Key Transponder Bypass: directions w. pics - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-15-2009, 11:35 PM   #1
michael3442
Fan#: 66803
What I Drive: 2000 wagon
FF Reputation: 5 michael3442 Good Standing Member
I recently bought a 2000 Focus which came with one PATS key. Finding that extra keys (I needed two more) were going to cost roughly $75+ each, I set off to find another solution. I found many posts that suggested pulling the transponder out of the key, but noone seemed to have actually done it. Well, I did it and...it works! You will lose a little security but I always lock my car anyway. Below are pics with directions under each picture.
The transponder is a tiny glass vial inside of which is a coil of wire and other mysterious stuff. A transmitting unit sends a signal to the transponder (no batteries) which somehow uses the signal to generate enough current to respond and allow the car to start. All this is fitted to a holder and this combo is stuffed into the key. Look at your key under a lamp and you can see the trapdoor. Use a razor blade, utility knife blade, or Exacto knife to cut along the trapdoor's rectangle and then pry out the transponder & holder.
Here's a better view of the setup.
And there it is. It's a tight fit and pulls out with a little effort. It also goes back in, but it's pretty hard. To get it back in (like if you lose you nerve...) you might heat the plastic key in the oven to something like 150 degrees and see if it slides in a little easier. But don't lose your nerve 'cause this workaround really works.
You'll find that the holder is a little too long to fit in the spot I'll recommend below. I cut the bottom 1/8" off but if I were to do it again I'd cut the top off which I could then use as a plug to cover the hole in the key's plastic. In either case put a drop of glue on the end to keep the two sides of the holder from spreading apart.
Now take off the bottom half of the steering column surround. It has three torx screws (size T-15), so go to the hardware store before you start this project and pick up the right sized driver if you don't have one. I had to jerk this surround a bit to get it removed but it came off in a few seconds. Now you can see the lock cylinder and the transponder's sending unit surrounding the cylinder right behind the key slot. It's that black plastic ring that's kind of dusty. What I was very pleased to find was that area behind the sender because it forms a little cubby that the shortened transponder/holder fits in nice and snug. Very cool.
Look closely and you'll see the holder on it's way to laying down in this perfect spot.
With all the black it may be hard to see, so I'll point it out.
There, all settled in. Time to start the car with the old key. Dang, it won't start! The dash lights go on and the security blinker by the 4-way flasher button goes nuts. But the engine isn't turning over! What's the deal?
Having fussed with the transponder earlier I knew the system was hypersensitive to its location, so I rotated the holder 90 degrees to configure it sort of vertically. Success, the car fired right up with no security LED flashing. Whew, that had my pulse racing a bit.
A strip of electrical tape slipped over the top finishes the job. After a few days of operation I may pull the tape back and pour a little glue alongside the holder, just in case the tape loses it's grip and the holder jiggles out when bouncing over a pot hole.
The project will take about an hour and is really pretty easy. Be sure to pick up the Torx driver (T-15) before you start. Good luck!
-MK
Other keywords: chip disable fob Securecode
michael3442 is offline
Old 07-16-2009, 09:40 AM   #2
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Just an FYI you are now committing insurance fraud and it is now ridiculously easy to break your window and hot wire the car.
But otherwise hey that thing looks cool.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 07-16-2009, 10:06 AM   #3
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
I don't see how that would apply, since most remote starter systems do something similar via an antenna wire to the ignition switch area. And in any case, it would bee no different than if someone forgot to take their keys out of the car. Besides, I rather doubt a nine-year-old car has theft insurance on it.
(1) But no one can tell that the modification has been made, so I rather doubt anyone will pick this Focus over others as a result, and,
(2) It's a nine-year-old station wagon economy car. Get real, who is going to want to steal it?
But otherwise hey those are good points.
penguin is offline
Old 07-16-2009, 10:08 AM   #4
YellerZX3
YellerZX3's Avatar
Fan#: 23043
Location: On the Prairie that is Grand, TX, United States
What I Drive: 2013 Silver SE Hatch, 12 Fusion SE
FF Reputation: 6 YellerZX3 Good Standing Member
Don't see how it would be insurance fraud unless he told somebody to steal it and did this PATs bypass for the purpose of getting the car stolen.
Garry - Fishflinger (on other forums)
Not So Low, Slow and Ingot Silver
YellerZX3 is offline
Old 07-16-2009, 10:18 AM   #5
Djmike2485
Registered User
Fan#: 3230
What I Drive: Silver 2000 Ford Focus Zetec 4 Dr.
FF Reputation: 6 Djmike2485 Good Standing Member
Yeah, but the only people who know it's done on his car are us.
Djmike2485 is offline
Old 07-16-2009, 12:42 PM   #6
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
i didnt mean to rag on you just giving FYI.
For the insurance thing, one of the first things they look at is your anti-theft devices on the car. One of the things on the checklist is an electronic interlock on the starter circuit. You no longer have this, so you ought to adjust your premium.
Anti-theft devices and car security systems are classified into three major class types. These are the mechanical car immobilizers, the electronic immobilizer and identification system and the security alarm device.
SUV this!
illinipo is offline
Old 07-16-2009, 06:42 PM   #7
michael3442
Fan#: 66803
You sound like the kind of guy who just can't wait to rag on folks. First in line at the rag bar, eh? Don't bother to say thanks for the 3 hours it took to get these photos taken, edited, and posted.
As for my insurance, putting this car on my policy raised my premium from now to next March by $45. Gee, maybe they'll raise me to $50. Ouch!
Old 07-16-2009, 08:12 PM   #8
cohort
cohort's Avatar
Fan#: 62280
What I Drive: '06 cammed Subaru 2.5i
FF Reputation: 3 cohort Good Standing Member
Thanks for the write up. It's always nice to have these in case of...
cohort is offline
Old 07-17-2009, 02:05 AM   #9
damonlan
Fan#: 65583
What I Drive: 2005, white, base model
Points 101, Level 2
Points: 101, Level: 2 Points: 101, Level: 2 Points: 101, Level: 2
Level Up 2% Completed
FF Reputation: 1 damonlan Good Standing Member
Thanks for saving me $100 or so. I'd buy ya a case a brew but. . . .
damonlan is offline
Old 07-31-2009, 09:29 PM   #10
Dan-O
Dan-O's Avatar
Fan#: 50029
What I Drive: 2002 FrankenTurbo powered Beetle
FF Reputation: 13 Dan-O Great Standing Member
Buy-Sell-Trade Rating: (26)
I just found this.
It's been a couple weeks, is this still working for you?
There's no replacement for displacement...
Yeah, there is: Boost!!
Dan-O is offline
Similar Threads
How To: Drilling Out Ignition Cylinder Due To Key Won't Turn (Ford Focus ignition lock cylinder) microtonal General Technical Chat 73 01-23-2011 11:39 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Transponder Keys jsonghas Ford Focus & General Car Chat 6 01-26-2005 04:44 PM
Wiring for remote start on 2000 ZX3 cobrar97 Car Audio, SYNC, MyFord Touch & Electronics 4 11-27-2004 03:21 PM
Need a new Key! lippy General Technical Chat 1 07-02-2004 10:53 AM
