SVT rear caliper help GRRR - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 07-13-2009, 09:22 PM   #1
djblackout
djblackout's Avatar
Fan#: 61433
What I Drive: 02 sonic blue SVTF
Points 11,427, Level 70
Points: 11,427, Level: 70 Points: 11,427, Level: 70 Points: 11,427, Level: 70
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 11 djblackout Great Standing Member
Thumbs down SVT rear caliper help GRRR
Okay, So i bought the tool that looks like a cube. you twist it to the right to turn the caliper piston back in. ive been turning it for the past hour and it just seems to spin and spin. its like 3/4 the way in, and the remaining 1/4 wont go any further.
i tried spinning it the other way to make sure im not retarded, but that was teh wrong way.
am i doing something wrong here?
02 SVTF
djblackout is offline
Old 07-13-2009, 09:45 PM   #2
Captain Moonpie
Focus "Sleeper"
Captain Moonpie's Avatar
Fan#: 41715
What I Drive: 2003 Focus ZX3 deep red
FF Reputation: 13 Captain Moonpie Great Standing Member
Ive never used that tool. I always just grab some giant lock-jaw pliers and squeeze the hell out of the piston against the caliper.
DRIVE IT LIKE YOU STOLE IT!!!!
WAY too many performance mods to list. Check profile if you wanna know. And yes, I installed all my mods myself in my garage. No special tools.
GET NITROUS PEOPLE!!
Captain Moonpie is offline
Old 07-13-2009, 10:04 PM   #3
djblackout
djblackout's Avatar
Fan#: 61433
you are not supposed to clamp it. the piston screws in. I have an SVT
02 SVTF
Old 07-13-2009, 10:35 PM   #4
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 31,955, Level 100
Points: 31,955, Level: 100 Points: 31,955, Level: 100 Points: 31,955, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I had to push REALLY hard while turning it a few times to get it to go back in. I just used some channel lock pliers but only because I didn't have the cube but I had the caliper off the car and clamped in a vice. Also, my brake hose was disconnected so the fluid had a place to go. Try opening your bleeder valve if its on the car or unscrewing the hose if its off.
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 07-13-2009, 11:18 PM   #5
djblackout
djblackout's Avatar
Fan#: 61433
bump
02 SVTF
Old 07-14-2009, 01:13 AM   #6
djblackout
djblackout's Avatar
Fan#: 61433
still wont go in enough for me to be able to put the pads on.
i bought the pads MKD886 from autozone. im pretty sure they are right
02 SVTF
Old 07-14-2009, 02:30 AM   #7
wsigo
Fan#: 57221
What I Drive: 2002 Toreador Red SE Sedan
FF Reputation: 5 wsigo Good Standing Member
Use the cube, as you have been. Apply pressure while turning, just as you have been.
Don't use clamps on these calipers.
Don't disconnect brake lines or unscrew bleeder valves.
DO take the cap off the master cylinder. That should relieve any pressure building up through the lines.
Go slow- as not to spurt brake fluid out of the master cylinder. FYI- brake fluid is both flammable, and a paint killer.
wsigo is offline
Old 07-14-2009, 04:33 AM   #8
djblackout
djblackout's Avatar
Fan#: 61433
ok so i got both rear brakes done, but the boot of the piston on the left rear seems to have a slit, and slightly drips.
took the car for a spin and the brake pedal sinks low. i can slam on the brakes and i dont come to a screeching stop. can i replace the piston? or do i have to get a whole new caliper?
and should i take it to get it done, or is it pretty easy to bleed the system? I have a one man bleeder system, but had a bad experience with my civic.
i think what may have happened is when i turned it to the left, to see if it would work i must have raised it too high and let some air in, should i just try and bleed the system first>?
02 SVTF
Old 07-14-2009, 11:53 AM   #9
racer1735
racer1735's Avatar
Fan#: 13782
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 5 racer1735 Good Standing Member
A one-man bleeder will do the majority of the process (I have several different varieties), but to get a really FIRM pedal, it takes two people, one to work the pedal and one to work each bleeder valve.
When you've run out of mods, it's time to get something new.
racer1735 is offline
Old 07-14-2009, 12:08 PM   #10
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 35,900, Level 100
Points: 35,900, Level: 100 Points: 35,900, Level: 100 Points: 35,900, Level: 100
Forum Activity 5%
FF Reputation: 34 tukaniSVT Great Standing Member
I did a tutorial on this.
http://www.focusfanatics.com/forum/showthread.php?t=204230
But yeah when bleeding your brakes I agree with Racer1735 that you'll have better luck with 2 people than yourself.
Good Luck with this all.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Similar Threads
How To - Extensive Suspension Overhaul (Front and Rear) SuperFlea Brakes, Suspension & Body Chassis 71 06-26-2014 10:58 PM
svt rear caliper installtion help wakewil Wheels & Tires - Sponsored By Tire Rack 7 12-15-2008 12:42 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 02:04 PM
SVT Left Rear Caliper PLRX Archive 1 01-16-2008 10:32 AM
Wtb: Rear Svt Caliper Mounting Bolts Help realitychck122 Archive 1 11-21-2007 04:05 PM
