Duratec cylinder head rebuild with pics - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-22-2009, 01:57 AM   #1
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
Align cams using alignment bar. If the head were installed, this would be TDC assuming no cam adjustments were made (if with adjustable gears).
This was not necessary because the head was not installed. I did it just because.
Aligned
Cam caps removed and laid in place in exact position they will be re-installed in. Intake on bottom, exhaust in top of the pic. Followed cam cap loosening sequence in chilton manual.
Head with cam caps removed.
Cams removed, exposing tappets.
Tappets laid out in sequence. Will be re-installed in the same location they were removed from.
Tappets removed and exposing valve springs. Valve spring compressor mounted and ready to break the keepers loose for valve spring/valve removal.
Intake ports. They were black.
Compressing the valve spring. While doing this, I kept my hand on the valve face from the combustion chamber side of the head so the keepers would break loose. If there is no pressure on the valves while you compress the springs, they will not break loose and you will not be able to get the components out.
Removing the valve. Once you have the valve spring out, the valve comes out easily.
The valves were filthy and loaded with deposits. It only looks metallic in this pic because of the camera flash. It was really just black carbon build up.
Intake port just after valve removal.
Removing the valve seals with a 14mm socket.
Keep each valve train component in it's proper place. There are 16 valves total.
A shot of the valve seats after all valvetrain components have been removed. Exhaust valve seats on bottom, intake on top. 30mm and 35mm respectively.
Cleaning the valvetrain components.
Clean intake port.
Clean exhaust ports.
Lapping valves into the cylinder head after re-installing valve seals. The combustion chamber side has been cleaned as well.
Valve seat and valve before grinding.
After grinding
That's where I am at for now. I'll edit this post with more pics once I complete the rebuild. Feedback appreciated.
afraziaaaa is offline
Old 07-22-2009, 02:18 AM   #2
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,010, Level 60
Points: 8,010, Level: 60 Points: 8,010, Level: 60 Points: 8,010, Level: 60
Level Up 30% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
nice work, good resource here for those who dont have a service manual
2003 Ford Escape 4x4 Limited
On Order: 2015 Porsche Cayman S
SYZ is offline
Old 07-22-2009, 04:10 AM   #3
ChrissyL
Trying to Focus
ChrissyL's Avatar
Fan#: 64813
What I Drive: '13 Performance Blue ST3
Points 1,380, Level 20
Points: 1,380, Level: 20 Points: 1,380, Level: 20 Points: 1,380, Level: 20
Level Up 80% Completed
FF Reputation: 13 ChrissyL Great Standing Member
Seems consistent with what I used to do rebuilding DOHC Japanese four-cylinder motorcycle top ends...good work and thanks for sharing, Afraziaaaa!
All my relations, Christine
NW Posse #17
"Straight roads are for fast cars. Curvy roads are for fast drivers."
ChrissyL is offline
Old 07-22-2009, 10:00 AM   #4
daveyboy
daveyboy's Avatar
Fan#: 61480
What I Drive: 06 Mustang GT, 09 Focus SE
FF Reputation: 7 daveyboy Good Standing Member
2.0L or 2.3L
Hard work never hurt anyone, but why take a chance
Originally Posted by ranger_mclaren View Post
Wheel gap is like a vagina the more fingers you can fit in the worse it is.
daveyboy is offline
Old 07-22-2009, 10:16 AM   #5
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
This particlar head is off of a D20
Old 07-22-2009, 10:25 PM   #6
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,213, Level 98
Points: 28,213, Level: 98 Points: 28,213, Level: 98 Points: 28,213, Level: 98
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 3%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
great thread
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 07-22-2009, 10:40 PM   #7
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,876, Level 100
Points: 51,876, Level: 100 Points: 51,876, Level: 100 Points: 51,876, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
You dont have to keep all componets togather if you grinding the seats and the valves , all springs are the same , all retainers and keepers are the same and your changing where the meet
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 07-22-2009, 10:49 PM   #8
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
oooooo, the valve looks SOOO nice afterwards! man, must be some bad gas or something getting the carbon all over the valves like that.
wouldda been cool to see you drop it in some techron or something, see if they come clean lol.
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 07-23-2009, 12:38 AM   #9
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
Lol @ techron. Hahaha. I think whoever owned the car this head came out of just didnt maintain very well.
Thanks Tom. I didn't know that, but it makes perfect sense.
I guess the tappets aren't going to matter either. Valve lash gotta be checked.
Old 07-23-2009, 03:22 AM   #10
gemini47
Fan#: 66625
What I Drive: Duratec Focus
FF Reputation: 3 gemini47 Good Standing Member
hey this is a great thread. thanks for posting this up!
gemini47 is offline
Similar Threads
FS Duratec race head w/cams/cg/sprgs/ret 0103VENOM Archive 10 08-25-2007 08:15 AM
General Specs on the 2.0L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:22 AM
General Specs on the 2.3L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:21 AM
General specs on the SPI b16sir1991 General Technical Chat 0 04-18-2007 11:20 AM
New Cylinder Head? jmltapp General Technical Chat 11 02-05-2004 03:28 PM
