Svt rear brake pads - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2009, 03:28 PM   #1
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
Svt rear brake pads
So ... Visiting my family in Dallas TX my brakes starting acting funny and squeaking and all kinds of not so good noises.
Well it turned out to be my rear brake pads were over due for a change.
So I decided, since there are lots of new owners of previously owned SVTs now, I wanted to share a "How-To" do the Rear Brakes since the SVTs have discs instead of drums. And the manuals do not have the SVTs in them ... unless you get the FORD Standard Manual ... which I found is hard to find.
I also looked in the How-To Archive and the Rear SVT ones are not here. I've done this before ... but just wanted to share.
Anyways, here you guys go.
1ST off You want to go to AutoZone and buy a Disc Brake Piston tool.
Now ...
1) Find a good place to do this. I like finding shade when working on the car ... especially since I live in TX. Goodness.
2) Put a brick or something equivalent to the other tires that you are not working on. Helps the roll of the car.
3) Put your car in 1st Gear and release the E-Brake.
4) Good a good Hydraulic Jack (Ummm if you use the Small dinky one from Ford in your car ... please be careful) I also recommend some good Jack Stands as well. (If you are new ... )
5) Next Start to Take off the Lugs. I do this in a criss cross pattern that way it's evenly taken off and evenly put on.
6) As an extra precaution I put my wheel under the car as well. ... Hey can never be overly Safe. It's just something I do. Wheels are cheaper than fixing the the whole strut and all ... But that's just me.
7) I would also recommend some good ol' Gloves. Alrighty well lets do this now ...
8) Now with the wheel off you will see the brake caliper. There are bolts on the back side of the caliper. You will need a 13mm socket and a 15mm wrench to get this off. There are 2 of them. One on top and one on bottom. The 15mm is too help the bolt from just spinning and not coming off.
9) Now that you have the bolt off. You need to wiggles the Caliper off. It's on there. So wiggle with some force. The Force wasn't with me, so I just used my hands and rocked it back and forth til it came off. (Okay that was corny ... anyways).
10) Take off the pads. Eww some nasty ones here with not much beef. I am embarrassed to show you my other side ... (**OH FOOTNOTE**) When changing brake pads. It is best to change both sides not just one side.
New ones are shiny. Too bad Tommy Boy wasn't around ... I would've bought his ... nevermind.
11) Test Fit.
12) Okay now for the Brake Tool. Here is a pic for those of you still scratching their head.
13) You need to Screw the Brake Piston Back into its home ... funny. Yes people think you push this in when you actually have to turn it in. It screws back in.
Tool Goes over it.
13) Now once you get the Piston Down, I recommend some good Lube. Brake Lube that is. This helps with some of the Squeaking noise and also helps put the caliper back over the brakes. Easy to slip on ... hehehe ... anyways.
Lube the spots that come in contact with the Brake Pads (NOT THE SIDE OF THE PAD TO THE DISCS!!!)
14) Okay dokey. Lets put the caliper back over and Put in the Screws.
Just reverse the install and you will be done.
Time for some Ice Cream.
Hope this helps many of you.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 07-04-2009, 04:40 PM   #2
racer1735
racer1735's Avatar
Fan#: 13782
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 5 racer1735 Good Standing Member
Good show! When I did mine, I had a dickens of a time getting the springs on the top of the brake pads to stay positioned in the calipers. One side of the spring would want to 'walk' into the opening in the top of the caliper, thus pushing the pad sideways. Did this over and over again...frustrating!
When you've run out of mods, it's time to get something new.
racer1735 is offline
Old 07-04-2009, 05:47 PM   #3
captcomputer
captcomputer's Avatar
Fan#: 9409
What I Drive: 2013 Focus ST (Preferred Blue)
Points 10,721, Level 68
Points: 10,721, Level: 68 Points: 10,721, Level: 68 Points: 10,721, Level: 68
Level Up 68% Completed
FF Reputation: 37 captcomputer Great Standing Member
Good writeup an nice clear (NIKON) pictures.
Now lets add this to the sticky thread list.
Joe Cool
Social groups:
LoneStar Fanatics
(Former)Blue Focus Owners
captcomputer is offline
Old 07-06-2009, 09:43 AM   #4
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
I make em clear for everyone to see. Man was it hard to take pics alone with a SLR Nikon.
Ray
Posted via FF Mobile
Old 07-06-2009, 10:29 AM   #5
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
i have never seen anyone take the caliper apart to replace the pads. but hey, whatever works.
good write-up
to all people that want to do this. that square shiny looking brake tool is an absolute must to have. the piston screws back into place. a normal caliper clamp will not work. some people use different methods to screw the piston into place, but for the price of the tool, its well worth it. it makes it so fast.
scrammer is offline
Old 07-06-2009, 01:26 PM   #6
1-ST
1-ST's Avatar
Fan#: 53127
What I Drive: various duratec powered vehicles
Points 721, Level 14
Points: 721, Level: 14 Points: 721, Level: 14 Points: 721, Level: 14
Level Up 21% Completed
FF Reputation: 10 1-ST Great Standing Member
Great write up with LOTs of excellent pictures. rep for you!
Is this in the How-to section yet? it should be.
05 ZX4 ST - parts donor. Daily driver until a rock found the oil filter and locked the motor.
08 S Coupe - autocross toy. Less weight and more tire.
06 Ranger - lowered commuter and parts hauler.
1-ST is offline
Old 07-08-2009, 10:02 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
hey these are really cool pictures BUMP! Wow this should be in the How-to sections
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 07-11-2009, 01:06 PM   #8
SVTRSST
70 100 70 70 : (
SVTRSST's Avatar
Fan#: 50439
What I Drive: 2003 Sonic Blue SVT Focus
Points 8,661, Level 62
Points: 8,661, Level: 62 Points: 8,661, Level: 62 Points: 8,661, Level: 62
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 16 SVTRSST Great Standing Member
Buy-Sell-Trade Rating: (10)
hey i didnt read any of machined rotors.. can someone explain if i really need to do that?, tukani?, anyone?
'03 SVT
0381 of 3985
SVTRSST is offline
Old 07-31-2009, 07:34 PM   #9
Focus112
Focus112's Avatar
Fan#: 50026
What I Drive: 2002 SVT Focus
Points 3,660, Level 38
Points: 3,660, Level: 38 Points: 3,660, Level: 38 Points: 3,660, Level: 38
Level Up 7% Completed
Forum Activity 3%
FF Reputation: 5 Focus112 Good Standing Member
i new something was fishy about the rear caliper, thanks a lot + rep
Focus112 is offline
Old 07-31-2009, 11:15 PM   #10
lightning2nd
love my red focus
lightning2nd's Avatar
Fan#: 54938
What I Drive: 2006 Red ZX4 SES w/SAP
Points 1,324, Level 20
Points: 1,324, Level: 20 Points: 1,324, Level: 20 Points: 1,324, Level: 20
Level Up 24% Completed
FF Reputation: 3 lightning2nd Good Standing Member
nice job
Built on 1-18-06
06' Red ZX4 SES 2.0L Duratec/ with S.A.P.
member of Focus Nation / Sedan Revolution#105 / Sap Crew#23 / Team Duratec#189 / Midwest Crew#31
lightning2nd is offline
Similar Threads
How To - Extensive Suspension Overhaul (Front and Rear) SuperFlea Brakes, Suspension & Body Chassis 74 01-28-2015 11:20 AM
2009 Ford Focus Coupe Unveiling at 12:01AM EST Tom Ford Focus & General Car Chat 97 05-13-2008 07:34 PM
rear disk brake / SVT brake kit.. Midnight_DevilX Wheels & Tires 12 10-22-2007 11:22 PM
For Sale: Hawk HPS rear brake pads EnixIV Archive 2 07-03-2007 08:48 AM
SVT is Dead lduran Ford Focus & General Car Chat 149 03-18-2006 01:48 PM
