How To: Install Massive's new rear Stress Bar - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-08-2009, 12:01 AM   #1
trailbikerider
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
Points 10,328, Level 67
Points: 10,328, Level: 67 Points: 10,328, Level: 67 Points: 10,328, Level: 67
Level Up 70% Completed
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
Let's start out by saying I got the bar at CJ4, and Karl didn't have a bolt kit put together yet as he had just finished the bars 48 hours beforehand, so my bolts are going to be different than everybody else's who's ordering them through their website.
Materials:
1. 15mm socket (For Nuts) and a 5/16 Box Wrench (Size of the nuts and bolts I used, mine are different than the ones included in the kit most likely).
2. BFH (Required)
3. Razor Knife
4. 3/8's Drill bit (once again, size I used) AND a smaller drill bit for drilling the pilot hole.
5. Sharpie or any black marker
6. Awl
7. Hammer
8. Rubber Mallet
9. A Second person (most important!)
First off, start by getting the car into the air either by putting it on a lift like myself, or using a jack. The purpose is to get the car's weight off of the back wheels.
Then remove the rear wheels, this will come in handy when tightening the nuts on the shock tower.
Remove the side carpet pieces in your trunk.
Here is where you can decide where you want your bar to be placed. The little piece of the strut tower that's protruding out with the arches on either side. You can put it on either side of there. I chose to put it on the rear one to make a little extra room in my trunk. Also remove the foam sound deadeners on the top of the strut tower for mounting. They stick on, so you can put them back on after you've tightened everything on.
This is what it looks like with everything mocked-up where I wanted it.
When you have the bar positioned where you want it, take your sharpie or black marker, and mark the hole position on the strut tower so you know where you want to drill your pilot hole.
Now, take your Hammer and Awl, and punch a small hole where you marked with your sharpie to give your drill bit a good place to start without moving all over the place.
This is with my pilot holes drilled.
Now take your larger drill bit (should be the same size as the bolts that come with the kit, like said before, I used 3/8's bolts, so that's what size my drill bit was) and drill the holes larger for the bolts to go through.
Place your carpet back in.
Have a second person hold the carpet from the inside of the trunk, and take your awl and make a hole through your carpet from the outside of your car.
Now comes the time to put the bar in. I tried installing it every way possible, but there was no way in hell it was going in, everything was too tight. So I went ahead and pulled the carpet back out, and cut some of the sound deadening out with the Razor Knife. The bar was still extremely hard to get positioned, but I could actually get it positioned now.
With the sound deadening removed, I put the carpet back in, and took my rubber mallet, and rapped on the bar for a long time to get it into place. It takes some strength and endurance to do, as it takes a long time, but you'll eventually get it. Once everything is in to your liking put your bolt and washer on the inside of the car, and put the lock washer and nut on the outside. You'll need one person holding the bolt from the inside while the other tightens the nut from the outside. Everything should be installed now!
Go out and have some fun with it now!
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 07-08-2009, 12:05 AM   #2
NeweracapMAN
NeweracapMAN's Avatar
Fan#: 64914
What I Drive: 06 red ZX4, 04 silver SVT cobra
FF Reputation: 8 NeweracapMAN Good Standing Member
SICKKKKKKK i love the color too
DID you put liek silicon or somethign to prevent rusting??
NeweracapMAN is offline
Old 07-08-2009, 12:09 AM   #3
pistolgripbmx
pistolgripbmx's Avatar
Fan#: 49331
What I Drive: 86 ranger, 2007 focus zx3 s
FF Reputation: 38 pistolgripbmx Great Standing Member
Buy-Sell-Trade Rating: (8)
looks good, nice write up, i hope to get this soon!
teamduratec #143!
focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune
pistolgripbmx is offline
Old 07-08-2009, 12:13 AM   #4
trailbikerider
Fan#: 50501
Na, the silicon won't do a whole lot to prevent rust. I may just replace the bolts with stainless when I get the time to get some new ones.
Old 07-08-2009, 12:22 AM   #5
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
Sweet! How is the differance? Is it a big one?
norcalfocus01 is offline
Old 07-08-2009, 12:24 AM   #6
trailbikerider
Fan#: 50501
Haven't been able to test it yet, but tomorrow I can tell you.
Old 07-08-2009, 02:00 AM   #7
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,834, Level 59
Points: 7,834, Level: 59 Points: 7,834, Level: 59 Points: 7,834, Level: 59
Level Up 43% Completed
Forum Activity 19%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Well Blake , after seeing you do this . You have inspired me to get 1 too :).
Nice how to and write up.
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is online now
Old 07-08-2009, 02:25 AM   #8
trailbikerider
Fan#: 50501
Sweet! I hope it does something. If it doesn't that's OK, it looks damn sweet lol.
Old 07-08-2009, 02:58 AM   #9
death_bomber
Aggresive Not Crazy
death_bomber's Avatar
Fan#: 39461
What I Drive: 2001 RED LX
Points 5,719, Level 48
Points: 5,719, Level: 48 Points: 5,719, Level: 48 Points: 5,719, Level: 48
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 6 death_bomber Good Standing Member
That's the limited edition one too right? i personally couldn't choose that color.... haha gotta keep my theme goin
death_bomber is offline
Old 07-08-2009, 09:44 AM   #10
trailbikerider
Fan#: 50501
It's their signature color. Massive purple.
Similar Threads
Strut bar, rear bar, stress bar, and sway bars fhg959 Wheels & Tires 48 06-13-2009 12:41 AM
For Sale: strut tower brace/svt rear bumper/rear stress bar alk3civichater Archive 26 04-06-2009 08:39 PM
Rear Sway Bar Install Bochet Wheels & Tires 3 11-07-2007 03:53 PM
Rear sway bar install problems.. PLEASE HELP! focusonthis420 Wheels & Tires 7 10-23-2007 12:56 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
