cables, always use a multimeter to determine which wires go to which pins, because not all cables use the same color scheme. You only need 3 wires for the XCAL2:
I chose to solder some widely available female RCA connectors to this DIN cable. This allows for fast & easy connections, extensions, and source swapping. I simply soldered another female RCA to the datalogging output on my Wideband, and made a custom 3.5mm->single RCA cable for the J&S Monitor.
SCT PRP FTMFW!
Similar Threads
Help! 2000 Focus - no fuel - need wiring diagram thebigreddog! General Technical Chat 7 09-21-2013 10:19 AM
ST170 Tailight Wiring Diagram havoc7476 MK1 Focus 6 11-08-2005 12:50 AM
April 2005 U.S. Auto Sales Scorecard Kneel Ford Focus & General Car Chat 3 05-04-2005 04:56 PM
Anyone have a wiring diagram for guage cluster. BLKEUROSVTZX5 Car Audio, SYNC, MyFord Touch & Electronics 2 08-11-2004 11:04 AM
