Which Mods Are Legal And Are Actually Worth The Money? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 07-12-2009, 08:05 PM   #1
shb5007
Fan#: 58683
What I Drive: 04 SVT Focus
Points 2,922, Level 33
Points: 2,922, Level: 33 Points: 2,922, Level: 33 Points: 2,922, Level: 33
Level Up 15% Completed
FF Reputation: 1 shb5007 Good Standing Member
Okay, according to the guys today I am in the ST class...
Which mods should I do to my SVT Focus that will help me out in the STS class, but will keep me legal?
I have a high flow cat, stainless steel brake lines, rotors, pads, and a tune.
I hear I can't upgrade the throttle body.
Thanks to EVERYONE for your help.
shb5007 is offline
Old 07-13-2009, 08:39 AM   #2
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
Well, as a disclaimer before spending the money, a well prepped "spec" civic will often beat an SVT in ST. But if you don't often see one, you should be able to do OK in this class.
You didn't mention what tires you're running. Absolutely start there, you should be researching Dunlop star specs, Kumho XS, B-stone RE-11, currently the tires to have this year from what I can tell. If you have the money get some new lighter weight wheels at the same time.
A rear sway bar is the next easy upgrade, a 22mm is a good fit with the SVT set up IMO.
With good tires and a new RSB work on your driving until you are consistant and at the car's limits.
For power upgrades, there is not much worth doing on the SVT for ST. The stock CAT is one of the best OEM CAT's made. Stock intake isn't too bad either.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 07-13-2009, 09:46 AM   #3
Dcl2049
MyCarBreaksAlot
Dcl2049's Avatar
Fan#: 18957
What I Drive: 2002 Malibu Blue ZX3
FF Reputation: 69 Dcl2049 Excellent Standing Member
If you're running a high flow cat I think technically you should be in STX... but I haven't read the rulebook in a while so they may have changed that recently?
^That's all good advice. Intake (use a K&N with the stock intake) and exhaust are kinda the main point of having the ST class. Those are actually good stock, so like he said, work on your handling. Tires & suspension are key. You can have aftermarket wheels so look for something lightweight. Adjustable dampers are nice. Check to see if you can have coilovers, I'm not sure if those are STS legal but if they are and you don't mind a crappy ride that's the way to go. But depending on how long you've done this you may not want to just throw money at your car. If you can get a lot of seat time and learn to drive the stock suspension well, that will make up more time than mods will.
Yes, that is a banana in my pocket.
Dan - gumpcrew #4
[BBS][Borla][Focus Central][Hella][K&N][Koni][Lentech][Wings West]
#23 STS Wiregrass Region SCCA
Dcl2049 is offline
Old 07-13-2009, 02:29 PM   #4
shb5007
Fan#: 58683
Thanks for all of the insight guys.
I guess I need to check on the high flow cat.
shb5007 is offline
Old 07-13-2009, 03:01 PM   #5
jayel579
jayel579's Avatar
Fan#: 64031
What I Drive: 2006 Mustang GT, 2002 E46 BMW 330Ci
Points 492, Level 9
Points: 492, Level: 9 Points: 492, Level: 9 Points: 492, Level: 9
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 2 jayel579 Good Standing Member
The best mod for anyone in autocross is to tighten the nut behind the wheel(work on your driving). Then tires and dampers.
"I have made a bar graph of my favorite Pies and I made a pie chart of my favorite Bars" - Marshall Eriksen
jayel579 is offline
Old 07-13-2009, 08:31 PM   #6
apex214
Fan#: 37876
What I Drive: 2003 Focus SVT, silver
FF Reputation: 43 apex214 Great Standing Member
Wise words, those!
ALWAYS "mod" the driver first...lots of practice, and lots of listening to the successful drivers.
apex214 is offline
Old 07-15-2009, 04:45 PM   #7
Auto-X-ZTS
Fan#: 54278
What I Drive: 2000 ZX2 S/R
Points 318, Level 6
Points: 318, Level: 6 Points: 318, Level: 6 Points: 318, Level: 6
Level Up 36% Completed
FF Reputation: 7 Auto-X-ZTS Good Standing Member
HI-FLO cats are legal in ST/STS--must be in 'stock' location. They can be moved up to 6" in STX. The SVT is an OK ST car, would be a better STX car, IMO...as you can add LSD...and maybe shoehorn on some 235/40-17 on 8"+ wheel.
Tires and wheels are #1...then dampers...RSB...springs...camber...bushings...power mods...
7.5" wide wheels and 215/45-16 (XS) or 215/40-17 (Z1) would be where I would start.
Erik B.
(_/\_-Head)
www.waiautox.org
___/\_____/\_____/\_____/\___
Auto-X-ZTS is offline
Old 07-16-2009, 03:25 PM   #8
ZX3Xr
ZX3Xr's Avatar
Fan#: 53790
What I Drive: 2001-Black over silver,ZX3
Points 643, Level 12
Points: 643, Level: 12 Points: 643, Level: 12 Points: 643, Level: 12
Level Up 86% Completed
FF Reputation: 1 ZX3Xr Good Standing Member
I love what limited slip did for my car, its not legal in ST, but the old Hondas still beat me.
H & R springs, Addco rear sway, frt & rear stress bars, s/s brake lines, adj. KYBs, Short air ram, UDP, shift kit, Hawk pads, speed bleeders, Torsen , Fidanza flywheel, MBRP catback, TB, SVT header
ZX3Xr is offline
Old 07-16-2009, 06:15 PM   #9
WUGcatsvt
Obama Can't Gymkhana
WUGcatsvt's Avatar
Fan#: 36697
What I Drive: 02 SVT, 86 BMW E30, 10 VW GTI
FF Reputation: 62 WUGcatsvt Excellent Standing Member
Buy-Sell-Trade Rating: (18)
This should clear something up for you
http://www.scca-milwaukee.org/Solo/c...sification.pdf
With the HFC you are STX
"No, the Focus is SLOW and just kinda stays that way."-Joe GCR SCCA VP
gumpcrew#10
Gulf Coast Region #12 - Me-45 DSP
My Girl-451 DSPL
WUGcatsvt is offline
Old 08-01-2009, 10:29 AM   #10
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
What I Drive: 2003 SVTF, 2003 G35, 2001 Audi S4
FF Reputation: 5 DirtyDeeds Good Standing Member
The document you linked to is out of date. It hasn't been updated since 2007.
High-flow cats are now legal for ST/STS. As was stated earlier, it must be installed in the stock location.
What you do to your Focus to be competitive in ST depends on how serious you want to be and will it still be your daily driver?
Since I've already been down this road with two SVTF's, I'll tell you what I would do if I was starting out from scratch trying to make a daily driver SVTF more competitive in ST.
Suspension:
Contact Auto-X-ZTS and get the rear sway bar he sells. Single best mod I've ever seen for an SVTF suspension. That's it for suspension.
Wheels and Tires:
Depending on your budget, stock wheels or 17x7.5 Rotas (Or something like a Rota) and a set of Dunlop Star Specs. Stock size is just fine. Getting a dedicated set of wheels and tires is preferable as any good ST class tire will wear very quickly with daily driving. ST class tires are also not the best in the wet. If you need a tire that can pull double duty, get a set of Sumitomo HTR Z III. The side walls are a little soft (Use higher pressure to compensate), but the level of grip is quite good and they last. They're also only $83 from Tire Rack.
Power:
CFM or RT high flow cat and a tune from Focus Power or Focus Sport.
That's it. Before you consider putting any more money into the car, spend that money on entry fees. Get out there and practice. You'll get the most improvement from good ole seat time.
DirtyDeeds is offline
