Home Depot Grill For 00-04 Models (Hi Picture Count) UPDATED!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-03-2009, 08:00 PM   #1
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
Id like to say thanks to Brad White as this is where I got the idea from. This is a really good cheap and easy project to do. I also think it looks a million times better than the OEM grill.
Tools:
Drill with 1/16 drill bit
Metal Shears
3/8 drive Socket
1/4 drive Socket
Various Sockets
Materials:
Two sheets of Gutter Graud
2-10 packs of #6x3/8 hex head srews
Total Cost:$7.00
Total Time: 3 hours (including time to take paictures)
Before:
Removal of Upper Grill
Step 1:
Remove the air damn from behind the grill.
Step 2:
Remove the four bolts holding the grill.
Step 3:
Unplug the lights from the harness.
Now your grill should be out and look like this.
Fabricating The Upper Mesh Grill
This is the gutter gaurd that I got. You can use any lightweight mesh you like.
Step 1:
Remove the Ford emblem from the grill. Use a 10mm socket to reomve these tow bolts on the back of the grill.
Step 2:
Lay the mesh ontop of the grill and center it. Then fold the mesh under the bottom of the grill so that the mesh lines up with the back edge of the grill. use your drill with the 1/16" drill bit and drill a pilot hole for the first screw in the center of the grill. Then use a 1/4" socket and screw the first screw into you pilot hole.
This is what it should look like at the end of this step.
Step 3:
Go to one end and drill another piolt hole and place another screw. Then trim with your shear along the bottom edge of the grill. Repet for the ohter end of the grill.
At the end of this step you should have 3 screws in the bottom of the grill.
Side Note: I did screw into the light housings. That way the screws could not be seen from the outside sticking thourgh. The screws should be in snug enough that moisture can not get into the housings.
Step 4:
Fold the mesh over the end of the grill. Then drill a pilot hole and place one screw on the end of the grill. After the srewed in use your shears and trim all over hang off the mesh.
Step 5:
Fold the remaining mesh over the top of the grill. Drill pilot holes and place a screw at each end of the grill. Then trim the mesh back as shown in picture 2. Next cut lines in the remianing mesh hanging over so you can fold the remaining mesh into the back of the grill.
You may want to try and just tuck the mesh without putting the screws in the top of the gill. Just so when the hood is open the screw are not there. But they are hardly seen if there.
Step 5: (Optional)
Use you wire sinps and cut the mesh from the front of the holes where the emblem goes. Then reinstall the emblem.
I had to use 5 minute epoxy to hold the bolts onto the stems of the emblem because the stems were chewed up from piror removal.
Congrats the upper grill is now finished. Re-install is the reverse of taking it out.
Fabricating The Lower Mesh Grill
Step 1:
Usinig zipties attach the mesh to the lower OEM grill. (this is only tempuary) Once the mesh is attached and not moving, use your shears and cut off the excess mesh following the opening of the bumper.
Step 2:
Once the mesh is cut to fit cut the zipties and remove mesh. (if you want to paint the mesh now is the time) Using door trim molding from your local auto parts store, line the outer edge of the cut metal. This gives a cleaner edge and protects yuor hands from cuts when washing the car in the future.
Step 3:
After the mesh is lined with the molding, attched it to the OEM grill with zipties, or light gauge wire. I put a ziptie on each of the verticle pilars, five in total.
Note: If you have a light colored car, and do not put the emblem back on, you will need to paint the metal brace behind the grill where the emblem goes. It will show through both grills if left a light color.
Congrats Your Done!
After With Non Painted Mesh:
After Painted Black:
I have future plans for the fog light area so that is why I didnt go all they way to the end. If you would like to go all the way to the end a 3rd piece of mesh will be required.
Thanks for looking! Let me know if there is anything I need to explain better.
norcalfocus01 is offline
Old 07-03-2009, 08:02 PM   #2
volcomstone1966
RIP 02 SVT 0209
volcomstone1966's Avatar
Fan#: 35104
What I Drive: 04 PWSC EAP SVT - 04 Kawasaki ZX6R
Points 16,597, Level 82
Points: 16,597, Level: 82 Points: 16,597, Level: 82 Points: 16,597, Level: 82
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 15 volcomstone1966 Great Standing Member
Buy-Sell-Trade Rating: (45)
looks good i did the top grill to the zx5 a few years ago
with the same stuff
04 SVT EAP #1131 -POWERWORKS-Torsen-Clutch Masters-Top Speed-Massive-Brembo-Fifteen52-Steeda-UNDER CONSTRUCTION
2K14 Turbo Veloster
04 Kawasaki ZX6R
volcomstone1966 is offline
Old 07-03-2009, 08:15 PM   #3
captcurt_18
captcurt_18's Avatar
Fan#: 49565
What I Drive: 2005 Light Tundra ZX4
FF Reputation: 26 captcurt_18 Great Standing Member
looks good. thats what my grille is made of and i love it
2005 Light Tundra ZX4 2002 BMW 325xi
Sedan Revolution Member #120
University of Montana
Photoshop Guru! PM me if you need something chopped up
Give me rep if im helpful!
captcurt_18 is offline
Old 07-03-2009, 08:24 PM   #4
jmiller_1974
Flipping Rockstar
Fan#: 57165
What I Drive: Black 02 SVT #2998
FF Reputation: 28 jmiller_1974 Great Standing Member
Buy-Sell-Trade Rating: (14)
Nice write up, Chris. Looks nice, too.
dreamspeed
jmiller_1974 is offline
Old 07-03-2009, 08:31 PM   #5
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,825, Level 59
Points: 7,825, Level: 59 Points: 7,825, Level: 59 Points: 7,825, Level: 59
Level Up 38% Completed
Forum Activity 19%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Sweet right up , now if you would just do mine for me
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is online now
Old 07-03-2009, 09:02 PM   #6
focus_evolution
focus_evolution's Avatar
Fan#: 52963
What I Drive: 2007 Brown SE(gone),2000 Black Zx3
FF Reputation: 1 focus_evolution Good Standing Member
great job looks good
Focus_evolution 2.0 zx3 is here!!!
focus_evolution is offline
Old 07-03-2009, 09:17 PM   #7
trevor
trevor's Avatar
Fan#: 49876
What I Drive: 2001 infared zx3
FF Reputation: 2 trevor Good Standing Member
am i the only one who thinks that this looks cheep and cholo-ish?
obx 4-2-1 race header, 2.25" focus sport cat-back, svt air box w/K&N, pipercross air ram, Roush stage 2 suspension, gaped plugs to .06, Taylor 8mm wires, ported TB, stedea ps motor mount, charcoal tint 35% front and 20% rear. FORD HONDA
trevor is offline
Old 07-03-2009, 10:58 PM   #8
stilix
Zzzykeyah!!!!!!
stilix's Avatar
Fan#: 53230
What I Drive: 2007 liquid grey metallic ZX3
FF Reputation: 4 stilix Good Standing Member
Buy-Sell-Trade Rating: (13)
i agree
ROTM: August 2011
stilix is offline
Old 07-03-2009, 11:41 PM   #9
lightning2nd
love my red focus
lightning2nd's Avatar
Fan#: 54938
What I Drive: 2006 Red ZX4 SES w/SAP
Points 1,324, Level 20
Points: 1,324, Level: 20 Points: 1,324, Level: 20 Points: 1,324, Level: 20
Level Up 24% Completed
FF Reputation: 3 lightning2nd Good Standing Member
lookin good, and nice job
Built on 1-18-06
06' Red ZX4 SES 2.0L Duratec/ with S.A.P.
member of Focus Nation / Sedan Revolution#105 / Sap Crew#23 / Team Duratec#189 / Midwest Crew#31
lightning2nd is offline
Old 07-04-2009, 12:14 AM   #10
TaylorinAlaska
TaylorinAlaska's Avatar
Fan#: 62423
What I Drive: F-dub soon-to-be
FF Reputation: 17 TaylorinAlaska Great Standing Member
Well jeez, you don't have to be rude. It looks ok, it needs some work. It doesn't quite fit, and the bottom is a bit much. How about painiting it black?
I like the fact that its custom, at least your not like the 1,678,923 other foci out there. Good job!
Originally Posted by Peregrine View Post
Who in their right mind would run 185's on a 7"wide tire? That's retarded.
TaylorinAlaska is offline
Similar Threads
the home depot front lip fffl6 MK1 Focus 6 02-27-2009 08:25 PM
Bargain at Home Depot! foundonroadalive Auto Washing, Detailing & Paint Protection 8 05-23-2008 09:07 AM
jrsc + home depot xp0s3d General Forced Induction 9 10-28-2006 09:02 PM
Things you can't get at Home Depot... cbo_and21 Ford Focus & General Car Chat 7 01-04-2006 02:31 PM
