VF engineering rear motor mount install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-27-2004, 02:26 PM   #1
drewzx3
drewzx3's Avatar
Fan#: 1213
What I Drive: silver 01 zx3
FF Reputation: 1 drewzx3 Good Standing Member
Question VF engineering rear motor mount install
Can anyone explains how to install it? I bought it used without any instructions.
drewzx3 is offline
Old 07-27-2004, 02:46 PM   #2
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
1) jack the car up (or put it on ramps)
2) crawl under and find the old mount
3) undo the bolts that hold the mount in the bracket at both ends. sorry, i don't remember the size
4) pull out the old mount. it may be necessary to use a pry bar or something for this because there's not a LOT of room to play with. if necessary, you may find removing reomving the front bracket from the engine makes this easier
5) put everything back in in reverse order. i don't know the torque specs off hand, though. a focus repair manual would probably have them. be patient with everything bc it IS a tight fit! you also lose the play built into the original mount, so that makes it even more difficult (of course, that's why you're replacing the mount in the first place). it took some experimenting to figure out the order to put stuff back in, but i think i put the back end on first (the one that mounts to the x-member) and THEN i put in the end that mounts to the engine. probably doesn't matter though.
the job isn't that hard to understand once you get under there. it's just doing it that is the PITA!
Mike
just visiting now....
whiteboyslo is offline
Old 07-27-2004, 05:33 PM   #3
drewzx3
drewzx3's Avatar
Fan#: 1213
Does the cupped part of the mount go up or down?
drewzx3 is offline
Old 07-27-2004, 08:20 PM   #4
cen
Fan#: 2515
What I Drive: '02 Liquid Grey ZX3
FF Reputation: 1 cen Good Standing Member
cupped part goes down, and also support your transmission with a jack just to be safe.... you are removing one of the mounts that hold it in place remember....
2002 Liquid Gray ZX3 5-Speed
Go: MagnaFlow Cat-Back ~ FC UDP ~ FS Cool Flo Intake ~ FC 65mm TB ~ FS 4-2-1 Race Header ~ Bosal Flex Pipe~ VF-Engineering Rear Mount
Show: Reverse Glow Gauges ~ Short Throw Shifter ~ Clear Corners ~ 35%/15% Tint
cen is offline
Similar Threads
HOW-TO Replacing Rear Upper Camber Arms, and camber bolts. SkyPilot Brakes, Suspension & Body Chassis 39 09-08-2013 01:59 PM
**Vote for FF.com ROTY** Chick Ford Focus - Ride of the Month 113 07-31-2007 12:04 PM
svt rear wing install help spins Focus SVT 12 07-12-2006 07:32 PM
Help me with install on rear camber kit cbrenn71 Brakes, Suspension & Body Chassis 17 06-20-2006 07:33 AM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
