My SVT Brake Swap (w/Rear Discs) is Done! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-27-2004, 07:02 PM   #1
l88m22vette
Fan#: 2184
What I Drive: 2001 Twilight Blue ZTS
FF Reputation: 1 l88m22vette Good Standing Member
Well, after posting about it forever ago, I finally got my SVT brake swap put onto my 2001 ZTS, and its awesome. Now, mind you, I got a good deal after scouring the internet and eBay for almost a year; I paid $600 for the complete swap, which included all the front (steering knuckles, calipers, new pads, new cross-drilled/vented rotors) and rear (spindles, calipers, rotors, e-brake cables) hardware. This swap was basically a bolt-in, as the parts came from a wrecked SVT Focus. The assemblies had been unbolted from the heap as the four full assemblies, not as scattered parts in a big box, which made my life a lot easier.
I began with the passenger rear, then drivers rear, then passenger front, and then finally the drivers front (start with the brake farthest from the master cylinder). I only ran into a few problems during the swap, which were the following: 1) Focuses w/drums do not use the same spindle as the discs, so once I got everything else off, I found the drum spindle was attached with two rivets; I drilled those out using a metal bit and some oil, and then could bolt on the new spindles (really the whole assembly) onto the plate that is already there using the existing bolt holes. 2) The second problem, at least on my sedan, is that the e-brake cables for drums have a different attachment point and type than do the calipers; this is the only part I have not yet completed, because the cables connect under the exhaust/heatshield, and plan to swap these either by dropping the stock exhaust (unbolt from flex) or when I put on a new system. Although the lengths might be the same of both cables when doing this swap on a ZX3, the cables would still need to be switched, so keep that in mind; I can live with this for a little while, because I still have my slushbox. 3) The last problem I had, because the parts were from a wrecked car, was my front bearings were bad on both assemblies, so I had to get new bearings pressed in, which brought the total up to ~$750 (~$75 per side for the bearings). The bearings are not the same as regular Focus bearings, and whether or not you have ABS also makes a difference, so if you do a swap, make sure you get the right stuff.
I did this swap sitting on the ground using only a jack and jackstands, as well as normal tools; the only specialty tool you need is a ball joint fork to separate the lower control arms from the steering knuckles. This tool costs only about $25, and most mechanics and big car buffs have one of these already; if not, you can find one at any good auto store.
I'm very glad I did this swap, as well as very lucky with what I found; for $50 less (or $200, depending on bearing condition), I not only got a front brake upgrade, but also a full rear disc swap. The idea of a rear disc swap seems to be in at least 2-3 posts per week, so hopefully this post will help those folks as well; aftermarket suppliers, like Stainless Steel Brake Corp., make a rear disc conversion, but with a little hunting (and patience, lol) you can almost definetly do it for less using either SVT parts or parts off a few of the non-SVT Focuses w/rear discs. About the only other thing I am thinking of doing to my brakes are stainless braided lines, and maybe an SVT master cylinder; if I do end up getting those two things, I'll post about those as well. Really, the only direction for me to go with my brakes is to a full-race system; for less then the price of an aftermarket disc conversion, I now have brakes that will keep up with my mods for a long time. Any questions or comments are welcome, and I will try to answer any questions people have about this swap.
EDIT: I accidently posted this in the Zetec Forum as well, sorry about that
Full SVT brake swap, indiglo gauges
http://www.ebaumsworld.com/honda-ad.html
l88m22vette is offline
Old 07-27-2004, 07:07 PM   #2
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
Congrats, kinda hard to see through those wheels, but I'm sure they look awesome. Probably feel nice under your foot as well.
Lil PZEV is offline
Old 07-27-2004, 07:29 PM   #3
mofocus
mefocuslongtime
mofocus's Avatar
Fan#: 5
What I Drive: Beltfed,extra pullified,weeemachine
FF Reputation: 6 mofocus Good Standing Member
Buy-Sell-Trade Rating: (17)
please stop posting the same thread in different forums
MAY 2007 ROTM WOOT [/COLOR][/B][/U]
my dyno video
mofocus is offline
Old 07-27-2004, 08:32 PM   #4
EuroZX3
EuroZX3's Avatar
Fan#: 39
What I Drive: 05 Black Scion TC
FF Reputation: 1 EuroZX3 Good Standing Member
Buy-Sell-Trade Rating: (7)
nice to see u got this done. sounds like it wasnt too hard. so you have no parking brake? how long do u think till u get that done?
Originally posted by darkpuppet
needs more cowbell
EuroZX3 is offline
Old 07-28-2004, 09:06 AM   #5
Hubris
Fan#: 9465
What I Drive: 2000 Z28, 2004 ZX-5
FF Reputation: 1 Hubris Good Standing Member
Great.....this is going to make the competition for SVT brakes all the harder :)
Did you take any pics of the parts that came to you....or how they were already partially pre-assembled? This has the makings of a good stickied post if we can flesh out the details a bit more.
Hubris is offline
Old 07-28-2004, 09:27 AM   #6
Solaris
Solaris's Avatar
Fan#: 52
What I Drive: 1985 Volvo 740 GLE
FF Reputation: 1 Solaris Good Standing Member
wow for only $600 very very nice. Still a bit pricey but it's half of what i've seen before. In all honesty did u notice much of a difference?
2001 Liquid Grey S2 will be remembered as my first love.
Now driving a 1985 Light Blue Volvo 740 GLE with 95,000 miles on it
Solaris is offline
Old 07-28-2004, 10:37 AM   #7
Vassili95
Fan#: 371
FF Reputation: 1 Vassili95 Good Standing Member
Nice job!
Did you feel any significant difference yet?
Peace...
Vassili95 is offline
Old 07-28-2004, 11:05 AM   #8
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Did you get the brake biasing valve as well?
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 07-28-2004, 11:09 AM   #9
Hubris
Fan#: 9465
I didn't even know the SVT had one. Why would it be needed on an OEM system, where the rotor size and piston details are known? I would think Ford would just design the system to work as-is...although giving adjustability is nice.
Hubris is offline
Old 07-28-2004, 01:05 PM   #10
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Drums and disc brakes in the back require different brake pressures. It could be clamping too hard to too little.
Egz is offline
Similar Threads
Project SVT Sedan Red01Focus Ford Focus Builds & General Showroom 185 01-24-2015 02:38 PM
Big Front Brake Kit Or Svt Brake Swap??? focuztyle Brakes, Suspension & Body Chassis 37 04-06-2013 11:53 PM
Question regarding SVT Brake Swap 02ZX5cominalive Wheels & Tires 11 06-05-2010 09:42 PM
HOW TO: Interior swap with power window and locks (over 100 pics) focuzed1 MK1 Interior Mods & Upgrades 11 01-03-2010 08:36 AM
SVT Brake Swap. jlemond Wheels & Tires 3 03-20-2006 02:39 PM
